VIZIO VO42L No picture, No Sound
  • CrappyCap
    • Jan 2011
    • 8
    Hi Guys,
    So many great knowledgeable folks here. I didn't know this forum exist prior to this week. Thanks you guys for sharing info.
    After reading the forum, I was able to fix a dead Sceptre LCD monitor that has 4 bad cap. The PSU is exactly the same as the one on this thread https://www.badcaps.net/forum/showthread.php?t=9981. Replace 4 caps with some Panasonic cap I have left when I built a DC-DC PSU for my carPC.
    Now come the real problem that I really need help troubleshoot.
    It's a Vizio VO42L bought from Costco. After about 16 months, the main controller board crap out (some input wasn't working). Costco concierge service fixed the problem by replace the main board. And now, this problem come up. It's out of 24 months for Costco Concierge service or VIZIO to fix. AMEX would of cover the 3rd year if I paid for the TV with AMEX card.
    The problem is that, when plug in there is 5VSB (Orange Vizio light up).
    Turn power on by remote or keypad, it takes 2-3 seconds (normally it would take that long too), then vizio logo turn White.
    There is NO visible sight of bad cap nor smell of burn component from PSU, Main board and 2 inverter board. All fuse are fine. Other than a DMM, soldering stuff, I don't have anything else to test. I have a big oscilloscope, but I don't know how to use it nor do I know if it a working scope
    I check for voltage and this is what it read.
    - 5VSB is ok (Orange light and white light).
    - PS_ON is 0V when Off/standby and 2.67V when On (white light) and 0V when turn off (remote or keypad).
    - NO reading on 12V nor 24V when Off or ON (BAD)
    The PSU is almost the same as this one https://www.badcaps.net/forum/attach...8&d=1289868833
    from this thread https://www.badcaps.net/forum/showthread.php?t=12041 Google for PSU part number, the PSU indeed also use in Vizio VX24L
    Inverter board look like this one: https://www.badcaps.net/forum/attach...8&d=1283627061
    from this thread https://www.badcaps.net/forum/showthread.php?t=11007
    I know I should of taking pic of the innards and post before asking question.
    Will do later today.
    I couldn't find a service manual for this VO42L from "the usual place", but I found the manual for Vizio L42HDTV10A/GV42L HDTV model. Quick look thru the manual, there is nothing regarding to PS_ON voltage to turn the PSU on.
    So what is the acceptable voltage on the PS_ON signal to turn on the PSU? I thought it should be ~3.3V, my reading of 2.67V is a little low to turn the PSU on. I'm thinking of using the PC PSU 3.3V line to force the TV PSU to turn on (remove the PS_ON line from the Main board of course) so I can check the 12V and 24V if there is anything coming out of it.
    My other option is to look for the Regulator that produce voltage for PS_ON line on the main board.
    If 2.67V on PS_ON is acceptable to turn on the PSU, then I need to take a look at transformer, regulator, transistor .... on the PSU side that generate 12V and 24V. Basically I'm trying to isolate the source of problem from each sections. Main board first, PSU next, then inverter.
    TV Detail.
    Vizio Model: VO42L FHDTV10A
    Main Board: 3642-0482-0150, 0171-2272-2604
    BL inverter: LG Phillips LC420WU5
    PSU: FSP254-3M01
  • PlainBill
    • Feb 2009
    • 7034
    Re: VIZIO VO42L No picture, No Sound
    The PS_ON voltage is normally about 3 volts. 2.67V is well within the range for 'about 3 volts'.
    There are a limited number of tests that can be done with the equipment you have. I'll try to repeat this later, but remember there are two grounds in the power supply. The HOT ground extends from the bridge rectifier to the SMPS transformer. The cold ground is on the AC input and the DC output. And remember that the main filter cap can have up to 400 volts on it if the power supply has a PFC front end (most do).
    Good pictures of the top and bottom of the power supply are essential. Note the links in my signature for information on what we are looking for.
    PlainBill
    • CrappyCap
      • Jan 2011
      • 8
      Thanks PB.
      I check voltage across the main big cap. 398VDC when ON and about 172VDC when standby.
      Most caps on the inverter are either made by Rubycon or Chemicon (KY). Is that a good thing?
      After taking the pictures, I try to plug all connector back to probe for LDO regulator, I forgot to plug in the 2 connectors for master and slave inverter board. I check 12V and 24V. To my surprise, 12V line read 11.9V and 24V line read 24.5V.
      So the problem is not the PSU. I need to do a load test on the 24V line to confirm that. For now, it's good
      PSU ok, Main board seem ok, next one is the inverter set.
      • CrappyCap
        • Jan 2011
        • 8
        Time to check the inverter set.
