Memorex MLT3221 - No Power
  • Dgtech
    E. Technician
    • Apr 2009
    • 1462
    • Steeler
    This one is stumping me for the moment.
    THE PROBLEM - No power at all. No power LED. No visual or audible changes when plugged in or power button pressed. "CON3" shows no output voltages to the digital board. IC8 is
    CHECKED COMPONENTS - Both fuses, all electrolytics (under HS3 - heatsink 3) were checked and confirmed. MOSFET's all checked good.
    CHANGED COMPONENTS - IC4 (KA431AZBU Shunt Regulator), IC8 (PWM chip), IC1 (on back)
    If you notice Q1 wasnt on the board, it will be shortly. I just removed it for the moment. It is a 2n4403. It checks ok as well.
    I have no documentation on this power supply. I find lots of people fix these on ebay. This board is listed on there either as IPOS 150 or 120. This one is the IPOS 150 Rev.3.3. (200-P00-HIVI150-CH).
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Memorex MLT3221 - No Power
    Do you see 5V standby voltage on CON3?
    --- begin sig file ---
    --- end sig file ---
    • Dgtech
      E. Technician
      • Apr 2009
      • 1462
      • Steeler
      Nope, no 5 volts there.
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        That's a problem. The pin labeled "5vsb" should always have 5v present on it.
        Seeing that there are HEC caps used on this power supply, it's very possible that the PSU start-up capacitor has dried. I see 2 small capacitors under the primary heatsink right behind Q6. One of them (or possibly both) is responsible for starting up the PSU. If they are of a known unreliable brand, change both.
        Before you do that, though, check the voltage across the big primary capacitor (EC2?). There should be around 165v. If present, then change the two caps I mentioned above.
        • Dgtech
          E. Technician
          • Apr 2009
          • 1462
          • Steeler
          Here are some more readings:
          165 VDC across EC2 (the big electrolytic)
          68 VAC at J7 - near upper 2 mosfets - between C72 and C73.
          Con3 - on the 12vdc pin I show a 1 Hz pulse that only goes as high as 9.8
          VDC ( using fluke, min-max function)
          80VDC on gate of Q17 - which I think is a driver mosfet for the lamp circuit.
          On 5VSB there is a 1Hz pulse of a high of 1.5v
          • PlainBill
            • Feb 2009
            • 7034
            Those measurements are consistent with either a bad start-up capacitor (those mentioned by retiredcaps) or an excessive load on one of the outputs.
            PlainBill
            • Dgtech
              E. Technician
              • Apr 2009
              • 1462
              • Steeler
              I checked and , just for kicks, actually changed the caps under the heatsink on the primary side. No change in result. There is 80VDC on gate of one of the mosfets that drive the lamp circuit. This is making me think that the primary side should be ok. Does this judgement seem sound?
              There was a mosfet that I question. This one is a Fairchild -FQPF 27po6. I checked it using two different fluke meters.
              Fluke 1 shows
              OFF = 336K OHMS ON = .2 OHMS
              Fluke 2 shows
              OFF = 886K OHMS ON= CANT SEEM TO TURN ON
              With the fluke 1, I'd think that the off should have been higher resistance S-G.
              With fluke 2, maybe the battery is dying?? I just changed the one in #1 last week.
              • retiredcaps
                • Apr 2010
                • 9271
                Fluke 1 shows
                I realize there are multiple ways of testing, but can you explain how you are measuring the mosfet with the terminology ON?
                • Dgtech
                  E. Technician
                  • Apr 2009
                  • 1462
                  • Steeler
                  I connect the source to the meter negative and touch the gate with the positive. Then move the positive to the drain. Should be on at this point = very low resistance. I made a typo above on the other post when I said I measured from source to gate, I meant source to drain.
                  • Dgtech
                    E. Technician
                    • Apr 2009
                    • 1462
                    • Steeler
                    OK- I found my error with testing this mosfet. EARLY MORNING BLUNDER. This one is a P - channel vs an N -channel. REVERSE THE POLARITY OF THE METER LEADS. LOL.
                    I need sleep, or alcohol, which ever comes first!
