I'd Like to buy the ESR Meter you all recommended, but......
+ More Options
Posts
  • Paul678
    • Nov 2011
    • 402
    ....why when I try to buy it:
    http://www.prc68.com/P/Prod.html#ESR
    It says, ask to see if in stock, and when
    I click on the link, I get:
    http://www.prc68.com/Contact.html
    I mean, is this Brooke Clark guy the
    person who makes these things? And
    if so, why is he trying to meet women
    when I'm trying to buy his product???
    Re: I'd Like to buy the ESR Meter you all recommended, but......
    I believe a lot of people here use and like the Blue ESR meter, it sounds pretty good for the price. That is what I would get if I have low budget. I use SENCORE LC-75.
      I use the Atlas ESR60, because it does capacitance too.
      • ivtec
        • Dec 2008
        • 1967
        :electronix.com/capanalyzer-88a-test-device-p-7363.htmlhy:
        I have this one and it does ESK and analyses caps pretty good
          Tom, that Atlas ESR60 looks pretty good especially with the automatic discharge function.
          Does the read out comes close to the spec of the cap rating (ESR)?
          • Paul678
            • Nov 2011
            • 402
            Yes, the meter I posted also does capacitance at the same
            time.
            But yours seem like a good one (and packaged better),
            but also more expensive:
            http://www.ebay.com/itm/NEW-Peak-Atl...item519df423dd
            Does this look like a decent price for this one?
            It also goes up to 22,000 uF, which I'm sure
            is enough, but the micro V4 claims to go up
            to 60,000 uF.
            • Paul678
              • Nov 2011
              • 402
              I also considered the Blue ESR meter, but it's actually
              about the same price, and it only measures the ESR,
              and not the capacitance at the same time.
              Also, the Blue meter is in kit form, whereas the Micro V4
              is already assembled.
              • tibimakai
                • Jan 2012
                • 3680
                with these meters you can measure the capacitors on the board, or they still have to be unsoldered?
                  I wouldn't rely on the discharge function. It's only rated to ±50V with >10uF capacitor.
                  The reading is typically very good but the probes fell off the connector in a few weeks, so I had to repair those and recalibrate it (which is simple... just zeroing the meter from the internal menu.) I have found several bad caps using it, including one which did not bulge.
                    to 60,000 uF.
                    I don't think you need to worry about more than 4700uF.
                    • Paul678
                      • Nov 2011
                      • 402
                      What do you think about the Russian-made Micro V4?
                      http://www.prc68.com/I/ESRmicro.shtml
                      It's about $70 less than the one you have.....
                      • chth96
                        by chth96
                        03-09-2024, 10:03 PM
                        12-31-2023, 06:04 AM
                      • jorpec
                        by jorpec
                        Hi
                        Thnaks
                        01-23-2023, 10:37 AM
                        Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                        12-14-2023, 07:45 PM
                      • Stephan Mathers
                        EDMI ATLAS MK10 Electronic Meter Discussion
                        by Stephan Mathers
                        Greetings, new guy here but always interested in the crazy universe of modding
                        We just finished construction of around 25 vacation houses, all inside the same private area.
                        Each house has 3phase power , and we bought an atlas MK10 meter for each house (25 meters total ! )
                        The metering on a per-house basis is done privately. Its not done by a utility company. The utility company will only charge us for the total consumption of all 25 houses together.
                        Id like to do a small modification on the firmware of our MK10 to make it easier identify each house's...
                        05-20-2025, 09:09 AM
