Philips 32PF5521D/10 Stuck in Standby Sortof
    Re: Philips 32PF5521D/10 Stuck in Standby Sortof
    Startup cap is a ~10-100uF 16-50V cap on primary supplies Vcc for controller.
    • QuantumCheese
      • Jan 2012
      • 35
      can you be a little more specific please?
      the psu board has 4 supplies ranging from 24V to 3v3,
      the SSB board (which features "a contoller" or Hercules according to the service man) about 5 (supplies) i think, and the IBO board another 5 or 6.
      "~10-100uF 16-50V" is pretty vague for supplies ranging from 24V to 1V2 wouldn't you say!
      • selldoor
        Slow Learner
        • 7870
        Not sure if you think I am joking about the hair dryer ? just type hair into the search
        ( search by post not thread )above and see how many hits you get.
        • QuantumCheese
          • Jan 2012
          • 35
          No! it's got just as much logic behind it as the can freezer spray i have, i've just never come across it before!
            On PSU there will only be a few caps on primary side. These are mostly start up caps and can cause the symptoms you describe.
            • selldoor
              Slow Learner
              • 7870
              #26
              C505 or C130 look to be the only two
              • QuantumCheese
                • Jan 2012
                • 35
                Are we at crossed purposes here?
                I don't see either of those references on the psu board. the other boards all have 4 digit designators
                • QuantumCheese
                  • Jan 2012
                  • 35
                  are they on the underside? the schematics available through electrotanya seem to omit the 32" supply board?
                  • QuantumCheese
                    • Jan 2012
                    • 35
                    and anyway if the psu fires up & the outputs are all nob on, why am i looking for a cap on the psu board?
                    • selldoor
                      Slow Learner
                      • 7870
                      #30
                      They are on your picture in post 3 or is that not your board?
                      • QuantumCheese
                        • Jan 2012
                        • 35
                        My Apologies, they are there after all.
                        What i'm failing to understand here is why your suggesting i check these components. If they were bad, the supply would not start. if the supply did not start i would be hard pushed to have verified the outputs on a scope already?
                        a few posts back when i said "The same damn fault as before", that included being able to hot-wire the backlight into firing up, again a difficult thing to do if the supply board is not working?
                          No. The startup cap provides power to Vcc. If the startup cap dries out, Vcc will sag during power up. However, if the cap is feeling okay (warm) and the chip is also feeling forgiving, it *may* just about work occasionally. I suggest simply replacing them as they are 50p components.
                          • QuantumCheese
                            • Jan 2012
                            • 35
                            Both measure well within spec.
                            Their are two caps on the psu board that are a bit close to the limit.
                            1- 120uF 450V on front end, measures at 110uF
                            2- 470uf 35v filters Vp (i think) measures at ~420uF
                            Neither of the above seem hugely significant, unless i'm missing a function of Vp, i believe it's only used to drive the audio amp,
                            Also and theirs no squealing audible at the front end, usual when the primary reservoir is duff
                            I still think the fault lies somewhere other than the psu board.
                            I pulled pins 10 and 11 (power down & standby) off the connector to the SSB, and managed to get 3 led flash codes out of the set.
                            1) "+12V from PSU error" - that figures as i had pulled the power good lead out
                            2) "+5V protection" - not sure what that means yet
                            3) "I2C error while communicating with ADC"
                            I'm not sure of the significance of any of these as when i put pins 10 & 11 back we were back to constant RED
                            • selldoor
                              Slow Learner
                              • 7870
                              #34
                              When you say your capacitors are within spec, what are you testing them with. A capacitance tester or an ESR meter? The cap can pass a capacitance test but still be bad due to high ESR.
                              The hairdryer trick also relates partially to this as a heated cap generally has a lower ESR than a cold one. - did you try it?
                              • QuantumCheese
                                • Jan 2012
                                • 35
                                one was 0.3 and the other was 0.7 ohms as measured with an PEAK Atlas ESR70.
                                • kueberco
                                  • Mar 2012
                                  • 66
                                  • usa
                                  #36
                                  Check the PFC controller on backside of power supply board. Mine was part#L6562D Search philips 32pfl5322d/37 power supply. Page 8
                                  • QuantumCheese
                                    • Jan 2012
                                    • 35
                                    Thanks, but i'm not sure how applicable that is to this fault. That PSU's of a completely different design, though mine does seem to feature a similar device in a similar location, it's not suffering a similar fault to that thread.
                                    • kueberco
                                      • Mar 2012
                                      • 66
                                      • usa
                                      #38
                                      Power boards look almost identical.
                                      • QuantumCheese
                                        • Jan 2012
                                        • 35
                                        Err, yea like an Audi Q7 looks like a Q5 if you take a few paces back.
                                        they [the boards] were clearly designed by the same people.
                                        water looks identical to vodka.... i could go on
                                        • duwane
                                          MacBook Air A2337 - 820-02016 - Stuck at 5v - Varying current draw - Board had short
                                          by duwane
                                          Hi All.
                                          I have an 820-02016 board (A2337 M1) that has come in for data recovery. Reported as liquid damage, but no visible evidence of any liquid damage.
                                          Board was initially stuck at 5v, and current only spiking occasionally to around 400mA and cycling.
                                          After initial troubleshooting, found that C7800 (which feeds the power rail PP5V_BSTLQ_VOUT_SPMU) was dead short to ground.
                                          Replaced C7800 and short gone. Board still stuck at 5v. Current draw behaviour changed. It now spikes up for a second to around 100mA to 130mA, then drops down to...
                                          10-17-2023, 07:48 PM
                                        • tuner2000i
                                          Philips 65PUS8518/12 distorted image after main board replacement
                                          by tuner2000i
                                          hello everyone,
                                          I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
                                          The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
                                          07-15-2025, 01:15 PM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                          by G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                          It does power up when pressing the power button.
                                          I already try the power button while plugin the plug with no result.
                                          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                          Could this be an PSU or eMMC issue ?
                                          07-19-2025, 03:43 AM
                                        • mferna14
                                          Apple 820-01958-A logic board stuck on 5V .19amp
                                          by mferna14
                                          Hi friends, working on a MacBook Air A2179 logic board 820-01958-A logic board. It's just stuck on 5V .19amp on one USB-port & then when I use to the other port it's also stuck on 5V .19amp but on this port it resets after few secs & start over with the same said voltage. I assumed that one of the CD3217B12s is defective, & replaced both with known good ICs. The status & result remains the same. I checked for shorts or liquid spill, all clear. On F8400 there is 12v present, but no 5V or 3.3 volts. There are LDO voltages on the both CDs 3.2v & 1.5V. Kindly if someone can help...
                                          02-21-2025, 03:42 PM
