Sceptre x22wg-Gamer 22" LCD
  • severach
    • Aug 2007
    • 1055
    Panel: AUO M220EW01 V.0 TN Film
    Power Supply: FSP050-2L02 3BS0144112GP REV:1 E116921 K3502 2SK3502 SG6841SZ BI3101A
    Video Board: AL012 REV.1 MTK810NGD MST9251DA-LF-165
    Inverter Transformer: SPI 8TC00291
    Another revision of the FSP050-2L02 uses a set of 4 transformers similar to the SPI 8TT00006.
    Disassembly:
    Do not remove 3 black angle head screws in back near connectors
    Split front with putty knife working from any corner, no force extract LED from front cover
    Panel: 4 gray angle head
    Power Board: 2 gray plastic thread, 2 gray machine thread, 1 gray machine thread to ground lug
    Video Board: 4 gray plastic thread, 4 VGA standoff, 1 gray machine thread at HDMI connector
    Reassembly: Ensure all buttons click. Unfortunately the monitor must be mostly reassembled to test.
    Bulged caps on power supply:
    C551, C552: CapXon 470uf 25v (runs at 5v, good ESR=0.05, bad esr>=1.1)
    Other caps that did not fail yet:
    C664: CapXon 470uf 25v (runs at 12v)
    C554: CapXon 470uf 25v (runs at 5v)
    C1, C661: Taicon 1000uf 16v (runs at 12v)
    C210: CapXon 33uf 35v (runs at 12v)
    The video board has a dark spot near C37. C37 tests good.
    C37: Jackcon 47uf 25v, esr=0.06 in circuit, esr=1.1 out of circuit
    This TN Film panel running on DVI is as clear as my PVA monitors with excellent bleed control.
    One person here on badcaps was able to fix their x22wg-Gamer entirely from the debug menu.
    sig files are for morons
  • ar3ohdee
    • Oct 2010
    • 23
    Re: Sceptre x22wg-Gamer 22" LCD
    Hey,
    Do you know where, or how I would order a new power supply for this monitor... Mine went out, and I don't know what would work in its place, or if I should just scrap it... Picture 4 of 6 is the "EXACT" piece I need to replace....
    • seanc
      • Nov 2008
      • 1319
      Do you have the same symptoms as picture 5?
      If so, now's the time to learn how to repair it!
      • ar3ohdee
        • Oct 2010
        • 23
        I don't think so?? Sorry, but not too sure what I am looking at in #5 (Bad Fuses???)... How would I be able to tell? It just stopped turning on the other day (no anything when pushing the buttons), From what I do know (very little, lol), it seems to ONLY be the power... SO, I figured if I replaced the whole piece (#4) it would work again... BUT, I am ALL ears/eyes, and would LOVE to know how to "fix" it, especially because I HATE throwing things out, AND Buying new ones... I can take a couple pictures of P.S. if that would help Identify any possible problems... Let me know, and Thanks for the help...
        -R
        • seanc
          • Nov 2008
          • 1319
          Yes, please take clear photos of your power board.
          If you look at picture 5 in the original set of pictures, you can see that 2 of the capacitors (tall cans with X on the top) have bulging tops.
          These items can be replaced and will usually result in a working monitor.
          • ar3ohdee
            • Oct 2010
            • 23
            As far as the caps go, they ALL look fine, and I can't see any bad spots on the back of the P.S. Mobo... Not sure what else it could be, you see anything???
            -R
            • seanc
              • Nov 2008
              • 1319
              There seems to be a hole in the top of U310, which may suggest that it's dead.
              • ar3ohdee
                • Oct 2010
                • 23
                Is that easily replaceable? Where could I get one, and would I just solder it on???
                • seanc
                  • Nov 2008
                  • 1319
                  You'd solder it in, you'd need to find the part number and replace it.
                  First, you need to work out if it is dead or not. You need a digital multimeter.
                  • ar3ohdee
                    • Oct 2010
                    • 23
                    will this allow me to test ALL of the caps, and different fuses???
                    • seanc
                      • Nov 2008
                      • 1319
                      No, it would allow you to test fuses, transistors, diodes etc.
                      You would need an ESR meter for the capacitors.
                      • ar3ohdee
                        • Oct 2010
                        • 23
                        going to pick up the digi multi reader tomorrow, and go from there... What exactly can I test with this again, and how do I test it? Keep you posted... Thanks...
                        • ar3ohdee
                          • Oct 2010
                          • 23
                          O.k. I am reading up on how to use this reader to check everything... Is there anything else in the pictures that look out of the normal??? Talk soon... Thanks
                          -R
                          • ar3ohdee
                            • Oct 2010
                            • 23
                            I checked U310, and my Reader says 10... So I think it it getting a current... What else should I check?
