Samsung LE32R88BD/ BN44-00155A
  • DaTT
    • Jul 2015
    • 12
    • Czech Republic
    #161
    Re: Samsung LE32R88BD/ BN44-00155A
    Hello. Please have a scheme to BN41-00813B? My TV still does not work properly. When cool the TV, the start takes a few minutes. I think that the main board defective (BN41-00813B). Can someone help me? Thank you.
    • Thermaltake
      Brain badcap
      • Aug 2015
      • 336
      • D12
      #162
      I found on aliexpress seller and I bought from him I had to buy 6 piece minimum. Now 2 weeks of waiting for them to come and after that I hope when friend & I solder all capacitors that are dead, that tv will be working again.
      • Agent24
        I see dead caps
        • Oct 2007
        • 5093
        • New Zealand
        #163
        Originally posted by DaTT
        I suppose something cold start drawing too much current. Can be a problem on the main TV card? Referring to the temperature dependence of the cold start I would have guessed for a capacitor. I have a good idea? Or is it stupidity? DaTT.
        It does seem like you have a heat sensitive fault on the mainboard. From what I see on the forum, a bad capacitor may be the cause. It may even be a surface-mount polymer or such capacitor too.
        Can you selectively heat or cool parts on the board? Do you have freezer spray?
        Check the earlier pages of this thread for some schematics.
        -David VanHorn
        • Thermaltake
          Brain badcap
          • Aug 2015
          • 336
          • D12
          #164
          Is it worth changing thermal paste under that mosfet chips with heatsink if supply is like 7+ years old or I should just leave it like it is ? Those that I will change of course I will put new one, but I was wondering if I should replace paste on all others that have heatsink.
          • Agent24
            I see dead caps
            • Oct 2007
            • 5093
            • New Zealand
            #165
            Over time the paste can dry out or degrade - how long this takes I'm not sure. If it doesn't look or feel like paste anymore, seems dry\crumbly etc... definitely replace it.
            Make sure you use the same amount they have used already, too little (or even too much) can cause problems.
            -David VanHorn
            • Thermaltake
              Brain badcap
              • Aug 2015
              • 336
              • D12
              #166
              Any paste is good or ? I have MX-4 for PCs, laptops, GPUs that I put, she is very good and very nice temps I got with her, one of the best in my opinion. I think it's like on CPU not too much but not too many I assume. I saw that they have some kind of thermal track on heatsink so I guess it needs to be spread on chip and not like CPU when you put dot and he spread thermal paste on it's own.
              On this video
              https://youtu.be/02Re-UmG9Gc?t=5m22s
              guy puts a bit too much I think or not ?
              • Agent24
                I see dead caps
                • Oct 2007
                • 5093
                • New Zealand
                #167
                CPU paste should work great but might be a bit of a waste as it is probably overkill, CPU and GPU has to dissipate more heat I expect.
                Just make sure if anything was insulated before with washers that you keep it insulated, note that some CPU paste is conductive.
                -David VanHorn
                • Thermaltake
                  Brain badcap
                  • Aug 2015
                  • 336
                  • D12
                  #168
                  MX-4 is non-conductive and non-capacitive, then MX-4 will do the work.
                  • Thermaltake
                    Brain badcap
                    • Aug 2015
                    • 336
                    • D12
                    #169
                    Success, Tv is working again! I am extra happy right now.
                    We replaced:
                    - RM801
                    - CM810
                    - QM801 (we didn't find 500V 9A so we put a bit stronger one 600V 9A)
                    - QM802 (we didn't find 500V 9A so we put a bit stronger one 600V 9A)
                    - CM808
                    - Glue removed (picture down is before replacements)
                    Total cost around 8-10$
                    Pics:
                    what we replaced:
                    Working TV:
                    Thank you so much guys for your suggestions and help, appreciate it.
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 5093
                      • New Zealand
                      #170
                      Nice
                      -David VanHorn
                      • Thermaltake
                        Brain badcap
                        • Aug 2015
                        • 336
                        • D12
                        #171
                        Very cheap fix, it was that or new supply, and new supply on this old tv is not a cheap investment.
                        Now I gain some new experience, if anything similar came in the future I will know where to start. Hope I helped with this description up if anyone else is having similar troubles with their supply.
                        P.S
                        I put MX-2 thermal paste (I use MX-4 also) on both mosfets, I used dot method like on PC CPU in the middle of the chip and tight the screw to heat sink.
                        • dsc
                          • Aug 2015
                          • 53
                          Hello everyone.
                          I've been woking on yet another BN44-00155A board for a LN T3253H. It had the slow blinking light with alternating blue ambient.
                          It had only one bad cap (all the others tested OK) but I replaced all of the caps as I had a kit on hand.
                          Next I found the RM801 had blown so I replaced it, only thing I had was a 22ohm 2W flame proof instead of the 1W fused.
                          I removed all of the glue as standard practice thanks to this thread. None of it seemed to be giving a problem.
                          Again because of this thread I replaced CM810, QM801, QM802 and CM808.
                          The set has come back to life however after a few minuets I smelt something overheating and found the higher watt RM801 was glowing red.
                          The million dollar question now is where do I look next?
                            You put in the wrong resistor (see diagram in the earlier thread), RM801 it should be 0.22 Ohms Fusible resistor, not 22 Ohms, that is why it burnt up.
                            • dsc
                              • Aug 2015
                              • 53
                              Ah bugger, I'll go bury my head now, totally missed the decimal point there.
                              How are you doing budm?
                              • dsc
                                • Aug 2015
                                • 53
                                The correct fusible resistors arrived yesterday. Popped it in last night and all is right as rain.
                                Thank you again budm and everyone else that contributed to this thread, nice top have two of these back in working order.
                                DSC
                                • coolizard
                                  • Nov 2015
                                  • 14
                                  • Czech Republic
                                  #176
                                  I have samsung LE32A336. I am sure that a repaired whole PSU, because I tested all voltages on their nominal current. Everything's fine, until I connect main board, then StandBy supply (5.2V) started oscillation between 5,2V and 0, I think, it is because on the mother board is shortcut, but I cannot found him. I changed all elites, but does not help. I am thinking about corrupted EEPROM, but it cannot shortcut supply, am I right? BTW, when I connect resistor between StB supply and ON/OFF pin on PSU, TV works fine, but it is not good way ). Any suggestion please?
                                  • coolizard
                                    • Nov 2015
                                    • 14
                                    • Czech Republic
                                    #177
                                    Or schematic will be very usefull if somebody has please?
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 5093
                                      • New Zealand
                                      #178
                                      Your TV is a different model to the one posted here. Please start your own thread, post photos if you can. People are more likely to be able to help you then
                                      -David VanHorn
                                      • coolizard
                                        • Nov 2015
                                        • 14
                                        • Czech Republic
                                        #179
                                        Sorry about that, I started here, because PSU is similar. I will start new one.
                                        • geoargi1970
                                          • Jan 2016
                                          • greece
                                          #180
                                          We replaced:
                                          - RM801
                                          - CM810
                                          - CM808
                                          Pics:
                                          what we replaced:
                                          Working TV:
                                          Good morning to all and happy new year. Happy new year to you Thermaltake.
                                          I would like to ask you about the supplier of the components.
                                          I have the same problem.
                                          Thank you in advanced
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
