Got this for free with a cracked screen. I had a screen (LTA-460HH-l04) so I put the parts except for the TON in it (big job!!). Now I have this problem. Is it the TCON or the panel?
Mitsubishi lt-46144 problem
Re: Mitsubishi lt-46144 problem
Is the replacement panel identical to the original panel?
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
also check the resolution of the original and the "new" panel (if it's not exactly the same model number)
Had a similar results on a netbook. Reason was that the replacement screen didn't have the same resolution as the old cracked one (1024x576 vs. 1024x600)
Garbage on the screen looked similar.. chopped up and all over the place.
The panel is exactly the same as the original. It's a samsung panel. I replaced the TCON with the original one that came out of the set with the cracked screen and the problem is the same Maybe a main board or as I suspect the panel I've had in my garage for a year is bad.Comment
This is a bad panel from the point of view of Mitsubishi. I have seen this symptom before. The replacement panels from Mitsubishi come with a new TCON and buffers. The buffers will not cause this. The TCON might. This panel was terrible. I would not be surprised at all if and other brands using the same panel were defective in the same way.
Did you ever see the replacement actually work properly?
Did you ever see that symptom on the cracked panel?Comment
by jimjoe123I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
Then each time... -
on this laptop acer aspire v571p the led of the power indicator blinks blue for periods of 1s lighted and 3s off after switch on and this indefinitely.
i tried the hard reset, cmos reset, changing the ram without results.
in order to reach the cmos battery i disassembled the laptop and did several mesures with my multimeter.
The 19v, 5v, 3v are well established after the chip 5v-3v. the following signals : 3d3v_aux_kbc (which supplies the sio chip) and 3d3_s5 are well established also.
but the signals: 3dv3_s0, pw_slp_s3# and pw_slp_s4 oscillate at the same...11-22-2025, 03:54 PM -
by perzyk23Good morning,
I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise.... -
by ChrissygizmoHello again everyone,
This is my latest mission, to try getting this Sony tv back to normal working order…
I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried... -
by reformattJust had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...07-31-2025, 08:37 PM - Loading...
