VIZIO VO42L No picture, No Sound
  • smata67
    • May 2006
    • 14
    #41
    Re: VIZIO VO42L No picture, No Sound
    I just got one of these and will be inspecting for the inverter problems. One question, how do I test the diodes, can they be tested in-circuit? My plan is to replace the BD9897FS chip and test the mosfets and replace all of them on the same board if one or more of them is bad. The caps I will also definitely replace with low leakage types.
    • geneg
      • Jan 2007
      • 7
      #42
      Guys, I am not able to open this pdf for the inverter mods. Can anyone send it to me
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        #43
        it opens fine for me with foxit reader.free download.be sure to uncheck the dammed toolbar and homepage stuff though!
        • geneg
          • Jan 2007
          • 7
          #44
          Works now, thanks
          • b700029
            Banned
            • Sep 2010
            • 640
            #45
            Hello, I seem to be having a similar problem. The resistance was off on two mosfets so I replaced the IC on the slave board. Now they are all around 8.5k. The master board is at 8.5k as well.
            When turning the TV on, I get a backlight for about 2 seconds then it turns off again. Also, the blue light on the master board turns on, then off at the same time. Is that light supposed to be constant under normal operation?
            What else should I check?
            • retiredcaps
              • Apr 2010
              • 9271
              #46
              In the lcd computer monitor world, we normally ask people to check the resistance of the secondary inverter transformer pins. It should be within 3% of each other.
              Other possibles causes of 2 seconds to black in the lcd computer monitor world are:
              a) bad caps
              b) bad ccfl
              c) bad ccfl wiring (the return wire)
              --- begin sig file ---
              --- end sig file ---
              • b700029
                Banned
                • Sep 2010
                • 640
                #47
                Originally posted by retiredcaps
                Check the resistance of the secondary inverter transformer pins. It should be within 3% of each other.
                a) bad caps
                b) bad ccfl
                Can you explain which pins on the secondary inverter transformer?
                The backlight does light up fully for 2 seconds, does that rule out b) ?
                Oh, I forgot to add I also replaced both caps on each board. The caps on the Slave board were badly bulged so I replaced them and the IC at the same time.
                I'm guessing it has to do with the inverter boards, but I'm not sure how else to troubleshoot them. I'm also not sure if the blue LED is supposed to stay on or turn back off like I'm seeing.
                • retiredcaps
                  • Apr 2010
                  • 9271
                  #48
                  edit: Found a pic of the transformer with the pins identified.
                  http://lcdparts.net/TransformerDetai...ProductID=3898
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    #49
                    In the computer lcd world, the inverter pwm IC operates as "all or nothing". Either all ccfls work or none at all (shutdown after 2 seconds - various protection mechanisms kick in).
                    You can read more starting with post #19 at
                    https://www.badcaps.net/forum/showthread.php?t=10419
                    The main TV power LED should stay on. I don't know about the master inverter board though.
                    • b700029
                      Banned
                      • Sep 2010
                      • 640
                      #50
                      Yes, the LED on the front of the TV stays on. There is a separate blue one on the master inverter board I was wondering about.
                      Is this how I measure them?
                      Red probe on S1, black probe on S2
                      Red probe on P1, black probe on P2
                      Master inverter #1:
                      S-27.4 ohms
                      P-0.2
                      Master inverter #2:
                      S-27.5 ohms
                      P-0.2
                      Slave #1:
                      S-28.0 ohms
                      P-0.2
                      Slave #2:
                      S-28.1 ohms
                      P-0.2
                      The site you linked: S:56-59 ohms P:0.2-0.4 ohms
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        #51
                        Okay, that is a good sign. That infers that the power supply and main/logic board are likely working.
                        That one I don't know about. I'm assuming since the backlights are off, then it would be logical to have that blue light off as well.
                        Master inverter #1:
                        S-27.4 ohms
                        P-0.2
                        Master inverter #2:
                        S-27.5 ohms
                        P-0.2
                        Slave #1:
                        S-28.0 ohms
                        P-0.2
                        Slave #2:
                        S-28.1 ohms
                        P-0.2
                        The above readings suggest that the inverter transformer is likely good even though the lcdparts.net site says 56-59 ohms.
                        Time to move onto testing the ccfls. Since it is unlikely you have a spare ccfl, do the test where you disconnect all but one. It is explained in post #20 in the troubleshooting guide.
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          #52
                          I noticed in post #21, that each inverter board has a SMD fuse. MF1 and SF2.
                          If there are 2 fuses and if one fuse is open, this may explain 2 seconds to black.
                          So check all your fuses on the boards to see if they are good or not. A good fuse should measure less than 1.0 ohms.
                          We had a similar case where one bad SMD fuse caused 2 seconds to black. From post #19 section 3 (of the troubleshooting guide) ...
                          https://www.badcaps.net/forum/showthread.php?p=197027
                          edit: This is why we always insist on clear focused pictures. Having those pics in post #21 help.
