Re: Sharp lc-42sb45u no response... at all.
That means the transistor of the PS_ON detection circuits on the power supply is getting enough Base current to turn it on, if you discconect that PS_ON from the main board and check the output voltage at the PS_ON pin on the main board, you will more likely to see something close to 5V.
For the backlight to turn on, it should have another signal called "BL_ON", or "INV_ON" from the main board that goes to the Inverter board.
