Memorex MLT3221 - No Power
  • johnnieboy2
    • Oct 2011
    • 42
    Re: Memorex MLT3221 - No Power
    I can do that, but out of curiosity, does this board have a 5v reg? If not how is it developed?
    • johnnieboy2
      • Oct 2011
      • 42
      Can anyone tell me what R56 value should be? It's located just to the right of EC7, one of the famed failure caps.
      • PlainBill
        • Feb 2009
        • 7034
        This is a switching mode power supply (actually two of them on one board). Regulation is accomplished by the interaction between a TL431A voltage reference, an opto-isolator, and the SMPS controller IC. In very general terms the SMPS controller pumps energy into the primary of a transformer, the secondary voltage is rectified and filtered, and the voltage reference instructs the smps controller to vary the amount of energy dumped into the primary based on the how closely the filtered voltage matches the design voltage.
        While it sounds (and is) complicated the entire arrangement can provide over 200 watts of well regulated (within 1%) power at more than 80% efficiency from a package about the size of a cigar box. By comparison, 30 years ago I workec for a company that built 200 watt linear power supplies. They were 18" x 8" x 8" and less than 33% efficient.
        PlainBill
        • johnnieboy2
          • Oct 2011
          • 42
          Thanks for explaining that.
          • johnnieboy2
            • Oct 2011
            • 42
            I've ordered a set of caps for the P/S board, 16 in all...will update when installed and tested. If this doesn't do it then it's !!! And in case of failure...anyone looking for components off this thing?, Let me know.
            • Dgtech
              E. Technician
              • Apr 2009
              • 1462
              • Steeler
              #86
              As you know, your 5V DC standby voltage is most likely your problem. With that being said, the problem rests on the power board. There are only a few components that make up the 5VDC. I dont have a schematic, and I'd give my left pinky toe for one, but I think the PWM might have something to do with the standby 5V. Check to see if that main chip, near the main output connector, has 13 volts on one of the pins. I can't remember what pin it was. I'm gonna try to find a thread with more info to help out.
              • johnnieboy2
                • Oct 2011
                • 42
                Your input is most appreciated. I really don't like the 'shotgun' approach I'm using but without a schematic and lack of Digital TV experience it's that or the junk pile.
                That said, what would be the conclusion if I have or don't have the 13v?
                • PlainBill
                  • Feb 2009
                  • 7034
                  Troubleshooting the standby power supply is rather straightforward. Dgtech is suggesting you check the power supply pin for the SMPS controller. Googling the part number and datasheet should lead you to the datasheet, which will identify the proper pins. If Vcc is missing, it suggests a problem with a bleeder resistor or the rectified mains supply. If it is low and steady, it suggests a bad SMPS controller. If it is pulsing, it suggests a short on the output or a bad startup cap.
                  PlainBill
                  • johnnieboy2
                    • Oct 2011
                    • 42
                    All I got was some low levels of pulsating voltages, millivolt range. Definitely replacing those startup caps when I get them. Short on the output, can you elaborate, what part... another board?
                    • PlainBill
                      • Feb 2009
                      • 7034
                      Wrong controller. That's the inverter controller. The SMPS controllers would be the two 8 pin ICs near oneanother on the bottom of the board.
                      PlainBill
                      • johnnieboy2
                        • Oct 2011
                        • 42
                        This is what I was referencing in my last the comments on voltages. I'm assuming your advice relates to a different IC which I cannot seem to find. Feeling like a clutz!
                        • Dgtech
                          E. Technician
                          • Apr 2009
                          • 1462
                          • Steeler
                          #92
                          If that's the pinout for IC8 then what voltave do you have on you pin 13 VCC?
                          • PlainBill
                            • Feb 2009
                            • 7034
                            Well, since you were nice enough to provide good pictures, I'll return the favor.
                            These identifications are tentative; if you supply the part number of the first three I an confirm them.
                            Blue circle - PFC Controller.
                            Yellow circles - Standby and Main SMPS controllers
                            Orange circle - Inverter controller.
                            Red circle - unknown, but possibly a 'power good' sensor.
                            PlainBill
                            • johnnieboy2
                              • Oct 2011
                              • 42
                              .024 to .029 volts fluctuating
                              • johnnieboy2
                                • Oct 2011
                                • 42
                                PlainBill
                                Gosh, I need a microscope! Best I can tell...
                                blue...very hard to read, guesstimate...ST (?) C2747 or CZ747
                                yellow...top one in pic is 78074 and STM4410A
                                yellow...6675A (Extremely hard to read accurately)
                                orange...SG3525AN
                                Red...D78F9222CX
                                • Dgtech
                                  E. Technician
                                  • Apr 2009
                                  • 1462
                                  • Steeler
                                  #96
                                  I guess I was wrong to think that chip was the main PWM for this power supply. I could not find any schematic to go by. How would I identify this as the main PWM in this circuit (for furture ref.)?
                                  • PlainBill
                                    • Feb 2009
                                    • 7034
                                    Aww, crap!!! It looks like I was wrong. I'm going to have to look over this again. One of the ICs I identified as an SMPS controller is a power FET, the other isn't identifiable, both are on the cold side of the power supply. The one I thought was an inverter controller is an SMPS controller. No, it's worse than that. The SG3525AN is definitely the controller for the high voltage (inverter) output. And the SMPS controller must be on the hot side of the power supply
                                    PlainBill
                                    • PlainBill
                                      • Feb 2009
                                      • 7034
                                      orange...SG3525AN
                                      Red...D78F9222CX
                                      OK, time to regroup. After looking this over carefully, I missed a LOT of clues, and misidentified the function of some components.
                                      IC2 (six pin IC up from the IC I circled in blue) is probably the SMPS controller. What is it's part number (yes, time to get a magnifying glass).
                                      The IC circled in blue is almost certainly the PFC controller; we aren't going to sweat the identification.
                                      PlainBill
                                      • johnnieboy2
                                        • Oct 2011
                                        • 42
                                        number on this is...62739
                                        • PlainBill
                                          • Feb 2009
                                          • 7034
                                          Nope, that crosses to a 3 pin IC. Sometime is you look at them at an angle the numbers are easier to read.
                                          PlainBill
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                            03-31-2024, 02:12 PM
                                            09-06-2024, 05:59 AM
