Dead corsair VS450 with blown TNY chip (cwt)
  • zunasthegreat
    • Dec 2017
    • 92
    • EU
    I have this Corsair VS450 PSU which lies dead and has an exploded TNY chip. Upon removing primary side parts like mosfets, the bulk cap and the bridge rectifier I've found that the primary cap is also a goner. (Photos)
    The mosfets and the diode are fine and survived the collapse it seems. The TNY chip is shattered and from the online review/sources it was probably a TNY176~177.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8339
    Very typical failure.
    • zunasthegreat
      • Dec 2017
      • 92
      • EU
      Around the TNY chip there are 4 caps, 2X 220uF 35V and 2X 10uF 50V. All junk JUN-FU WG showing horrible reading. I replaced the 220uF ones with ZLH 220uF 35V and the 10uF ones with Nichicon SV 10uF 35V. Changed all the secondary ones too from Capxon/Aishi/JunFu into ->
      3.3V - 2X KY 2200uF 10V
      5V - KY 2200 10V + KY 1000uF 16V
      12V - 2X Rubycon ZLH 1800uF 16V (*no space for more than 10mm. Old were Capxon KF 2200uF 16V)
      -12 - Rubycon ZLH 330uF 16V (who uses 1000uF caps here?)
      5VSB - Nichicon HV 1500uF 16V + Nichicon PW 1000uF 10V
      PG Cap near sitronix chip - Nichicon PW 1000uF 10V here
      For the TNY chip I've placed a socket which I don't know if its a good idea cause the IC seems to need the pcb for heat dissipation. The new chip is a TNY178 and I've added a small heatsink on top. For bridge rectifier I used the PBU805 and I also changed the mosfets. The PFC one is a K3568 and the main switchers are now 2X K3569 which I had in stock. These are small updates 8A->10A (main) 10A->12A (PFC).
      Well the psu *works*!!! even with that 100uF 400V cap! New cap will arrive soon and I'll do more testing. No room for more than 25mm diamater for the primary cap.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8339
        I see you done a full blown upgrade. What did you order to replace the main filter cap with?
        • zunasthegreat
          • Dec 2017
          • 92
          • EU
          The only one I found in stock at 25mm and within budget was a United-Chemi-Con KMM 450V 220uF 105 C.
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8339
            Ahh,… well at least they are 120hz rated and not 100.
            • zunasthegreat
              • Dec 2017
              • 92
              • EU
              Changed the last caps near Optocouplers 2x 2.2uF 50V to 3.3uF KYA 50V and lastly the primary cap. Only thing that bothers me is the TNY178 mod I did which has socket now and a small heatsink.
              Photo with Finished looks, hope it will last.
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8339
                Yeah… putting a socket on a HV chip isn’t such a good idea. But then these TNY, LNK, TOP, etc devices like this die like flies anyway. As long as things are hospital grade clean around that chip after replacing, you should be fine until the dust builds up between the pins. Had seen a replacement fail within 24 hours, only because he didn’t clean good enough after the first repair. I did the second repair and all is well.
                  • 31246
                  put rtv on the pins?
                  • zunasthegreat
                    • Dec 2017
                    • 92
                    • EU
                    Someone suggested a big copper wire like ~3mm thick across source pins to unleash the heat and still keep the socket for future repairs. From the testings I've done so far I see like 37~40C @ 27 C room temp. PC is a haswell 4C and GPU a R9-270.
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 5059
                      • New Zealand
                      Nice job, although I don't think it's a good idea to socket the chip...
                      At least use a machined pin IC socket, not one of those spring-contact ones.
                      Or just solder it in directly, for the best connection and reliability.
                      -David VanHorn
                      • acedogblast
                        by acedogblast
                        11-02-2024, 05:13 PM
                      • double_DD
                        How can I be sure that my EC chip is dead?
                        by double_DD
                        As the title suggests, how can I be sure that my EC chip is really dead?
                        I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                        Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                        03-12-2025, 07:47 AM
                      • DynaxSC
                        ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                        by DynaxSC
                        Hi
                        I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                        08-04-2025, 12:20 PM
                        Common SPI bios chip programming Questions and Answers
                        by SMDFlea
                        Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
                        A: If you can`t read from it how do you expect to write to it ?.
                        Q: Why is my bios chip unreadable ?.
                        A: The programmer is faulty or has a worn or broken zif socket.
                        The USB cable is frayed,connector pins worn or some other physical damage.
                        Not enough amperage or voltage to power the programmer properly.
                        Bad...
                        09-02-2021, 04:40 PM
                      • iyas132
                        Corsair RM 750 blown schottky diode near ES1DF
                        by iyas132
                        Hi there, i am currently diagnosing my corsair rm750 that wont turn on, after a power trip.
                        Before the power trip, previously i need to push power button on my pc case quite a bit in order to turn the pc (and power supply on), however after the power trip now i cannot turn the pc on at all and i opened the power supply, and found out some of the component(s) are blown. (picture attached)
                        My current diagnostic is that the (schottky) diode marked "SF" in the 5Vsb circuit are blown and possibly the ES1DF diode too.
                        Can anyone help me identify the component...
                        12-30-2024, 01:34 AM
