Re: Magnovox 32MF231D
Thanks budm for pointing me in the right direction.
Yeah, there's a lot of ICs, but I only had to check the first one. Look:
I can see a small crack, and a pin-sized hole on the chip. So I'm off to Digikey to order a new one.
broksonic, I suggest you check this chip on your board too.
I did check a few other things:
Why is the Vcc only 0.1v on this one? Shouldn't it be 24V?
Code:
12V supply IC (7003): Pin 1 (OUT) = 11.8v Pin 2 (Sync) =11.8v Pin 3 (Inh) = 11.8v Pin 4 (Comp) =11.9v Pin 5 (FB) = 11.5v Pin 6 (Vref) = 12.2v Pin 7 (GND) = 0.0v Pin 8 (Vcc) = 14.4v
Code:
Schottky rectifiers: 6001 has 4.60v on cathode lead 6002 has 4.80v on cathode 6003 has 23.8v on cathode IC at location 7004 Pin 1 (OUT) = 5.2v Pin 2 = 0v Pin 3 = 0v Pin 4 (comp) = 0.9v Pin 5 (FB) = 1.2v Pin 6 = 0v Pin 7 = 0v Pin 8 (Vcc) = 0.1v
It sure looks like it though, since the dark green area criss-crosses and surrounds those four pins.
but I went and put my 2nd L5973 chip into the eBay scrapper. I repaired the trace on Friday and there's new diode for 6002.
Hopefully, budm or Tom will give their opinions.
