vizio amber light E321VL
  • Monsolo
    • Jul 2012
    Re: vizio amber light E321VL
    Originally posted by killian6pk
    You need to start a new thread on your tv. Take good close up pictures of the front and back of your power board and mainboard. Post them with the Manage Attachments button below in the Additional Options section. You will be helped to figure out your problem if it is possible to do so.
    Will do, thanks!
    • DULLTV
      • May 2012
      • 9
      • usa
      #102
      I got a e321vl that power on(backlight is on) but no picture.
      Any suggestions ?
      • killian6pk
        • Apr 2010
        • 502
        Any suggestions ?
        See the post directly above yours. These old posts don't get the attention because people think the problem was solved or the OP gave up. So just start a new thread with good, focused top down pictures of both sides of each of your boards. Also one picture with all the boards hooked up (as if you just took the back off). We want to be able to read the writing on the boards.
        Have you ever stopped to think and then forget to start thinking again?
        As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."
        • DULLTV
          • May 2012
          • 9
          • usa
          #104
          • elvergon
            • Dec 2012
            • mexico
            #105
            hi some help i check the pins and the one that is to give me 12v is not
            given me that amount of energy
            • ealequi
              • Dec 2012
              • 212
              • usa
              #106
              this is a very easy fix guys. u18 is the eeprom in the center need to be reprogram or buy a new one on ebay for 25.00 already program.
              • kdh2012
                • Dec 2012
                • 17
                • usa
                #107
                I just bought one of those eeproms. Didn't fix the board/tv.
                Turned out to be a bad solder joint. I resoldered parts in groups, so I don't know exactly which part was the problem. But, I have a pretty good idea.
                Those resistor packs around the main IC do not have legs. The contacts do not necessarily touch the pads. So, in order to make contact, you have to bridge the solder joint. That is a good way to have a bad contact.
                Anyway, after soldering all the r-packs, the tv works! Yea! I would suggest resoldering all the r-packs on both sides of the board near that main IC.
                Good luck!
                (anyone want a $25 chip )
                • huzo
                  HP 470 G5 blinking amber light no power
                  by huzo
                  The board is daox8cmb6eo and i can't find no boardview or schematics on the forum or anywhere...
                  So i plug in the charger, amber light starts blinking ,there is 3.3V and 5V present, and 2.4V on the power button,board doesn't turn on, no shorts...
                  I've tried flashing the bios...
                  interesting thing is the battery was around 7,8V, and it's 11.1V battery, the mosfet near the battery is open, but not charging,i desoldered it,tested it and it's fine ,but the amber light kept going on the charger so i charged the battery with power supply and got it to about 10.5V...
                  06-08-2023, 04:08 PM
                • What?
                  Vizio SV422XVT blinking amber/white power light
                  by What?
                  Good day, hope all are healthy and cozy. I could use some help with my malfunctioning Vizio with a blinking power light. I have narrowed the problem to the main board but not sure what to do next. I guess it would be good to start with what I have done.
                  Problem:
                  I have no image, no sound, blinking power light. (left it plugged in overnight and it was still blinking the following morning). I tried the Vizio recommendations (hold power button for 30 seconds, press reset button, check the outlet is live)
                  Power Board:
                  I am getting 5v only. I have unplugged...
                  04-27-2020, 06:21 PM
                • stevenallauca
                  HP laptop does not charge the battery, the light turns amber and then changes to white.
                  by stevenallauca
                  Hello everyone. I have a problem with an HP laptop, when connecting the charger the amber light comes on for 6 seconds, changes to white and does not charge, I have checked all the components with the multimeter and the values seem correct, I was guided by the diagram, I do not know if it is a problem with the BQ24728H charge controller, investigating it seems that the voltages given by the charge controller are correct, I made the measurements connected to the power source and without the battery:
                  - ACN (BQACN) 19.6v
                  - ACP (BQACP) 19.6v
                  - CMSRC (BQCMSRC) 19.6v
                  - ACDRV...
                  09-23-2024, 11:30 AM
                • x_orange90_x
                  Vizio E550i-A0 no power, no standby light
                  by x_orange90_x
                  I have a Vizio E550i-A0 that will not power on. It also does not display the standby light in the corner. I disconnected the main board cable to see if the backlights would light but they did not (maybe this is normal for this set?). I checked the voltages on the plug and they all read in mV or 0, so there's no voltage there. The fuses are ok, and the voltages of the 450v caps read about 160v. I see no visual damage on either the power supply or main board. I have read online that the main board is usually the culprit in this model, but not getting backlights with the main disconnected makes me...
                  11-20-2023, 09:49 AM
                • zwect
                  Dell Latitude 5420 / GDF40 LA-K491P REV 3.0 / Amber / Orange light when power button is pressed
                  by zwect
                  I have this Dell Latitude 5420 with ST: CMF62F3, board GDF40 LA-K491P REV 3.0 that does not power on, i already searched for some clues about this problem that happens on mine but no BIOS i downloaded and flashed did anything.
                  Only when the power brick is connected, when pressing the power button an amber light lights up at the front and slight decreases its brightness, the RAM and the CPU seem to heat up if the laptop is left connected but nothing else, other than USB devices getting powered.
                  Here is the original BIOS dump from the 25R256JVEN chip.
                  09-11-2024, 05:54 PM
