These are protective diodes and they are located at the AV signal input; if something was connected during lightning, then the discharge passed through this input and could kill the processor.
Samsung UN60EH6000 wont come on after lightning strike.
This topic has been answered.
Which ones are you referring too? If you are talking about the D407 and D409 that I found burned, these seem to be diodes and upon more checking are not good. One is totally open in either direction.
These diodes are close to the RCA input jacks on the board. The only port that was connected during the strike was HDMI1.Last edited by karthur; 11-28-2023, 07:58 AM.Comment
When I tested the IC601, I get a reading with the "+" probe on the anode and "-" on the cathode. When I reverse the leads, shouldn't this now read "0" for a good diode? I get a reading >0 when I do this for both legs. Does this not mean the diode is faulty?
I tested IC601, IC602 and IC204, To me all three seem to be faulty. Am I testing these wrong?
After much searching, I finally found a datasheet on this component. This component is made by "Diodes Incorporated". This is a voltage regulator. A link to the data sheet is here.
https://cdn.badcaps-static.com/pdfs/...fca50db500.pdf
Attached Filesif you find these attachements useful please consider making a small donation to the site
Here is the bin file for my UN60EH6000FXZA. Chip is a Winbond W25Q128BV.
I have not given up on this just yet. I finally got around to replacing the main board and I still have the same issue. I have replaced both the main and T-con board. The only one left is the Power board. Before I spend another $55 on this thing, can someone tell me what to check so I can have a clue if the problem is the power board or not?
There is a picture of the power board on post #9.
Much appreciated.Comment
by Bardou KariHi,
I’m trying to fix an HP EliteBook 840 G6 that stopped working after a lightning storm.
– Charger is OK and 19V is present at the motherboard.
– No charging LED, no fan, no reaction.
– I don’t see any 3.3V or 5V near the coils.
– Battery is unplugged.
– I’m new to board repair but can use a multimeter.
I added a clear photo of the board.
Any idea where to start or what to check next?
Thanks a lot for your help!...07-01-2025, 10:45 AM -
by SluggerBYes it's a 17 year old Panasonic plasma!
I was watching TV when there was a huge lighting strike nearby my house that shook the house. When that happened, the picture on the TV froze and the TV wouldn't turn off except by pulling the power cable. Now if you plug in the TV, it seems to turn on (it makes the turn on "clikcs" it always does, the red power light comes on but there is no picture, although I can see the back light around the edges. And the TV doesn't respond to the power button on the remote to turn off, and doesn't respond to the manual power button on the front... -
by MrCreosoteTHE LIGHTNING:
This was a very close strike, blew a 15 amp breaker for all ceiling lights in home AND could smell ozone for a few minutes after strike.
Very close and probably a very strong EMP.
THE TV:
No standby LED. Some voltage from PSB (not totally dead).
But found a kit of ALL 4 circuit boards for $55.
At first thought, this will fix my TV.
But then lightning has the ability to totally fry semiconductors. Which would include any or all of the PCBs. However, the display is one big semiconductor and given... -
by pbighi everyone,
my parents in law have seen their Bravia Sony LED 32EX600 TV set stop after a lightning strike. After being plugged to mains, it shows nothing no power LED on bottom left shines.
On the power PCB (GE3b, attached pic), I chacked the fuses and the only roasted one is R6536 : 0.47 ohms, 1/2W. After replacing it, I made some voltage measurement with ref to the chassis :
- the 450V/150uF capacitor voltage when plugged is normal at 394V
- from connector CN6150 (15 poles)
STBY normal 3.3V -> I shunted it to 3 (POWER ON) and 11 (BL ON) and unplugged...06-28-2023, 02:43 AM -
by pflHello Everyone.
This powerful amplified subwoofer doesn't make any sound after lightning striked near the house were it was plugged in.
It consists in :- a power board were the full H bridge class D amplifier and main power rails are located
- a preamp board (ref. F.01U.299.771) receiving 2 symetrical inputs(IN1, IN2), a digital chain (A-D converter -> Digital Signal Processor -> D-A converter) and a micro controler in charge (at least) of the human interface (lcd display and 1 rotating button)
human interface is working fine
Input levels are...-
01-23-2024, 10:21 AM - Loading...
