I have a TCL Roku 55S403TCAA. It quit working after a storm. Other electronics quit working as well so I am pretty sure the storm had something to do with it. Anyway, I took a look at it, no obvious damage, blown components, scorch marks, etc. I am looking at the power board first, 40-L141H4-PWG1CG. I've repaired bad caps and blown components but nothing more extensive beyond that. I am trying to troubleshoot it, but I can't even find the fuse on this board. There are markings on the PCB saying "replace fuse as marking" however. I attached a photo of the board. I am also testing the pins but I can't find the standby pin. I don't know if it has a different marking on this board. There are two connectors and the only labels the pins have are GND, 12v, NC, P_DIM, BL_ON, P_ON, A_DIM, and then several LED pins. I'm not sure what to do since I thought every board had those. I'd appreciate any suggestions.
TCL Roku 55S403TCAA dead after storm
Re: TCL Roku 55S403TCAA dead after storm
Usually fuse is right by the AC plug. Maybe I'm not familiar with what this type of fuse looks like. Maybe on bottom ? It says it on the board. And lightning can also run up the HDMI inputs also so main board could be damaged also. Check around HDMI connectors for shorts as well (if that was a possibility)
Edit, that disc may be the fuse actually but not sureLast edited by EazyBone; 11-19-2023, 05:18 PM. -
Maybe this will helpAttached FilesComment
or this.Attached FilesComment
Assuming...7 Photos -
by k370Hi everyone,
I have a NM-A321 board that is dead, with no power at all.
When I received the laptop, the +5VPMIC line was shorted. Removing the PU3 (ISL95905) solved the short, so I ordered and replaced the ISL.
With the new ISL, the short is gone, but still no voltages at all. I measured the following rails:- +3VALW
- +5VAUX
- 1.2VSUS_PWRGD
- 3VALW_PGD
- 1.05VAUX_PWRGD
Additionally, the ISL95906 (PU3) is not getting any voltage on the VIN rail.
The only place on the board where I find any voltage is on the first MOSFETs, specifically:... -
by Asraf AtbHi everyone,
I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....1 Photo -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by yuuki47Hello...
My sister purchased an M2 MacBook Air a year and a half ago. While she was using it a week ago, it randomly shut off and no longer powers on. There are no signs of life and not even the MagSafe indicator LED lights up.
We took it to Apple and they disconnected the battery and tried a bunch of stuff before they declared the logic board "brain dead" and quoted us about £567 to replace it. Typical of them...
eBay replacements run about £367 with the Touch ID sensor included.
I did consider to probe the logic board for shorts... - Loading...
