L32 HDTV10A Won't turn on fully
    I recently was givin a vizio L32 HDTV10A to mess around with. When I push the power button the power light goes from standby (orange) to power on (green), but i get no response from the tv. No picture, no backlight, nothing. and once the tv is on, i can't turn it back off without unplugging it. I can't really see any obvious signs of burning or bad capacitors on power supply or main board. I just want to know which part to replace. I don't want to buy the wrong thing. I'm kind of new at this. Some help with this would be greatly appreciated
    Re: L32 HDTV10A Won't turn on fully
    This is a VERY common problem; a little searching would have shown you U33 is often bad. Currently indications are another (unknown) component is causing U33 to fail. It is STRONGLY suggested you search the forum for other threads dealing with this TV and test U33 before ordering a replacement.
    PlainBill
      The symptoms that you've listed are common with mainboard issues. Research a little bit here using the search function and look for vizio. 32 inch 37inch and 42 inch vizio's have been having these same problems.
        There is a chance the U26 has been damaged, but that symptom is slightly different (amber only; no green on power-up). It's a very tiny component on the upper right region of the mainboard that controls the TV power on. Most people probably can't see the melted solder point without a 10x lens.
        You can bridge it with a 10k ohm resistor or diode (I chose the resistor), but it would be preferable to repair it and replace the component. Fixing a $700 mainboard with a 20 cent resistor is very rewarding.
        https://www.badcaps.net/forum/showth...32+amber+light
          i did some more tinkering with the tv. I tried using a standard electrical wire to bridge the connection for u26, now the power light turns green right when i plugg it in. Did i just make the tv worse?
            Probably. If you are trying to screw up your TV, you don't need my help.
            PlainBill
              That was funny ... PlainBill
