Sharp lc-42sb45u no response... at all.
  • Justin_D33
    You know what pisses me off? Finding CapXon in the wild.
    by Justin_D33
    It doesn't matter the series - GL, KF, LX, PD, I don't care. If I see CapXon in anything, my instinct is always "get it out of there". Even if it "looks fine". They should be ashamed of themselves. CapXon = CrapXon (rightfully memed).
    11-25-2025, 09:27 PM
  • advant
    by advant
    02-03-2020, 12:25 AM
  • sefoster
    Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
    by sefoster
    I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
    11-20-2022, 09:29 AM
  • gavenb
    Sharp LC-80LE661U 80 inch
    by gavenb
    Hi folks!
    I have a LC-80LE661U that had some interesting issues.
    Initially, it would come on and show the sharp logo and would show normal static before shutting off.
    I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it...
    11-12-2023, 02:05 PM
  • SONY_E-WASTER
    Help! Sharp LC-70UE30U 3 long flashes + 3 short flashes.
    by SONY_E-WASTER
    Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
    The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
    then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
    does...
    12-26-2021, 05:46 PM
