Vizio E371VA Power Problem?
  • Mark355
    • Apr 2012
    • 24
    First post from a newbie! My Dad of 84 was the proud owner of a Vizio E371VA which, of course fails after the warranty has expired......he doesn't have any paperwork anyway. Anyhow, the "Vizio" front logo will light, and when you "power" it up the logo dims slightly and the screen and logo will flicker slightly. That's it. After researching on the web I found countless references to the bad cap easy fix, so I'm thinking even I can handle that. After taking the back panel off, I find none of the caps to look bad, i.e. popped or leaking. Any thoughts? My Dad was ready to toss it and get another one.....which he really can't afford. SO I thought I would at least look at it. Oh yes, I do own a multimeter, but have limited knowledge on how to use it. I'm willing to learn, and hey, the unit is worthless now anyway. lol I can take and post pics if needed.
    Thanks in advance,
    Mark
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Vizio E371VA Power Problem?
    Post clear focused top down view pictures following the instructions in my sig file below exactly.
    We want the composition to look like the following
    https://www.badcaps.net/forum/showpo...94&postcount=1
    --- begin sig file ---
    --- end sig file ---
    • Mr Bill
      • Nov 2011
      • 648
      definitely post pictures of the power supply and the whole rear of the tv. You say the vizio logo dims. Is this the logo on the cabinet of the front of the tv or the splash screen before the tv turns on? Does the tv turn on despite the flickering?
      • Mark355
        • Apr 2012
        • 24
        Thanks for the quick responses. I'll take pics tomorrow. Oh yes, the logo is on the bottom of the unit, not the splash screen. When I push the power button, the logo dims slightly and the screen lightly flickers as well, that's all.
        Mark
        • cashkennedy
          • Aug 2011
          • 668
          Are you able to turn the tv "off" with the button? (as in will the logo return to amber after pressing the power button again)?
          Most likely this is bad regulators on the main board. You should search for the service manual (available at elektro tanya most likely). Then follow the DC-DC regulator testing path. You will need a multimeter for this.
          Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
          • Mark355
            • Apr 2012
            • 24
            Yes, I can turn the unit "off" with the power button i.e. the logo will dim slightly to the standby mode. Press it again and the logo will brighten and the screen as well as the logo will start to flicker slightly. Hope to get photos up ASAP. Busy day today though.
            Thanks,
            Mark
            • cashkennedy
              • Aug 2011
              • 668
              Is your logo changing color at all? Or just dimming?
              (Does it go from amber to white )
              • Mark355
                • Apr 2012
                • 24
                It changes brightness not color. I just fired it back up with the back cover off. When I plug the power in via the chord the "VIZIO" logo lights. Then when I push the power button on the side the logo actually brightens, and sometimes the screen will flicker and I noticed that a blue LED on one of the boards flashes as well. Also any opening in the metal backing I can see the same flickering, but it is much brighter. I can also hear a faint clicking sound. I have tried to upload the pictures that I took, but for some reason the upload times out. I have re-sized them below the 2000 x 2000 and they are under 2megs. Oh well.
                Thanks for your replies,
                Mark
                  1280x1024 is fine for us, just take some macro shots of important areas.
                  • Mark355
                    • Apr 2012
                    • 24
                    Weird, I had to upload the pics in Explorer, wouldn't in Mozilla. Go figure! Hope these help.
                    Thanks,
                    Mark
                      Darn - that's the first Vizio I've actually seen using cheap capacitors. For a "cheap" brand, Vizio are generally quite high quality, but I guess even they will shave a penny here and there.
                      Anyway, use your multimeter on the 200V DC range to check the outputs of the supply. (Don't worry, we aren't measuring 200V, we're measuring 24V.) Check the red wires going to the board of the left (looking from the back.) Place the black probe in part of the case (screw hole, etc), the red probe on the pins of the wires on either side. You should see around 24V give or take 1V.
                      Do -NOT- touch any of the heatsinks of the power supply, as they will sting you with some live voltage. The rest is safe to touch, with the exception of the high voltage for the backlights, but that is well covered up.
