Polaroid TLA-04011c Red Light on, no power on
  • ryn0909
    Professor X
    • 122
    Re: Polaroid TLA-04011c Red Light on, no power on
    no sorry, i got rid of that tv years ago. i was actually trying to fix it for a friend, but to no avail.
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
    • ipatch
      troubleshooting microsoft surface pro 4 no power no led charge light
      by ipatch
      hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
      10-05-2023, 11:59 AM
    • russpall
      LG 39ln540v - red light flashes twice, no power to LED driver?
      by russpall
      Hi there,
      I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
      The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
      08-27-2024, 01:07 PM
      by sam_sam_sam
      03-31-2024, 02:12 PM
      Laptop computer that went completely dead no boot no power light no hard drive light
      by sam_sam_sam
      See pictures for type of laptop computer
      I checked switching power supply brick 19.2 volts multi meter only
      No booting without switching power supply connected
      Checked switching power supply with an (28 volt ) incandescent light bulb it lights then hooked up the switching power supply again now the laptop and boots like normal
      What the heck is going on here...
      04-04-2025, 04:58 AM
