Vizio VX32L turns on with backlight, no video or sound
  • Ayelix
    • Mar 2011
    • 10
    I have the same problem as described in the thread here. My Vizio VX32L turns on with the power button, the light changes from amber to white and the backlight comes on, but there is no sound or video (only black screen). I have read the thread linked above and followed the troubleshooting for DC-DC converters in the VW32L manual (here) with no success. The VW32L manual is the most similar to the VX32L that I could find, in fact I found no differences in component names or values while troubleshooting. I have tested all of the components recommended in the manual and all seem to be working fine. Any recommendations of what I should try next?
  • cadiman
    • Mar 2010
    • 397
    Re: Vizio VX32L turns on with backlight, no video or sound
    The problem is not the power supply with these. The problem is on the mainboard.
    Look at U-9 (amc1117) 3.3v It will be low(2.2)or so. This is the same on vx32 and 37.
    The tv will turn on the backlight, but nothing else.
    Also you can use the vx32 mainboard on the vx37 tv. That was how I found the problem and reading posts here always helps too.
    • Ayelix
      • Mar 2011
      • 10
      When I said I followed the troubleshooting for the DC-DC converters, I meant those on the mainboard. I also read to check U9 in another thread and it is at 3.3V.
      • 1simtime
        • Feb 2011
        • 30
        Also working on VX32L same symptoms. I noticed at power up the blue led on inverter board has short delay then turns on, off, on ,then fades off slowly.Once the led turns on, both inverter boards make buzzing sounds, loud enough to hear ,but hard to tell where it was coming from. Have not checked anything on these boards yet.
        I also checked voltages on LDO reg. I have 2 readings because the voltage changed from power up(1st reading) to when the inverter led came on(2nd reading).
        LDO ... V in (1-3) ... V out (1-2) ... (2-3)
        U33 ... 3.15/3.85 ... .84/.18 ... 2.88/3.01
        U9 ... 2.03/1.89 ... 1.02/.83 ... 1.04/1.06
        U7 ... 2.23/2.05 ... 1.16/.99 ... 1.04/1.05
        U8,U2,U4 .. 3.08 ... . 1.24 ... .. 1.84
        Mainboard 3632-0102-0150(4B) LDO reg all above marked AMC1117 F0646J
        Also U10 measured 3.01
        That is as far as I am. I had to come in and warm up, it's 18 degrees in my garage.
        • cadiman
          • Mar 2010
          • 397
          When the inverter board first powers up you will see the blue led light and then it will go out this is normal. should not go off and on then off
          You will hear them buzz a bit like a shop light ballast. If they are really loud the ccfls are going bad.
          Make sure you have the 5v standby from power supply. There are 2 small fuses soldered to the board near the power supply plug at the main board. Check these with your meter. I think one is the 5v standby and the other is the 12v after the supply is turned on.
          If you really get into this thing I can take the cover off of mine and get voltages for you.
          When the power button is pushed and the backlights are on you should have 12v going to the main board.(check U-3) it`s in front of the audio output IC and just under the part number. That might be the regulator of some sort should be 12v there.
          good luck!
          • Ayelix
            • Mar 2011
            • 10
            I have checked all of my DC-DC converter voltages and the power supply input on the main board. I can check them all again and record my readings to compare to someone else's readings if that would help me or 1simtime.
            • 1simtime
              • Feb 2011
              • 30
              Both fuses on main and each fuse on inverter boards are good .
              At the P.S. is 5.18v standby. powered up 5.18v , 12.00v, 24.2v and 24.2v.
              U3 (7805ct) tab(gnd) to pin 1(in) is 11.9v and tab to pin 2(out) is 5.0v.
              All caps on p.s. mainboard and both inverter boards appear good .I do not have an esr meter but I would like to get one.
              From another vizio post I got a Digi- Key # 497-1229-1-nd for the amc1117 F0646J . The voltages I showed on my last post for U33,U9and U7 do not appear to be normal . Anything else to check before I order? Thanks
              • cadiman
                • Mar 2010
                • 397
                I have the cover off and I have a list of v-in and v-out for amc1117.
                u33 5v in 3.2 out
                u2 5v in 3.2 out
                u4 5v in 3.2 out
                u8 5v in 3.2 out
                u7 3.2v in 1.25 out
                u9 3.2v in 1.50 out
                u8 has 5v in 3.2v out at all times
                also check for 4 or 5v at small transisters at button control plug-in at upper left of board. (when button pushed).
