42" lg plasma dead or is it?
  • hairdye
    • Jun 2011
    • 13
    Hi
    I am no electrician and i need someones help please. I have an Lg 42 inch plasma that will not power up at all, no lights nothing.
    I have taken the back off and on the power supply board there are at least 2 blown caps ( split on top slightly) and two with bulging tops.
    I tried to follow where the board was live with a test pen nearly half of the board is live then it goes dead where one of the capasitors is located.
    Would blown caps stop the tv showing any sign of life at all when plugged in?
    I am going to go out and buy some replacements but do you guys think this is all it could be?
    cheers
    would a photo be better to look at to show the dead caps
  • seanc
    • Nov 2008
    • 1319
    Re: 42" lg plasma dead or is it?
    Yes they would stop it powering up.
    Please post high quality photos, no larger than 2000x2000px attached to the forum.
    Don't buy capacitors from the shops, they will more than likely not be of the correct specification.
    • hairdye
      • Jun 2011
      • 13
      Thanks for the reply i will take a pic and upload it.......
      cheers
      • hairdye
        • Jun 2011
        • 13
        Please bare with me while i explain the picture.
        The area outlined in blue has power showing with a test pen ,
        there is then a damaged cap just below where i have lined in red, there is now power any where else on the board. there is also 3 other caps that are perished again lined in red.
        Would these stop the tv showing any signs of life , no lights sound, nothing.
        I have spoke to maplins and told them the value of the 3 caps on the left 10v 3300uf they said they have 35v 2200uf and these would do!!!
        Please help me, would these caps stop all power to the tv
        and will the caps they suggest do
        many thanks
        • tmcw
          • Oct 2010
          • 382
          • Ireland
          I think you'll have to replace any obviously blown caps, and maybe if there are others of a similar capacitance and brand, replace them too, as they're likely to go the same way.
          I've always been told that you should use the same capacitance (unless it's been shown that the original design was lacking), but can go up in voltage, when replacing faulty caps. An expert will probably be along to verify or correct me.
          • OldMan
            • Jun 2011
            • 47
            I agree with tmcw. You'll need to replace at least the bulging ones...and it wouldn't hurt to spend an extra $5 to replace them all in that series. When I replace caps I always buy same capacitance (essential) but up the voltage by one level. Example - remove a 3300uF 10v and replace with 3300uF 16v. You definitely do not want to replace with a shop cap unless its rated up to 105C and has identical capacitance.
            As far as replacing you'll find an infinite number of tutorials on the net. I always purchase my caps from DigiKey (www.digikey.com) and have found the Panasonic FM series radial lead aluminum electrolytic caps to be the best value. Ships next day from order and arrives in 2 business days with USPS mail.
            Let us know how your repair goes.
            • rayrod81
              • Oct 2010
              • 205
              It is probably best to replace the capacitors with ones of the same capacitance. Voltage tolerance is pretty tight on some of these low voltage lines and replacing with caps that have a different rating might not work. Also you will need low esr caps. Panasonic FR/FM/FC caps would be suitable replacements. General purpose caps won't work very long if at all.
              • hairdye
                • Jun 2011
                • 13
                was i right in thinking that once these are replaced i should have power all across the board?
                Im in the uk does anyone know where i can buy these caps from i would like to do the job asap ..........anyone open on a sunday?
                cheers
                • hairdye
                  • Jun 2011
                  • 13
                  Forgot to ask.......... where i drew the line around my board in the image, would that be normal for the power to end there if the caps had blown as illustrated, (just for piece if mind)
                  many thanks again for all your replies
                  cheers
                  • PlainBill
                    • Feb 2009
                    • 7034
                    cheers
                    Tutorial time here. This power supply is a fairly complex supply, with one standby (always on) power supply and three main supplies that power up in a specific sequence within a limited time interval. In addition, there is a PFC front end to contend with.
                    Notice there are four transformers arranged in a (more or less) straight line. The small one toward the bottom of the picture is for the standby supply. The caps you have tagged would affect both the standby supply and the low voltage main supplies. It is unrealistic to believe the TV would work properly until they were replaced - indeed, it is unlikely it would even try to turn on.
                    PlainBill
                    • seanc
                      • Nov 2008
                      • 1319
                      As for Maplin - they won't sell you quality 105˚C low ESR capacitors. The last ones I got were Jamicon 85˚C.
                      Buy from RS Components UK site and be patient. They have the cheapest shipping.
                      • hairdye
                        • Jun 2011
                        • 13
                        Thank you very much everyone it has made this problem a lot clearer.
                        I will order the caps and once installed i will report back with what happens once installed.
                        Once again thank you very much for your time and effort .
