Acoustic solutions LCD26761HDF no backlight
  • sienoki
    replied
    Re: Acoustic solutions LCD26761HDF no backlight
    Originally posted by budm
    Too bad you DID NOT tell us that you did not check to see if it is putting out the 24vdc after the IC is replaced! I am begining to wonder if you do have the 24vdc all along but the problem was a blown fuse for the Inverter controller circuits.
    That is OK, now you know a lot more than before! I am just glad to be able to do remote troubleshooting.
    Cheers!
    When i first got this set there was no 24v reading at the inverter pin out on psu..with or without inverter lead pluged in..so that IC must have been bad & needed replacing as well as the fuse...was so close to throwing towel in & telling my m8 that he needs another psu..total cost should be 5pounds with the fuses added..so once again you guys you guys fixed this set i was the 1 sh**ing it with multimeter..lol
    replied
    Cheers!
    replied
    Originally posted by sienoki
    I jumped it for now as ive no fuses etc
    http://i1068.photobucket.com/albums/...5/P1000929.jpg
    And its working...thx for being very patient with me..im a very very slow learner lol...if you guys lived near by it would be beers all around..im gonna get them fuses from selldoors link tommoz...so TOM..BUDM..SELLDOOR&again..thx
    As the PSU puts out about 4A remember to replace it sooner or later or you will have a mess of melted wire to fix if something goes wrong.
  • sienoki
    replied
    Put 2.2 Ohm in place of the fuse for now.
    replied
  • selldoor
    replied
    I think he said 2.2 ohm not kilo ohm
    They are very small - see http://cpc.farnell.com/phoenix-passi...70?Ntt=re03770
    or These for the 2.2
    http://cpc.farnell.com/phoenix-passi...71?Ntt=re03771
  • sienoki
    replied
    Disregard the R925, that message was for another person in another thread, sorry, too many threads to reply to.
    So that 2.2k is ok to test for know fella..thx
    replied
    replied
    What I mean is that you can use small value resistor in place of the fuse. Sometime it is referred to fusible resistor, very common usage in place of the fuse.
  • sienoki
    replied
    Sorry, R925.
    3 reds & gold is 2.2k correct...the R925 is that a common part..thx
    Found a red red red gold gonna desolder & get bk to you guys...thx
    replied
    Sorry, R925.
  • sienoki
    replied
    At this point, since the PFC is working, then I would say the PS_ON is OK since the 400vdc is now feeding the 24vdc switching power supply circuits, that 1A fuse on the inverter board is for the controlling the Inverter circuits which turns on/off the Inverter Oscillator/output driving/Dimming circuits.
    I use Littlefuse PICOFUSE 1A in its place. You can use 1 or 2.2 Ohm 1/4W MOX resistor for now to test.
    Budm sorry for not knowing which resistor you mean..dont suppose you know what colour bands are so i can look on some old boards..thx
    replied
  • sienoki
    replied
    Originally posted by tom66
    Different approach-
    I'm guessing you have standby voltages?
    Is there an on/off signal going to be the PSU to turn the 24V on or off?
    Is that the 12pin of PL802 tom..thx
  • sienoki
    replied
    Tom how am i checking your sujestion..thx
    Can you plz tell me what to check on the schematics..thx
  • sienoki
    replied
    Different approach-
    replied
    Different approach-
  • sienoki
    replied
    That is 1A fuse as printed on the circuit board, where is this fuse at again? I thought you had checked to see if you are getting the 24vdc OUTPUT after installed the new IC!
    No m8 i never checked for 24v after installing new IC..the fuse is on the inverter board..its F1A/76v not 75...should i jump it for now with solder wire till i get a new fuse..what type fuse should i get..thx
    I checked google for the type of fuse & came across this
    https://www.badcaps.net/forum/showth...18526...should i try the same procedure..thx
    replied
  • sienoki
    replied
    So that signal is the Positive, which is fed into the base in one of the two transistors in that section. We need to draw out how those two transistors and resistors are connected to pin 2 and pin 3 of the IC. That voltage must be used to turn on-off the Oscillator circuits of the PFC IC, that is the only thing I can think of.
    Can you draw out the physical connections of that section, or the schematic of it?
    Budm while doing them last measurements id thought id check the 24v pin out since ive not checked that since IC fitted..all 4 red wires measure 24v..so i took the shield off & found another fuse F1A/75V which seems to be shorted as no continuity..its got 20 as markings only..thx
    http://i1068.photobucket.com/albums/...5/P1000915.jpg
  • triplefour
    by triplefour
    09-13-2023, 10:43 PM
  • DanPoka
    Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
    by DanPoka
    I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
    Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
    This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
    02-15-2025, 05:05 AM
  • Comp_Pro
    No Backlight Macbook A1990 820-01041
    by Comp_Pro
    Hello all,
    Am trying to figure out this backlight issue with this A1990 Macbook Pro.
    Tests performed:
    There is no backlight even with a good screen.
    Backlight IC is receiving the correct support voltages.
    Fuse F8400 ok
    Current sense resistor R8400 ok
    Backlight IC is receiving 3.3V on enable pin.
    Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
    Backlight IC receiving 5V from PP5V_G3S
    Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
    I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
    05-06-2024, 10:23 PM
  • jimbofz
    lg 32LC46 backlight inverter board fault
    by jimbofz
    Hi this oldie had no backlight .after replacing caps on 24v rail ,
    still no b/l this uses inverter type:1315 B1-16A,
    im sure ive come across the same inverter in a samsung possibly le32r88bd ?
    all t/x in board test ok ,so i fitted 15k and led to pin 4 of oz964gn ic
    this allows protect to be temporary overridden.
    b/l now comes on
    but the left hand side of pic is gradually darker than the right side
    i have the cct for the tv
    but it does not have inverter cct.
    i opened it up to inspect the ccfl tubes
    and they dont have any...
    12-19-2021, 06:58 AM
  • cheebster
    iPad Pro 12.9 5th Gen Backlight Issue
    by cheebster
    Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
    Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
    Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
    The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
    Anyone...
    05-20-2025, 09:17 AM
