TCL Roku 55S403TCAA dead after storm
  • bobbintb
    • Feb 2014
    • 6
    I have a TCL Roku 55S403TCAA. It quit working after a storm. Other electronics quit working as well so I am pretty sure the storm had something to do with it. Anyway, I took a look at it, no obvious damage, blown components, scorch marks, etc. I am looking at the power board first, 40-L141H4-PWG1CG. I've repaired bad caps and blown components but nothing more extensive beyond that. I am trying to troubleshoot it, but I can't even find the fuse on this board. There are markings on the PCB saying "replace fuse as marking" however. I attached a photo of the board. I am also testing the pins but I can't find the standby pin. I don't know if it has a different marking on this board. There are two connectors and the only labels the pins have are GND, 12v, NC, P_DIM, BL_ON, P_ON, A_DIM, and then several LED pins. I'm not sure what to do since I thought every board had those. I'd appreciate any suggestions.
  • EazyBone
    • Jun 2023
    • 1319
    • United states
    Re: TCL Roku 55S403TCAA dead after storm
    Usually fuse is right by the AC plug. Maybe I'm not familiar with what this type of fuse looks like. Maybe on bottom ? It says it on the board. And lightning can also run up the HDMI inputs also so main board could be damaged also. Check around HDMI connectors for shorts as well (if that was a possibility)
    Edit, that disc may be the fuse actually but not sure
    • williej
      • May 2005
      • 10
      Maybe this will help
      • williej
        • May 2005
        • 10
        or this.
        • R_J
          • 9535
          The primary fuse is F1 red rectangle box
          • EazyBone
            • Jun 2023
            • 1319
            • United states
            Thanks, was curious as well. Do you know what this type of fuse is called?
            • R_J
              • 9535
              Little fuse 392 series or mst micro fuse, radial box some call them a dip mounted fuse. or TE5 fuse
              • EazyBone
                • Jun 2023
                • 1319
                • United states
                Thanks, I googled those and they all came up. Appreciate it
                • bobbintb
                  • Feb 2014
                  • 6
                  Ah, thank you. I looked right at it several times but I've never seen that type of fuse so I didn't notice.
                  • bobbintb
                    • Feb 2014
                    • 6
                    Originally posted by williej
                    or this.
                    Thanks. I found the first one but the model number was different so I wasn't sure if it was sufficiently similar.
                    • k370
                      Yoga3 Pro-1370 Board NM-A321 DEAD no power at all
                      by k370
                      I have a NM-A321 board that is dead, with no power at all.
                      When I received the laptop, the +5VPMIC line was shorted. Removing the PU3 (ISL95905) solved the short, so I ordered and replaced the ISL.
                      With the new ISL, the short is gone, but still no voltages at all. I measured the following rails:
                      • +3VALW
                      • +5VAUX
                      • 1.2VSUS_PWRGD
                      • 3VALW_PGD
                      • 1.05VAUX_PWRGD
                      Additionally, the ISL95906 (PU3) is not getting any voltage on the VIN rail.
                      The only place on the board where I find any voltage is on the first MOSFETs, specifically:...
                      09-23-2024, 11:57 AM
                    • Asraf Atb
                      by Asraf Atb
                      01-27-2025, 05:02 PM
                    • m1ch43lzm
                      by m1ch43lzm
                      05-12-2025, 08:37 PM
                    • yuuki47
                      A2681 M2 MacBook Air Dead Logic Board
                      by yuuki47
                      Hello...
                      My sister purchased an M2 MacBook Air a year and a half ago. While she was using it a week ago, it randomly shut off and no longer powers on. There are no signs of life and not even the MagSafe indicator LED lights up.
                      We took it to Apple and they disconnected the battery and tried a bunch of stuff before they declared the logic board "brain dead" and quoted us about £567 to replace it. Typical of them...
                      eBay replacements run about £367 with the Touch ID sensor included.
                      I did consider to probe the logic board for shorts...
                      04-13-2024, 06:22 AM
