Random Vertical Lines on Samsung LCD TV
    Re: Random Vertical Lines on Samsung LCD TV
    It looks like the same one I fixed last week, I thought it was the tab bonding also, but it turns out to be T-C0N after all.
    https://www.badcaps.net/forum/showth...ng+LN32B540P8D
    http://s807.photobucket.com/albums/y...20LN32B540P8D/
    • MisterD
      • Oct 2012
      • 668
      IF it's not the T-CON then try using a hair dryer and heat the tab bonds, then you may get results when pushing on them. check out my latest tab bond repair at this link.
      https://www.badcaps.net/forum/showthread.php?t=25709
      • grumpy bob
        • May 2013
        Hey guys,
        I registered for this forum just to post to this thread.
        I too have the same problem with the vertical lines.
        My TV is a Samsung LN40A750 purchased back in 2008 when it was brand new. I'm really bummed out because it is of course out of warranty, but only 5 years old and basically garbage after this recent problem. The pictures don't do the extent of the problem justice, it's getting worse.
        I am no stranger to DIY electronics work so I am gathering that what needs to be done is a T-Con replacement... Has anyone had any success with this particular series of samsung? I ordered a new T-Con off eBay for 40 bucks. Have already taken it apart and cleaned out the ribbon connectors from the Tcon. Easy stuff, considering I usually work on smaller boards. Put it back together though and no change...
        Sidenote: Samsung TVs are great... when they work. This will be it's 3rd repair and my first out of pocket. I initially had to get the bezel replaced after it had a separation issue with the red coloring, and a couple years ago had to get some bad caps replaced due to the cap plague. Samsung footed the bill for both.
        TL;DR - Vertical Line issue on a 5 year old Samsung LN40A750. Looking for success stories/suggestions.
        • Tealtuna
          • Jul 2013
          • 7
          I have a similar problem with my 4-year old Samsung LCD... I am going to post up pictures and description most likely in a new thread but I wanted to get my first post completed..
          And I wanted to bump for the last post above^ Now sure if his new T-Con worked or not!?
          I am a mechanical guy (engineer) but have done some minor electronic work and would rather do some troubleshooting with this forum before I pay for a repairman to diagnose the problem and find out that it's as much as a new TV.
          • Tealtuna
            • Jul 2013
            • 7
            Bought a tcon board for my ln46b650t1f samsung going to install today wish me luck.
            • grumpy bob
              • May 2013
              T-Con didn't work out for me. Then oddly enough the TV seemed fine after reinstalling the old board back in. Was good for 2 weeks then the capacitors went bad on me again. This would mark the second time I had a cap problem in this TV. Had the clicking, not turning on symptom. Samsung installed new caps once again. Then the TV was good to go again... for a week. Now I'm back to square one with the vertical lines and no real solution.
              I am so fed up with this TV I'm about to part it out. May be the last Samsung product I buy.
              Anyone else has any solutions I am all ears...
              • johnbinsc
                • Aug 2013
                • 24
                Just want to report another successful repair of a Samsung set with a tab bonding problem.
                My Samsung LN40A650A1F (LN40A650A1FXZA) 40" LCD TV was a hand me down from my father in law because it had developed some screen problems.
                When I initially received it, the TV had multiple images, expanded vertically upon startup, which then dissipated after 5-10 minutes of warm up. We lived with it like that for 6 months. However the problem became worse with left half screen dimming and some number of thin colored vertical bands running down the left side of the screen. This new problem would appear after the set had been on a few minutes, and in the early stages went away after 30 or so minutes. We tried just leaving the set on 24x7, but eventually the second problem just stopped going away.
                Following the a suggestion in some other threads here on badcaps.net, I purchased some heat conductive compressible foam on eBay (Thermagon T-Flex 6100 highly Compressible Gap Filling Interface Pad 47mm x 66mm) for $3.74 including s/h. I opened the TV and removed the metal frame on the LCD panel. While running the TV for at most 1 minute at a time to avoid overheating damage, I found that pressing down on the left most (as viewed when looking at the TV in the normal orientation) tab bonded flexible circuit, between the in-line driver IC and the glass panel edge, cleared the picture up for the most part. It seemed like the right most tab bond also had some effect on the picture. The 14 flexible circuit tab bonds in between had no effect on the picture when pressed on in various ways, so they seemed very solid. I cut two roughly 8 mm strips across the short edge of the Thermagon pad (so roughly 8mm x 47mm), peeled the backing off both sides, and applied them on top of the flexible circuits at both ends, aligning with the edge of the glass. In this position they partially overlapped the position of the inline integrated circuit, however I do not think the placement of the pads was particularly critical. I replaced the metal frame and tested the LCD panel and it had a perfect image again, which remained without any problem after I finished reassembling the TV.
                A couple of minor notes.
                1) I did "break and remake" the contacts on the cable from the main control board to the TCON board on both ends, and also on both ends of each of the four short ribbon cables from the TCON board to the signal distribution board. It had absolutely no effect on the LCD image when I powered it back on.
                2) The metal frame on my LCD panel was attached to the LCD by the 10 smaller silver screws from the front (image side), and also by three screws (M4-0.70 x 12mm) black machine screws that attached it to some other metal frame parts at the bottom. But there were 10 other screw holes on the sides for attaching the metal frame to the plastic LCD frame that did not have screws in them. I decided that adding these screws could only make the overall panel more rigid, and perhaps reduce flexing that might cause more problems, so I purchased the additional screws (M4-.70x12 oval head Phillips) at Lowe's and added them. There were no problems with clearance of the heads when reassembling the TV. This step was probably unnecessary, but I thought I would simply let folks know that you can do this without damage. Don't use longer screws, cause that could potentially cause problems.
                So thanks again to BudM and others for providing this information. Saved this TV from the landfill.
                • ridaKHI
                  • Mar 2021
                  • 16
                  • Egypt
                  #28
                  I have the same problem with my Samsung LCD panel a320ap20s4lv0.4.
                  Could this be fixed by cutting some kind of tracks on PCB that drives the LCD panel?
                  vgh even vgh odd signal from Shift Register
                  and directly connected to panel?
                  Thanks for all the help in advance.
                  panel: LTI320AP01
                  panel PCB a320ap20s4lv0.4
                  main board: 090-6M1814-03
                  • Falki
                    Colorful LCD Vertical Lines on Samsung ue55es8090
                    by Falki
                    Hello there, ive recently found an older 55inch Samsung SmartTV.
                    A similar issue has been posted as well but also with no actual response ...
                    08-12-2025, 04:19 AM
                  • Stanley1843
                    by Stanley1843
                    06-29-2024, 11:54 AM
                  • pni
                    LG 49uf695v vertical coloured lines
                    by pni
                    Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
                    11-14-2025, 03:15 AM
                  • x_orange90_x
                    Samsung UN46C8000XFXZA vertical bars/horizontal lines
                    by x_orange90_x
                    I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
                    The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
                    09-04-2023, 12:09 PM
                  • polaro
                    Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
                    by polaro
                    Greetings,
                    I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
                    08-27-2022, 08:46 AM
