Acoustic solutions LCD26761HDF no backlight
    replied
    Re: Acoustic solutions LCD26761HDF no backlight
    You had the better pictures before that I download but I still cannot see some of the traces that run under the components.
  • sienoki
    replied
    Originally posted by budm
    I would like to be able to trace out those parts to see if they are connected to pin 2 and 3 of that IC.
    Are these pics any good..thx
    http://i1068.photobucket.com/albums/...5/P1000885.jpg
    http://i1068.photobucket.com/albums/...5/P1000884.jpg
    http://i1068.photobucket.com/albums/...5/P1000890.jpg
    replied
    replied
    Some how this company is doing something else. I still believe it has something to do with those components on the top left. The sensing may be some where else.
  • sienoki
    replied
    Originally posted by tom66
    I'm going by what I've seen in other app notes but there is usually a resistor connecting the source pin to the -ve of capacitor to act as a current sense. To detect short circuits but also to provide a slow-charge of the main bulk capacitors and on some designs it makes the power supply current-mode controlled instead of voltage-mode.
    My probes touched together on ohms settings reads 01.0..which 2 diodes are you refering to tom..thx
    replied
    There is no SOURCE resistor for sensing, it is connected to the two jumpers to ground, the sensing circuit is cone some where else, see the PDF. Gates has resistors that you can see in the PDF.
    I have a feeling that the components on the leaft side has something to do with start/stop control of the IC, the application notes does not show anything for start/stop function.
    Tom is correct abouit the diagram, it is not the same as your baord as you cam see from the trace layout.
    replied
    replied
    Originally posted by sienoki
    I know its not the same but just thought some of the components where in same place..theres abit floating about google about them 3 resistors in paralell
    Maybe there are some similarities, but I wouldn't rely on it. Did you check those diodes I mentioned?
  • sienoki
    replied
    17PW20 isn't the same as 17PW26 unfortunately.
    replied
  • sienoki
    replied
    Probably not the SMDs, R971 is likely the sense resistor. Don't worry about pulling it for now, what does you meter read when the leads are touched?
    Also check the two diodes for s/c looks like it's a two-switch forward converter. Big improvement on the old half-bridge Vestel designs which had huge reliability problems.
    C878 could also be faulty but unlikely just looks like a snubber.
    Tom ive come across this what do you think..the 3 resistors in parallel r817-818-819..ive got 3 new same value from another kit that i didnt need...
    When it mensions D861-Q841 & C904 they are print side right alongside the 24vpin out & thatD861 marking AP has readings both ways as i mentioned earlier in this thread..thx
    replied
    Is it the 2 smd resistors 103 & 330 if so they measure Q813-103=10.2 & 330=33.7 in circuit
    Q814-103=10.03 & 330=34.0
    The big resistor R971-red-red-silver-gold which is 0.22 only measures 00.8 thats in circuit shall i pull 1 leg..thx
  • sienoki
    replied
    Do i need the other items in this kit..thx
    http://www.ohmsupplies.co.uk/17PW26-...-Q813/Q814-S/C
    R971 1 leg pulled reads 02.4 is this O/C..thx
  • sienoki
    replied
  • sienoki
    replied
    Any big resistors connected to the source pin of the MOSFET? Can't see them from your pic. Might be O/C.
    Hi tom..do these pics help..thx
    http://i1068.photobucket.com/albums/...5/P1000867.jpg
    http://i1068.photobucket.com/albums/...5/P1000872.jpg
    http://i1068.photobucket.com/albums/...5/P1000871.jpg
    http://i1068.photobucket.com/albums/...5/P1000873.jpg
    replied
    IC came today still no backlight..where to next?..thx
  • sienoki
    replied
    Thx fella..ordered the IC will get back to you guys when installed..thx
  • sienoki
    replied
    Try that for now as it will eliminate a possible cause.
    replied
    Thx tom..should i recap all the board or just try this IC first..ive been reading about the 4 block caps 2 red & 2 grey..thx
  • sienoki
    replied
  • triplefour
    by triplefour
    09-13-2023, 10:43 PM
  • DanPoka
    Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
    by DanPoka
    I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
    Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
    This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
    02-15-2025, 05:05 AM
  • Comp_Pro
    No Backlight Macbook A1990 820-01041
    by Comp_Pro
    Hello all,
    Am trying to figure out this backlight issue with this A1990 Macbook Pro.
    Tests performed:
    There is no backlight even with a good screen.
    Backlight IC is receiving the correct support voltages.
    Fuse F8400 ok
    Current sense resistor R8400 ok
    Backlight IC is receiving 3.3V on enable pin.
    Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
    Backlight IC receiving 5V from PP5V_G3S
    Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
    I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
    05-06-2024, 10:23 PM
  • jimbofz
    lg 32LC46 backlight inverter board fault
    by jimbofz
    Hi this oldie had no backlight .after replacing caps on 24v rail ,
    still no b/l this uses inverter type:1315 B1-16A,
    im sure ive come across the same inverter in a samsung possibly le32r88bd ?
    all t/x in board test ok ,so i fitted 15k and led to pin 4 of oz964gn ic
    this allows protect to be temporary overridden.
    b/l now comes on
    but the left hand side of pic is gradually darker than the right side
    i have the cct for the tv
    but it does not have inverter cct.
    i opened it up to inspect the ccfl tubes
    and they dont have any...
    12-19-2021, 06:58 AM
  • cheebster
    iPad Pro 12.9 5th Gen Backlight Issue
    by cheebster
    Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
    Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
    Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
    The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
    Anyone...
    05-20-2025, 09:17 AM