                    This mosfet tests ok now. I still have no output on this power supply.
                      master hoarder
                      • May 2008
                      • 12175
                      • Bulgaria
                      Check diode D6? and also small SMT diode D2 on the backside of the board.
                      If those are good, check resistance between 5vsb and ground. If it's not shorted, change the output capacitors on 5vsb - that would be EC15 and the two capacitors to the right of the inductor L6 in the second picture.
                      • Dgtech
                        E. Technician
                        • Apr 2009
                        • 1462
                        • Steeler
                        D2 looks fine - .5 Vdc on diode check however, does .158 sound right for D6(both diodes)? I'm used to diodes checking .5 Vdc or .7 but not .158. Do these fail like this? or do they usually burn open? Also, the one above it (on the same heatsink) measures .252 as well.
                        Here are the numbers on these:
                        D6 = FYPF2045DN
                        Above component = MBRF10100
                        Both datasheets are attatched. I cant seem to find the information from these to tell if both are good or not.
                        • Dgtech
                          E. Technician
                          • Apr 2009
                          • 1462
                          • Steeler
                            master hoarder
                            • May 2008
                            • 12175
                            • Bulgaria
                            I think there was a misunderstanding. The diode D6 I was talking about is located on the primary side, close to the transformer and Q6. Perhaps I misread the numbers on the board.
                            Diodes *usually* become shorted when they fail.
                            However, the reading you got for those schottky diodes attached to the heatsinks (0.158 for both diodes) sound normal since schottky diodes have lower voltage drop (and hence better efficiency, which is why they are preferred for the outputs in PSUs).
                            For FYPF2045DN, if you look at Figure 1. Typical Forward Voltage Characteristics (on page 2) you will see a graph of Forward Curent vs. Forward Voltage Drop. As the Forward Current increases, the Forward Voltage Drop becomes larger. Since your multimeter is not putting a lot of current through the diode, the Forward Voltage Drop you get displayed on your multimeter's screen is fairly low. Hence the low readings.
                            • Dgtech
                              E. Technician
                              • Apr 2009
                              • 1462
                              • Steeler
                              It was my mistake, you were right about the part number. I checked out those components and found that they were good. I changed the cap just to be sure - same result.
                              I did find a shorted diode at D10. This diode is marked as HER304. I have circled it on the attatched photo. It is attatched to a heatsink and is standing upright. As also seen in the 2nd photo. This is the classic case of "I thought I checked that before". Taking notes would have made all the difference.
                              Now I have to find a solution for a match if I cant find the exact component.
                                master hoarder
                                • May 2008
                                • 12175
                                • Bulgaria
                                Is this out of circuit or in-circuit measurement? If in-circuit, measure it again out of circuit just to make sure.
                                Looking at the HER304 datasheet, just about any fast-recovery diode capable of 3A @ 50C should work.
                                Basically just match the Forward Current (Amp) rating and the Maximum Reverse Recovery Time rating. HER304 has 50 ns (nanoseconds) recovery time. As for the voltage rating - I doubt this PSU has any voltage on the secondary side above 30v, so even a 100v diode would likely work fine.
                                *EDIT*
                                Looking at second photo above, the solder joint between the heatsink and the diode seems cracked. Perhaps this is what caused the diode to short?
                                • Dgtech
                                  E. Technician
                                  • Apr 2009
                                  • 1462
                                  • Steeler
                                  I apreaciate the help momaka. Yes, the readings were out of circuit. After checking Digikey and Fairchild, I finally found it at Allied. I will post the result once I get the part. Thanks again.
                                  • Dgtech
                                    E. Technician
                                    • Apr 2009
                                    • 1462
                                    • Steeler
                                    Everything works well after replacing that diode. All powered up and scanning for digital channels now. Thanks again momaka. I apreciated your help and guidance.
                                      master hoarder
                                      • May 2008
                                      • 12175
                                      • Bulgaria
                                      Hey don't thank me. After all, you found the shorted diode and did all of the work . Good job!
                                      By the way, what diode did you use as a replacement? (you know, just in case anyone needs this as a reference.)
                                      • Dgtech
                                        E. Technician
                                        • Apr 2009
                                        • 1462
                                        • Steeler
                                        The replacement part was an NTE equivilent. NTE576
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          09-06-2024, 05:59 AM