                            • prophecy
                              • Oct 2010
                              • 1
                              hey i new and i was googling and found this forum. i was wondering if i had the same problem with my monitor as in picture 5 how would i go about buying new capacitors
                              • Wrog
                                • Oct 2009
                                • 472
                                Take a look in the "Frequently Asked Questions" subforum, there are stickied threads there on how to replace caps. The short reply is you would make a list of all caps, with their values (uF, voltage), dimensions (diameter and height) and series, then find replacements using the original specs as a guideline. There is also a thread in the same subforum that lists places to purchase your replacement caps (hint: put your location in your profile). If you need help selecting replacement caps, post your list here and someone can point you in the right direction. Lots of folks like to use Panasonic FC or FM if they are available.
                                • smokee_won
                                  • Nov 2010
                                  • 1
                                  Mine failed awhile back and I've just started looking into repairing or replacing the power supply. These posts confirmed the conclusion I drew as soon as I flipped the board over. It appears that ebay has two postings for a cap repair kit. This one => http://cgi.ebay.com/Repair-Kit-Scept...item35ab31658d is a panasonic set for $13.95 plus $2.95 shipping. There is another set for $12.95 plus $2.95 shipping that looks like Nichicon caps http://cgi.ebay.com/Repair-Kit-Scept...item35ab10ff7c. For the more bold individuals there is a Chinese vendor that sells the entire supply for 70 yen http://www.microsofttranslator.com/b...d%3D7366330412.
                                  I could likely get the caps from MCM/Newwork or Digikey but I like the fact that the leg work is already done. Both of the kits are from the same ebay vendor. I am thinking of going with the Panasonic set to fix mine. I'll post after I check for a picture.
                                  • ricebowler
                                    • Dec 2010
                                    • 1
                                    mine have the same problem it wont turn on the monitor. it alway keep flashing blue light and it keep it on please help
                                    • mockingbird
                                      • Dec 2008
                                      • 5488
                                      There are also some big capacitors on the logic board which need to be replaced.
                                      If you want a complete list of al the capacitors and their replacement parts, including the Taicon primary and the small caps on the logic board, let me know I will post it here.
                                      • mockingbird
                                        • Dec 2008
                                        • 5488
                                        I had a partial success with this monitor.
                                        Only the VGA input worked before, and it still only works now. DVI and HDMI still give me "No Signal".
                                        I changed every single capacitor, both on the logic board and PSU, except for one Jackon 47uF 25V which I forgot to order. I also have only that yellow bridge wire on the logic board but not that red one.
                                        Anyone have any idea?
                                          Huawei MateBook MATEBOOK 16 SPACE GRAY Notebook 16 Specification for Upgrade or Repair
                                          This specification for the Huawei MateBook MATEBOOK 16 SPACE GRAY Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the MATEBOOK 16 SPACE GRAY boardview and MATEBOOK 16 SPACE GRAY schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 05:20 AM
                                          Samsung 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U Chromebook Specification for Upgrade or Repair
                                          This specification for the Samsung 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U boardview and 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help...
                                          09-07-2024, 12:10 AM
                                        • Mad_Science
                                          Sharp TFT-LCD Model No. LQ050Q5DR01 gray screen
                                          by Mad_Science
                                          I have a older eddy current tester made by Olympus that uses interchangeable TFT-LCD screens. I have two devices that each take the same removable screens. One is an Olympus NORTEC 200D+ and the other is an Olympus SONIC 1200M EMI. I have searched the internet high and low for service manuals for these units with no luck. Both these units were used extensively by the US military for NDT on airplanes. The detachable screen plugs into the base unit via a weird non standard VGA connector. Buttons on the removable display are used to power the units on. When the power button is pressed the unit makes...
                                          03-01-2024, 05:05 PM
                                          KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
                                          by momaka
                                          For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
                                          http://www.rmac.kingwin.com/products.../abt_650MM.asp
                                          I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
                                          What mostly drew me into buying it is its 2x PCI-E power connectors...
                                          03-29-2022, 11:34 PM
                                        • spirittoo
                                          Sceptre 48" TV backlight LED`s
                                          by spirittoo
                                          Trying to fix a backlight problem with a Sceptre 48" TV.
                                          I found replacement strips with the same part number as the strips in the Sceptre, but the new backlight strips have 5 leds per strip and the ones in the tv has 6.
                                          So I decided to replace the leds instead. I found 3 bad ones. I had no problem removing the bad ones with a heat gun, they came right out. However the leds on the replacement strip would not come out with heat. I use my solder iron as well, they will not come off.
                                          Anyone know how I can remove those leds without damaging them?
                                          11-11-2023, 10:23 AM