                • 1simtime
                  • Feb 2011
                  • 30
                  You guys on this site are the best ! Willing to take your TV apart to get voltage readings to help out. Thanks cadiman !!!
                  I didn't get the same readings as you. I used pins 1-3 for in ..1-2 for out..2-3? This was how some one from another Vizio post got their readings.(pasted below)
                  I understand the mainboard is from a different model so the voltages I got may not be the same .
                  kingofcoins's
                  Default Re: Vizio VW42LFHDTV10...Brother Mikes TV...mainboard woes
                  I'm still a bit over my head on this, so when you get a chance...
                  New point... does the fact I get no backlight action at all mean I need to address
                  it separately, or is it likely the mainboard trouble keeping them off?
                  I not sure I took enough info on the last post so here is all the LDO regulator readings
                  for Vin (1-3) and Vout (1-2) and pin 2 ? (2-3):
                  U2.... 3.0VDC 1.2V 1.8V
                  U7.... 3.4 1.1 2.25
                  U8.... 3.1 1.2 1.85
                  U9.... 3.3 1.5 1.75
                  U33... 3.0 1.2 1.8
                  4 of these are AMC1117 F0646J U9 is a K1117S15 612
                  cadiman ..What did you use for gnd and pins for in and out so I can compare my readings? THANKS
                  • cadiman
                    • Mar 2010
                    • 397
                    U9 can be replaced with an amc1117. All of these are the same on the vx 32 board.
                    The vx37 had a k1117s15 same as the amc1117 I think the 1117 is the clue here.
                    You can use tv frame on this one (what the board is screwed to).
                    As you look at the amc1117 (the rca plugs, audio and video inputs facing you) the upper pin is v in, the middle pin is v out and the lower pin is adj. or possibly ground. these are soldered at the top of the ic depending on how you are looking at it.
                    In your case the top is on your left and the 3 pins are on the right.
                    The top is also center pin or v out. check here so you don`t short the output to the input.
                    You should have 5v going into all of these except for u7 and u9.
                    u8 should have 5v in and 3.2 out all the time. I think you should check here first with tv plugged in and tv turned off
                    • 1simtime
                      • Feb 2011
                      • 30
                      Using board gnd instead of pin 1 made the difference.(post#4 used pin1 for gnd and post #9 measurements were from a post with a different model # I used as reference.
                      here is what I got using board gnd
                      LDO...pin 3........pin 2....
                      U33... 5.13v in . 2.05v out
                      U7.... 2.05v in . 1.00v out
                      U9.... 2.05v in . 1.0ov out
                      These 3 look low compared to your readings
                      U2,U4,U8 appear normal with 5v in and 3.2v out
                      U8 had 5v in and 3.2v out with tv off
                      • Ayelix
                        • Mar 2011
                        • 10
                        1simtime, according to cadiman and the vw32l service manual, U33 is supposed to be at 3.3V and U7 is supposed to be at 1.2V. U9 however is not mentioned in the service manual. It looks like U33 may be the problem as it may be providing the input for U7 and U9 which is supposed to be 3.3V. This is just a guess though. Someone with knowledge of these components could confirm this.
                        • 1simtime
                          • Feb 2011
                          • 30
                          Ayelix, are you getting anywhere with your VX32?
                          • Ayelix
                            • Mar 2011
                            • 10
                            I have not touched it since I made the post. Tomorrow I will take readings of all the DC-DC converters on the board and record my results.
                            • Ayelix
                              • Mar 2011
                              • 10
                              I took all my readings today. It seems that the inputs for almost all the 1117 converters are low, ~3V instead of 5V. I recorded the standby (SB) in and out voltages and the power on (ON) in and out voltages. Pin 1 was used as ground, the larger tab (connected to pin 2) was used for out readings, and pin 3 was used for in readings.
