I have a Vizio VA26L that will turn on but there is no backlight. I did the flashlight test in a dark room and can see the picture/menu being displayed but there is no backlight. The power on (white Vizio logo) and off (orange logo) works as it should. Voltages out of the power supply are 11.8V on the 12V, 23.3 on the 24V when turned on. The inverter board is getting 23.3V. However, it appears that the surface mount 1A/76V fuse labeled "20" (see red circle) is blown because I don't get continuity across it. Should I check it a different way? I was considering soldering in a new fuse and seeing if it blows again. The power supply was full of Capxion caps but none appeared bulging or failed. I did, however replace all except the 450V 150uF big cap on the power supply board in case some had failed without visible signs. Is there anything else I should test or check before trying the new fuse?
There are 4 caps of unknown origin and size (label side is glued down to board) but none appear bulging. Should I replace these? It looks as if someone might have reflowed them at some point but I do not know for sure.
Board markings: VIT70063.50 rev 3, 27-D023043, I260B1-5UA-L201C
Thanks in advance.
DK
Thanks in advance.
DK