                        cheers
                        • hairdye
                          • Jun 2011
                          • 13
                          Didnt take long before i came back is is this sort of cap that i need....Al Electrolytic Cap 105C 10V 3300uF or FC radial elec cap, 3300uF 10V............
                          i dont know what the difference is.
                          cheers
                          • seanc
                            • Nov 2008
                            • 1319
                            Need a part number for the first one, the second is Panasonic FC.
                            FC is fine as long as it fits.
                            • hairdye
                              • Jun 2011
                              • 13
                              EEUFM1A332 this is the part number for the first one........... what did you mean by if it fits?
                              cheers
                              • seanc
                                • Nov 2008
                                • 1319
                                Check the dimensions of new vs old.
                                That cap is a Panasonic FM - also suitable if it will physically fit.
                                • hairdye
                                  • Jun 2011
                                  • 13
                                  I would like to thank you all for your help and the time taken to answer my posts.
                                  I bought the new caps and my plasma is now working.
                                  To say i had the tv given not working (they were throwing it out) it has only cost me £2.96 to repair and the picture is fantastic.
                                  After i found this forum and then repaired my own Tv i thought about my mothers tv that packed up. She let the repair man keep it as he said it would cost the earth to repair, now i think maybe not.
                                  Anyway once again thanks and i know where to come when i drop on anther tv.
                                  Regards
                                  Wayne
                                  • PlainBill
                                    • Feb 2009
                                    • 7034
                                    Regards
                                    Wayne
                                    Way to go!!! Congratulations.
                                    One of the grim realities of the repair business is that the shop must make enough money to pay the employees, the rent, the utilities, and all the other expenses. This means that it will cost a MINIMUM of $100 for a repair as simple as opening up a flat panel TV and replacing a capacitor. What is worse, if the capacitor didn't fix it, they could easily spend several hours identifying the actual failure and repairing it. As a result, often a $150 power supply is installed rather than a $2.00 capacitor.
                                    PlainBill
                                    • cadillacman
                                      • Feb 2011
                                      • 524
                                      Regards
                                      Wayne
                                      Congrats!!
                                      Just keep in mind there are alot of other failures that can keep a set from powering up or working peoperly. You are one of the lucky ones heh. My first repair was also bad caps. If your looking for sets to fix and resell, look for ones that do not power on or power on and off, etc.. thats usually signs of bad caps or cold solder joints, both of which are easy to fix.
                                      • zunasthegreat
                                        Dead corsair VS450 with blown TNY chip (cwt)
                                        by zunasthegreat
                                        I have this Corsair VS450 PSU which lies dead and has an exploded TNY chip. Upon removing primary side parts like mosfets, the bulk cap and the bridge rectifier I've found that the primary cap is also a goner. (Photos)
                                        The mosfets and the diode are fine and survived the collapse it seems. The TNY chip is shattered and from the online review/sources it was probably a TNY176~177....
                                        08-30-2025, 03:11 AM
                                      • dellxps15
                                        macbook a1707 15 inch trackpad dead. blown fuse identification
                                        by dellxps15
                                        hi all, got this macbook with dead trackpad. after some investigation i found that fuse is bwlown. it's marked with a K on it. anyone kjnow it's value ? it is a 0402 package.
                                        another problem is: i tried another trackpad that was working fine, but the feedback sensor was not. all volts are present, but the click mechanism isnt .
                                        04-30-2024, 10:48 AM
                                      • Super360
                                        Samsung PLASMA PN50B530S2F DEAD
                                        by Super360
                                        Hi everyone I have this plasma here that has no standby light and is completely dead. I opened it up to see extremely dirty and dusty to which I cleaned but made no difference. So I checked all fuses good. I checked the standby voltage 5 volts good. Then I did that plasma control board test by shorting the pins(THANKS 2 TVTIMMY) and the tv actually turned on and made a sound. Does this mean I need a new motherboard?...
                                        12-16-2021, 09:25 PM
                                      • cmlewis89
                                        LG 47LB5DF blown power supply board
                                        by cmlewis89
                                        Hi folks,
                                        I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                                        09-03-2024, 07:50 PM
                                      • bobby4star
                                        BN44-00517C dead - blown cap, resistor and fuse
                                        by bobby4star
                                        Hi All,
                                        I have a UE32ES6540 which is dead, customer reported a pop and a puff of smoke. PSU is BN44-00517C and has blown 221k 1KV cap, next to this a blown resistor RM811. Board mains fuse is blown.
                                        Has anyone seen this problem and will changing the cap, resistor and fuse likely fix it? One more ask, can anyone give me a 2nd opinion of this resistor rating of RM811? I think it's 0.24 Ohms but would like a 2nd opinion! See attached pic.
                                        Thanks!
                                        Bob...
                                        11-12-2020, 12:46 AM