                          • b700029
                            Banned
                            • Sep 2010
                            • 640
                            #53
                            I can add photos, but post #21 was a good representation
                            Ok, checked MF1 on the master and SF2 on the slave and they were both <0.2 ohms. Both boards are seeing 24.5 volts too.
                            I will work on the CCFL test next, I read post #20 in your guide.
                            There is only one plug from each inverter board going into the panel. So that means I have to take it apart and there will be several CCFLs connected together to these two plugs that I can individually unplug? Or are there only two CCFLs? I saw another post that the inverter board had 10 or so plugs along the side of it, I can see how your idea works there.
                            Edit: I unplugged the output from the master board, and the backlight did not light for 2 seconds. Plugged in the master and unplugged the slave and it lights for 2 seconds. This could mean?
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              #54
                              And post #4. I have to give credit to both posters for their pics.
                              I can think of 2 things.
                              1) It could mean the master controls the whole show. That is, without the working master and its ccfls, nothing runs at all and it doesn't even try to light up the slave ccfls.
                              2) If the master doesn't control the whole show, then there is something wrong with the slave board and/or its ccfl/wiring.
                              Another test.
                              What happens if you plug the slave ccfl into the master board and vice versa using the same disconnect test?
                              • b700029
                                Banned
                                • Sep 2010
                                • 640
                                #55
                                I agree there may still be a problem with the slave board. This is also the one I changed the IC on. (The MOSFET resistances are good now though).
                                Here is a photo of the back of the TV. I thought about trying to switch the boards but based on the wiring I don't think it would work. The master board has a 14p header from the PSU, while the slave has a 12p. The ribbon cables don't line up either.
                                With this arrangement can I not do your test of disconnecting all but one CCFL at a time?
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  #56
                                  I mean just switch the pink cables that go to the ccfls. You will have to do some board acrobatics so exercise caution and use cardboard to insulate and prevent shorts.
                                  Or are the cables all keyed towards a master and a slave?
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    #57
                                    I can't tell with the shielding how all the ccfls are arranged internally. Before you go taking things apart, there are a few more things to check on the inverter board and others may chime in with other suggestions.
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      #58
                                      Can you post a picture of your slave board and circle which two you replaced? This will also identify what board revision you have.
                                      I'm wondering if you have to replace all 4 even if the 2 originals measured good resistance wise? A resistance test won't catch all the faults of the mosfet.
                                      • b700029
                                        Banned
                                        • Sep 2010
                                        • 640
                                        #59
                                        They are not keyed, but the cables are short and come out on opposite ends of the set. I think even with taking the power supply off so I can move everything over, the master board might not reach the slave plug.
                                        Ok, I will work on your suggestions and take more photos.
                                        • fillmore85
                                          • Dec 2011
                                          #60
                                          I am glad I found this site. I also have the VO42L FHDTV10A with sound and no picture.
                                          The "Vizio" logo changes from yellow to white and I am able to switch inputs and hear sound from the selected input, but I have no picture. Not even a dim picture.
                                          I was also concerned about the blue LED that is lit up on the master inverter but goes out 3 seconds after the tv is on.
                                          I will check the CCFL's tomorrow and switch out the IC on the master inverter.
                                          • cheeky2
                                            by cheeky2
                                            05-25-2024, 03:27 AM
                                          • Dani_2024
                                            by Dani_2024
                                            10-28-2024, 05:06 PM
                                          • gavric
                                            Vizio M70-C3 Half picture is bad, main board on its last leg?
                                            by gavric
                                            Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
                                            When tv powers on vizio V logo shows nice on whole screen. picture 1
                                            When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
                                            When i start youtube picture shows on left side fine, right is all scrambled. pic 2
                                            When i click video to start playing picture goes black(like when you change...
                                            09-02-2021, 08:55 PM
                                          • fharris1977
                                            Vizio D50u-D1 Dead: PSU or Main Board?
                                            by fharris1977
                                            Hi. Anyone who has experience with these vizio sets, which pin on this connector is the standby, the 5V pin? Trying to rule out the PSU before ordering a mainboard. I'm getting 0 Volts on all pins on this connector. Trying to jump the standby and PS ON pins to see if the PSU is functioning. Thanks in advance.
                                            03-12-2024, 12:22 PM
                                          • DXseekerMO
                                            Vizio E55-C2, appears dead, no 20V, main cap always 385V, no PSon
                                            by DXseekerMO
                                            I bought this Vizio E55-C2 yesterday with the complaint of completely dead, will not power on, no initial power light that trails off when plugged in. The complaint is confirmed.
                                            The 120V protection fuse is good. The first thing I checked was main cap voltage, always at 385V. Other voltages found on the power board look like the TV is trying to tell me it's partially on? Here they are:
                                            Main cap…….385v stable
                                            1: 5VSB……….5.05v stable
                                            2: 5VSB……….5.05v stable
                                            3: ACD…………3.3v stable
                                            4: PS_ON…….3.3v stable...
                                            10-14-2018, 02:45 PM