        I remember one post (#29) by Dgtech https://www.badcaps.net/forum/showpo...4&postcount=29 regarding checking for 4 mosfet along with the BD9897FS controller.
        Well on the master controller all 4 and 2 on the slave read 8.45Kohm. Those are circle in RED. Within the spec as indicated by Dgtech. the other 2 on the slave card give weird reading. 1.6 ohm and 7.6 Ohm. Those are circle in Yellow.
        Does that mean the controller chip (BD9897FS) is going south or only that 2 mosfet (K4075) are going on honeymoon?
        Look like neither mouser nor digikey has that BD chip on hand.
        Thanks guys.
        • Dgtech
          E. Technician
          • Apr 2009
          • 1462
          • Steeler
          You are correct. This video driver chip is bad. It shorts out internally and gives a lower resistance on one or, in this case, two of it's four outputs. Once the chip is removed, with just the pads showing, you will see that the resistance check you made will go even higher. They should read 10K each. Place the new chip in, about 8.5K.
          The chips I get are from in China. I buy them on Ebay for about $10 each chip. Sometimes you can find a seller here in the US that has a few. If you can find this then it helps cause the shipping from china takes a while.
          I have a few here I bought in anticipation of seeing more of these TV's. I'll have to check my stash before I know if I can give up any. Check ebay first.
          • CrappyCap
            • Jan 2011
            • 8
            I try to remove the BD9897FS chip and end up lifted few traces on the pcb
            Time to order a new set. It's 130 buck from Vizpart listed as upgraded version (6632L-0470N & 6632L-0471N) of the original 6632L-0470A (Master) & 6632L-0471A (Slave).
            After remove the chip, the 2 bad mosfet is still reading bad and 2 good mosfet is ready about 10K. I guess the bad BD chip probably isn't bad, but a bad 2 mosfet instead.
            • CrappyCap
              • Jan 2011
              • 8
              Thanks everyone.
              Just order new inverter kits (6632L-0470A & 6632L-0471A) from fleebay for 120 bucks shipped.
              Let see if that fit the problem. Finger cross and waiting for new part to arrive
              • Dgtech
                E. Technician
                • Apr 2009
                • 1462
                • Steeler
                Sorry to hear about the desoldering mishap.
                Did you buy both master and slave replacement boards?
                I have replaced one without replacing both before.
                • CrappyCap
                  • Jan 2011
                  • 8
                  Well before start de-soldering, I already "knew" that I'm going to screw up that IC. I never deal with MSD before so it a good experiment. Next time I'll just get some of those ChipQuick kits.
                  I just order both master and slave. ShopJimmy want 75 bucks shipped for the slave. Fleebay doesn't have the slave I need, but have a set for 120 shipped. Both place advertised as "brand new". If thing work out and I have extra left. Maybe just keep it for "future need" .
                  I may use the "broken" inverter and jump, modify to make it more "reliable" as posted by Phillips. Just something to experiment on free time.
                  • CrappyCap
                    • Jan 2011
                    • 8
                    New set of inverter came. Replace the inverters and I'm back watching TV
                    Before install the inverter, I did check 8 mosfet and they all read 8.56k Ohm.
                    Also note, new inverter set has same part number but revision 1.3 board whereas the old on was rev 1.2.
                    Thanks everyone for helping trouble shoot the problem and sharing info on fixing those problematic electronic gadgets.
                    • andyak
                      • Feb 2011
                      • 4
                      Hey Guys,
                      New here - good discussions!
                      I have same Vizio - same problem!
                      turns on, goes white - no picture.
                      I have checked out all voltages - ok - replaced power sup fuse - just in case - have good voltages all around and unit responds to remote.
                      Just read this thread and checked for the 8.5k readings - and lo and behold the slave inverter has one slightly low at around 7.3 and another really low - so I guess the chip is bad!
                      I also have ordered new set of inverters for $120 shipped -
                      Q - if they are new revision, should I install the replacement main inverter as well - or can I leave it in and just replace the bad slave?
                      another question - how the heck do you get the FFC - little flat cables safely in and out of inverter sockets?
                      Thanks in advance..
                      Andy
                      • Dgtech
                        E. Technician
                        • Apr 2009
                        • 1462
                        • Steeler
                        I wouldn't worry about the flat cable unless there was some physical damage. You could have just changed the slave board but just in case, keep the master that you take out since it checked good. I have a Philips that I changed the slave board out. It worked fine for about four months and then the Master died for the same chip. I dont think it was a matching problem, I think the chip simply died. I have changed out a number of those chips now.
                        • andyak
                          • Feb 2011
                          • 4
                          Thanks - is there a specific way the little flat cables come in and out of the connector on the board? does the connector open up - I can't seem to get it to open....
