latitude 3350 blink 1 white light on
  • apostsamking
    • Dec 2017
    • 118
    • Ghana
    Pls I have latitude 3350 laptop and it stop working. I realize that anytime I press the power button it powers on blink 1 white light on and off. I flash bios but the same problem. I realize that the 3.3v that's on the bios chip is not stable. It goes on and off. But when I remove the bios chip from the board power is stable. I have change the bios chip still the same problem. What should I do.
  • mon2
    • 14721
    Start a fresh thread with the details of your issues. It will be easier to follow. You have a Dell so sure to check the adapter PS_ID signal line on the power adapter connector. Measure the voltage to ground of this important signal.
    • David Morel
      Latitude 5520 i7, adapter light goes off when plugged in
      by David Morel
      Hello! This is my very first post, thanks for accepting me on this forum.
      i have a 5520 latitude that suddenly stopped charging, the light from the adapter goes off when it’s plugged it, i tested different chargers, checked the ports and they seem to be fine, any help would be appreciated
      10-22-2025, 09:09 PM
    • icareservicezone
      Synology DS918+ blue light blink
      by icareservicezone
      Synology DS918+
      Model name : GDI41L2
      p/N: 08-06GDI4116
      Version: V1.6
      Problem : blue light blink...
      05-24-2025, 11:53 PM
    • djordje
      Philips 55 oled 804/12 red light blink
      by djordje
      Hello all,
      I have Philips Oled 55 (804/12) with black screen and red light blink.
      I have opened TV and tested voltages based on similar oled topics, on power supply board i am getting ps_o/f 3.3v and 5v for t-con_o/f while panel_o/f is 0v. And i get black screen.
      Also i have done self psb test and i am getting on psb +12V_t and also + 24V for panel. (Measurements on dmm are + 12.3V fot t-con and 22.4 for panel)
      When i power only psb and tcon with 4 ribbons for panel i only get black screen.
      My questions is what should i do next...
      01-03-2025, 04:00 PM
    • ruletero
      HP Omen only do not turn on, only flashes white light
      by ruletero
      Hi everyone
      Please help me with this laptop
      HP Omen 15-dc0003la , MB DAG3DBMB8D0 REV. D
      It doesn't turn on, when I connect the charger with battery orange light appears on power jack and without battery white light appear, it is fine I think
      But if I press power button, power led flashes white once, only that, not consumes anything power, not start, nothing more.
      Bios was programmed with a working version, no changes.
      Voltages
      +3vS5 = 3v when I connect charger, next goes to 0 (I think is fine)...
      06-07-2023, 10:11 AM
      RAB Lighting 30 and 48 White LED 9-12VDC Blinding Light Bars—> Very nice light bar
      I bought these LED light bars from Electronic Goldmine surplus store online
      These light bars are the nicest LED light bars I have ever seen in there online store
      I read the description of these light bars and said yeah right there bright at 9 volts
      Let just see if this is the case or not and just how bright is bright because I bought some of there light bars that they said were very bright and were ok but I would not say they were as bright as they claim
      But I thought I would give these a try only because they had both light bars on sale as a bundle...
      02-11-2021, 10:03 AM