                        Since this power supply has PFC Voltage booster circuits, please also check the DC voltage on that large 450Vdc cap when TV is off, it should be around 165~170Vdc, then turn on the TV, the voltage should go up to 380~400Vdc, it does, that means the PS_ON is OK, if not, it can be due to no PS_ON or failed PFC circuits.
                        • Mark355
                          • Apr 2012
                          • 24
                          Well I checked the red leads and they all check at 24.8 volts. @budm, are you talking about the large black cap on the power supply board, at position C909? If so, any suggested precautions on the multimeter settings or how I should test?
                          Thanks,
                          Mark
                          • selldoor
                            Slow Learner
                            • 7870
                            Hi- Yes that is the capacitor he means.
                            These are high voltages so great care needed
                            Set your meter to 600vDC and put the black (negative) probe on the
                            Negative leg of the the capacitor. Put the red (positive) probe on the
                            positive leg of the capacitor. Do not hold the probes too near to the
                            metal points.
                            Remember heat sinks will carry a voltage that will give you a nasty jolt
                            • Mark355
                              • Apr 2012
                              • 24
                              OK, with the TV plugged in and in stand by mode the large cap read 173 volts, with the set on it read 411. And hey, I didn't cause a single arc!
                              Thanks again,
                              Mark
                                OK, that means the PS_ON signal is good, then next thing we will need to find out if you do have 24vdc for the inverter board. On your first picture, on the top left there is a connector (24vdc, red and black wires) that goes to the Inverter board on the bottom left of the picture, disconnect that cable, turn the TV on and see if you have 24vdc at the top left connector.
                                  The OP already checked that, but there are some other voltages to check.
                                  OP, Can you post some close ups of the connector going from PSU to main board?
                                  I note that there is an orange cap without a safety vent, this could easily be failed without knowing, but you would only find out for sure when it went "bang"! That seems a little dangerous to me....
                                    Oops, I missed that info, sorry.
                                    • Mark355
                                      • Apr 2012
                                      • 24
                                      Thanks for the continued suggestions. I hope the attached pics are what you needed. Also, in the second pic, is this the orange cap that you were talking about?
                                      Thanks again,
                                      Mark
                                        I don't see a second pic but thanks for the connector. With main board plugged in check the voltage on the +12V and +5V like you did for the inverter power.
                                        • Super360
                                          Vizio E701i-A3 Vizio logo flashing then turns off
                                          by Super360
                                          Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
                                          07-25-2024, 07:06 PM
                                        • x_orange90_x
                                          Vizio V555-G1 stuck on wallpaper; now stuck on V logo
                                          by x_orange90_x
                                          I just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
                                          12-28-2023, 06:26 AM
                                        • rajbot
                                          No Power problem with Vizio E60-E3
                                          by rajbot
                                          Hi all:
                                          I have a Vizio E60-E3 I am trying to troubleshoot a no power problem with. Thanks to the help on this board and elsewhere, I was pretty sure I had narrowed it to a power board problem. The board in question is a 09-60CAP0D0-00. Image attached for reference, but not of my board (tv is put away at the moment). FWIW, no obvious looking issues with the board.
                                          I measured voltage at power in and on the fuse and saw 120V, so power is getting to the board.
                                          On the pins out to the main board, I got no voltage at all on any of the pins. I assumed this...
                                          03-22-2023, 08:09 AM
                                        • theone111
                                          by theone111
                                          3. Problem: TV shuts down
                                          07-22-2024, 10:36 AM
                                        • MICHAEL_2013
                                          Change Logo Aptio Setup Utility 2021 (ROM Layout mismatch detected) Problem
                                          by MICHAEL_2013
                                          Good afternoon, Lords of great wisdom. My problem is the following: I bought a Chinese laptop with GN117_MB_V31-T board. (Aptio Setup Utility 2021) (There is no info for that board). And I want to change the logo of the bios. I have used Aptio_V Afuwin to do the bios Backup, then I change the logo with AMI ChangeLogo Tool v5.0.0.2 and everything seems perfect. But when you restart the new logo appears ok. But it automatically enters the bios, appearing a new option RECOVERY, ROM LAYOUT MISMATCH DETECTED - PARTIAL UPDATE IS NOT ALLOWED. If I give ESC it enters windows without problem but always...
                                          06-28-2021, 03:12 PM