                          • Randhj
                            • Feb 2011
                            • 3
                            New here first post. Same vizio vo42l also purchased from costco and died 2 years 8 months after purchase. Costcos concierge wanted 400 to come out and look at it, we got a local repairman to come out for a 100 and he said it was the 2 inverters and wanted another 200 for parts and 100 to install. Im not sure how he checked it, I was not here at the time its my grandparents tv. I would like to know the difficult of installing the two inverters. I have built my own desktops, and have handy man experience but poor soldering skills. If I get the inverters off auction site for 110 (not repair kit) is it just unscrewing the old boards and popping the new one in and clipping in ribbon? I do have a voltmeter as well if that can help me double check his diagnosis easily.
                            • PlainBill
                              • Feb 2009
                              • 7034
                              As I recall, Costco's Concierge service provides a 3 year warranty. If that is correct I would insist that they provide the promised service.
                              The common failure is shorted transistors on the slave inverter. Replacement is a fairly straightforward job, not much more difficult than replacing a motherboard on a PC.
                              PlainBill
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                In Canada, Costco's Concierge service is 2 years. This would explain the service denial if poster is in Canada.
                                --- begin sig file ---
                                --- end sig file ---
                                • vonwiggleding
                                  • Feb 2011
                                  • 9
                                  Almost exact same date as mine went out, I purchased July 22 2008. It was my slave inverter board too, it whined like a stuck pig for 3 months before croaking. Makes me think Vizio knows they're selling garbage.
                                  As Crappy said, I was told by concierge the 3rd year warranty is only added if you bought with AMEX.
                                  • Randhj
                                    • Feb 2011
                                    • 3
                                    Yea, we paid cash so no 3rd year warranty. Im gonna order from vizparts later today. I opened it up yesterday to take a look and it seems very straightforward. Ours was buzzing for a lomg time too, I guess we should have called while under warranty for buzzing.
                                    • PlainBill
                                      • Feb 2009
                                      • 7034
                                      Well, as much as I hate to defend Vizio, the inverters are supplied as part of the LCD panel, and are manufactured by LG Electronics. LG is aware of the problem, and has already issued a modification kit for the inverters.
                                      PlainBill
                                      • CHENG39
                                        • Mar 2011
                                        These experiences are all very similar to mine. About 27 months into ownership and the screen went black with no advance indications. Sound remained. I did the flashlight check and was relieved to see the picture. I ordered new master/slave inverters from vizparts (~$130 for the set) and replaced them. No change. Against my better judgment, I ordered a power supply and replaced it. Again, no change. I searched the web again and found this thread and began resistance checks on the old inverter mosfets. Similar indications on the slave board (one read a short, while the others were in tolerance). Retraced my steps and replaced the original P/S and new inverters. Gave it one more try and I'm back up watching college ball. Not sure what I missed on the first go 'round, but I also wondered some about the flat connectors (whether I was making good contact).
                                        • cheeky2
                                          by cheeky2
                                          05-25-2024, 03:27 AM
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
                                        • gavric
                                          Vizio M70-C3 Half picture is bad, main board on its last leg?
                                          by gavric
                                          Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
                                          When tv powers on vizio V logo shows nice on whole screen. picture 1
                                          When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
                                          When i start youtube picture shows on left side fine, right is all scrambled. pic 2
                                          When i click video to start playing picture goes black(like when you change...
                                          09-02-2021, 08:55 PM
                                        • fharris1977
                                          Vizio D50u-D1 Dead: PSU or Main Board?
                                          by fharris1977
                                          Hi. Anyone who has experience with these vizio sets, which pin on this connector is the standby, the 5V pin? Trying to rule out the PSU before ordering a mainboard. I'm getting 0 Volts on all pins on this connector. Trying to jump the standby and PS ON pins to see if the PSU is functioning. Thanks in advance.
                                          03-12-2024, 12:22 PM
                                        • DXseekerMO
                                          Vizio E55-C2, appears dead, no 20V, main cap always 385V, no PSon
                                          by DXseekerMO
                                          I bought this Vizio E55-C2 yesterday with the complaint of completely dead, will not power on, no initial power light that trails off when plugged in. The complaint is confirmed.
                                          The 120V protection fuse is good. The first thing I checked was main cap voltage, always at 385V. Other voltages found on the power board look like the TV is trying to tell me it's partially on? Here they are:
                                          Main cap…….385v stable
                                          1: 5VSB……….5.05v stable
                                          2: 5VSB……….5.05v stable
                                          3: ACD…………3.3v stable
                                          4: PS_ON…….3.3v stable...
                                          10-14-2018, 02:45 PM