                              Code:
                              Component  SB out  SB in  ON out	ON in
                              U10     0    0    1.25   3.62
                              U7      0    0    1.24   3.29
                              U9      0    0    1.24   3.04
                              U33     0    0    1.24   1.94
                              U8      1.24   3.04   1.24	2.98
                              U2      0.04   0.19   1.25	2.93  *See below
                              U4      0    0    1.24   2.97
                              U3      0         11.93      Using P2 GND, P1 V+
                              U3      0         5.02       Using P2 GND, P3 V+
                              I think these readings are different than what I saw a couple days ago. I think it may be because I was using the board ground (a mounting screw) during my readings instead of pin 1 of each converter.
                              U2 is interesting. It reads very low on standby, but as long as the reset button is held down it goes to ~3V in and ~1.24V out. Once the reset button is released it goes back to the very low input and output. I don't really know what to make of all this!
                              I'm going to go check all of the power connections again and I will edit this post to add those readings.
                              • PlainBill
                                • Feb 2009
                                • 7034
                                Code:
                                U10     0    0    1.25   3.62
                                U7      0    0    1.24   3.29
                                U9      0    0    1.24   3.04
                                U33     0    0    1.24   1.94
                                U4      0    0    1.24   2.97
                                One point to consider, the AMC, AS, LM, etc 1117 regulators come in variable (AS1117) and fixed (AS1117-33; AS1117-25; etc) versions. On a fixed output version, pin 1 is at Gnd. On a variable output version pin 1 is the Adj input, and will be at some voltage above gnd. As you noticed, it is important to choose the Ground point for your measurements carefully.
                                PlainBill
                                • Ayelix
                                  • Mar 2011
                                  • 10
                                  Should I be using the board ground with the adjustable regulators and pin 1 for the fixed regulators? If that is the case then all readings should just be taken using board ground right?
                                  Thanks for the help.
                                  • Ayelix
                                    • Mar 2011
                                    • 10
                                    Here are my readings using the board ground instead of pin 1 of the regulators. Nothing looks wrong here . Also, it all matches the correct values in the DC-DC troubleshooting section of the VW32L service manual.
                                    Code:
                                    U10		0	0	2.62	4.99
                                    U7		0	0	1.24	3.29
                                    U9		0	0	1.49	3.29
                                    U33		0	0	3.3	5
                                    U8		3.3	5	3.3	5.04
                                    U2		0.12	0	3.33	5
                                    U4		0	0	3.28	5
                                    U3 		0		11.93		Pin 1
                                    U3 		0		5.02		Pin 3
                                    U1 		0	?	5	?	Pins 1,3,5,6,7,8
                                    U6 		0	?	1.6	?	Pins 5,6
                                    J1:
                                       Pin 1      PWR ON (about 3.3V? Mine's 1.7V)
                                       Pins 2,3,4,5   12V ON
                                       Pins 6,7,8    GND
                                       Pins 9,10,11   5V SB
                                    F1: 12V ON
                                    F2: 5V SB
                                    • cadiman
                                      • Mar 2010
                                      • 397
                                      I would go after u33 1simtime. my readings are from A GOOD WORKING BOARD ON A WORKING TV THAT I AM WATCHING A MOVIE ON.
                                      1)As long as you get the same readings I have or not it will get you headed in the right direction, if we are lucky.
                                      2)When an amc1117 fails I am pretty sure they go low.
                                      3)Check with Plainbill
                                      • 1simtime
                                        • Feb 2011
                                        • 30
                                        I plan to order from Digi- Key # 497-1229-1-nd for the amc1117 F0646J
                                        I will post back when I get it replaced Thanks
                                        I think Ayelix is still working on fixing a VX32L so I hope we can help !
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
                                        • SS454
                                          vizio e650i-a2 backlight flashes then turns off
                                          by SS454
                                          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                          panel: au optronics T650HVN05.4
                                          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                          https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                          08-20-2020, 03:57 PM
                                        • ggil44
                                          Vizio M65-E0 No Picture, No Sound
                                          by ggil44
                                          Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
                                          09-03-2024, 08:30 PM
                                        • Super360
                                          Vizio E701i-A3 Vizio logo flashing then turns off
                                          by Super360
                                          Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
                                          07-25-2024, 07:06 PM
