Samsung LE32R88BD/ BN44-00155A
Re: Samsung LE32R88BD/ BN44-00155A
Thanks for the follow-up.Never stop learning
Hi guys,
looking for some advice on fixing my mom's LE32RB86 LCD TV. It powers on, remote, backlight and sound works, but there is no picture just backlighted black, otherwise everything ok.
Unfortunately doesn't seems like standard caps power on problem.
Do you have some experience if it could be some parts, because whole boards seems so rare on that old tv.
Thanks for advice.Comment
Another very common problem with this board apart from the conductive glue is dry joints on the transistor just above where the mains enters the board, you need to re solder this item every time one of these sets comes in for repair as it can lead to intermittent faults.Comment
Hi guys,
Thanks for advice.Never stop learning
You should have 12 volts on the T con fuse, if you trace the power to the main board it usually comes from a switching transistor or FET whch is either faulty or for some reason has a low input, another thing you could try is disconect the T con board and see if the rail rises up just in case a short on the T con is pulling the rail down.Comment
Can I see the pictures of these two fuses?Never stop learning
Those two are NOT fuses, they are Ferrite inductors.
What is the LCD panel model number as printed on the sticker?Never stop learning
Please up load pictures of the whole backside of the TV so we can clearly see all the boards and also the pictures of the T-CON board.Never stop learning
OK, your T-CON board runs on 5VDC so you do have DCV to the T-CON, so you need to find out if you do have 5VDC at both ends of the SMD fuse on the T-CON or not.Attached FilesNever stop learning
