42PFL3704D/F7 No picture
  • fellim
    • Mar 2011
    • 36
    Hey Guys,
    You very helpful badcap members previously helped me repair a power supply issue by replacing 3 caps in a 42" Philips, thank you very much!
    I got my hands on a newer LCD (42PFL3704D/F7) that turns on and stays on, has audio, but no picture. I can see the light in the back turn on and the screen is illuminated but black.
    Any idea where i can start on this? Thank you for any feedback in advance!
  • retiredcaps
    • Apr 2010
    • 9271
    Re: 42PFL3704D/F7 No picture
    Originally posted by fellim
    Here are some pictures i took of the 2 boards on the back: http://imgur.com/a/ZFpKc
    For many reasons which I won't go into, we want the pictures uploaded to this forum using the "manage attachments" and not offsite. Pictures should be no bigger than 2000x2000 resolution. Also, please do not post inline.
    --- begin sig file ---
    --- end sig file ---
    • fellim
      • Mar 2011
      • 36
      Edit made, sorry about that.
        The power supply is probably okay, but just to rule it out have you checked the output voltages on it?
        Also that power supply is disappointing to see in a Philips, full of cheap caps and the design doesn't seem well thought out.
        • fellim
          • Mar 2011
          • 36
          Sorry, i don't have an multimeter to test voltages with at the moment. If you had to guess would it be the T-Con or Inverter board?
          • cashkennedy
            • Aug 2011
            • 668
            The inverters control the backlight. So if your seeing the screen's backlight clearly turn on, and the screen seems evenly lit up then the inverters seem to be working.
            Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
              Only T-Con, Main or power supply (rarely) could cause these symptoms. To test them, you *will* need a multimeter, even if it's a cheapo £5 (digital) one.
              • fellim
                • Mar 2011
                • 36
                Well i feel dumb... received new t-con in the mail via shopjimmy.com, knowing it was the wrong board i tried to plug it in to see if maybe it could work. Nope. Now i think i shorted a fuse because i get no power. Plug it in and no light.
                • fellim
                  • Mar 2011
                  • 36
                  Any ideas what could be happening?
                  • rayrod81
                    • Oct 2010
                    • 205
                    You will have to buy a multimeter to check voltages and fuses. There is no other way to know what is wrong. Does it do the same thing without the new T-con plugged in?
                      Buy one: http://www.ebay.com/itm/New-LCD-Digi...item2564eadf33
                      This will be fine for basic testing. It's nothing special, but you will need it for any repair.
                      • fellim
                        • Mar 2011
                        • 36
                        Finally got my hands on a multimeter. Where should i begin testing? I was wrong about the backlight, it doesn't turn on. A new one was only $40 on ShopJimmy.com so i swapped it out but no luck. The white power light comes on, i hear a zap noise when i turn the tv on and off (stays on), but black screen. I can hear sound and flip through the channels. Thanks for sticking with me on this guys, i should have got the multimeter sooner
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          Originally posted by tom66
                          See my own personal experience with the dmm you linked above at
                          https://www.badcaps.net/forum/showpo...4&postcount=25
                          I now have 2 Flukes and 1 Amprobe. I got an used Fluke 75 for $20 CDN locally.
                          • fellim
                            • Mar 2011
                            • 36
                            I ended up getting a Equus 3320 Innova Auto Ranging Digital Multimeter from Wal-Mart.
                            I now have an illuminated backlight but still no picture. Here is a video: http://www.youtube.com/watch?v=nZGcwsMzTpo
                            In the video i press the menu button but nothing shows on the screen.
                            • fellim
                              • Mar 2011
                              • 36
                              How can i test the T-Con? Multimeter newb here...
                              • Dgtech
                                E. Technician
                                • Apr 2009
                                • 1462
                                • Steeler
                                Have you checked the inverter boards?
                                Pictures of these also would help.
                                • fellim
                                  • Mar 2011
                                  • 36
                                  Pictures of inverter are posted above in the OP. How do i go about testing the T-Con board? That is my main culprit since i have swapped the inverter, main, and backlight with no luck (i plan to return these).
                                  What is followed by the t-con board?
                                  • fellim
                                    • Mar 2011
                                    • 36
                                    T-Con
                                    • Dgtech
                                      E. Technician
                                      • Apr 2009
                                      • 1462
                                      • Steeler
                                      Do a search in ebay for (42PFL3704D). This search will lead you to what the inverter board looks like. It's green. Sometimes it's under a heatsink or something.
                                      • fellim
                                        • Mar 2011
                                        • 36
                                        I have already replaced the backlight inverter with no luck. I thought you meant inverter power board which is pictured above.
                                        • Tr0ll
                                          by Tr0ll
                                          Original T-con:
                                          First replacement T-con:
                                          10-07-2023, 07:48 PM
                                        • JJAAMM
                                          by JJAAMM
                                          Problem
                                          07-06-2023, 06:01 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • CyberPhoenix
                                          Issue with picture quality of Sony bravia TV
                                          by CyberPhoenix
                                          Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                                          01-22-2024, 02:08 AM
