Samsung UN60EH6000 wont come on after lightning strike.
This topic has been answered.
  • lotas
    • Jan 2016
    • 4880
    • Russia
    These are protective diodes and they are located at the AV signal input; if something was connected during lightning, then the discharge passed through this input and could kill the processor.
    • karthur
      • Nov 2015
      • 150
      Which ones are you referring too? If you are talking about the D407 and D409 that I found burned, these seem to be diodes and upon more checking are not good. One is totally open in either direction.
      These diodes are close to the RCA input jacks on the board. The only port that was connected during the strike was HDMI1.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4541
        • Italy - Milan
        probably diodes are a previous fault..
        • karthur
          • Nov 2015
          • 150
          When I tested the IC601, I get a reading with the "+" probe on the anode and "-" on the cathode. When I reverse the leads, shouldn't this now read "0" for a good diode? I get a reading >0 when I do this for both legs. Does this not mean the diode is faulty?
          I tested IC601, IC602 and IC204, To me all three seem to be faulty. Am I testing these wrong?
Name:	Good or Bad.png
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4541
            • Italy - Milan
            IC601 stands for Integrated Circuit 601, why you tell about anode, cathode?
            • karthur
              • Nov 2015
              • 150
              I thought you said IC601 was a double diode. I have been treating and testing it as such.
              Refer to post#16 above.
              • karthur
                • Nov 2015
                • 150
                After much searching, I finally found a datasheet on this component. This component is made by "Diodes Incorporated". This is a voltage regulator. A link to the data sheet is here.
                https://cdn.badcaps-static.com/pdfs/...fca50db500.pdf
Name:	DII AP1117.png
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4541
                  • Italy - Milan
                  #28
                  There was no need, it's a common 1117, so what you have on tab of ic601? if 3,3v it's ok, then software issue..stop..
                  • karthur
                    • Nov 2015
                    • 150
                    Voltage on these components
                    IC204 (on the tab) 1.5vdc
                    IC601 (on the tab) 3.3vdc
                    IC602 (on the tab ) 1.8vdc
                    Does anyone have a dump for the IC901 chip?
                    • karthur
                      • Nov 2015
                      • 150
                      Found a .bin file on ***********. They charge for a "VIP" membership in order to download the file. Anyone used this site? I am needing the " UN60EH6000FXZA bios bin".
                      • lotas
                        • Jan 2016
                        • 4880
                        • Russia
                        #31
                        Post your own dump.
                        • karthur
                          karthur commented
                          Editing a comment
                          Posted it below..... Thanks
                      • karthur
                        • Nov 2015
                        • 150
                        Do I need to remove the chip from the board or can it be read while installed?
                        • lotas
                          • Jan 2016
                          • 4880
                          • Russia
                          #33
                          It is better to carefully unsolder it, clean the contacts from flux with isopropyl alcohol and read the data on the programmer through the adapter socket.
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4541
                            • Italy - Milan
                            #34
                            you can try to solder tiny wires, not all pins needed, vcc, gnd, di, do, clk, wp and maybe cs... have you got an old transformer to unroll the wire?
                            Note: Lotas thankyou for the dump for the Sharp tv, it worked!
                            • angelos
                              • Dec 2012
                              • 573
                              • South Africa
                              #35
                              Absolutely, replace the board
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4541
                                • Italy - Milan
                                #36
                                Component inputs was not connected!!
                                • karthur
                                  • Nov 2015
                                  • 150
                                  Post your own dump.
                                  Here is the bin file for my UN60EH6000FXZA​. Chip is a Winbond W25Q128BV.
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4541
                                    • Italy - Milan
                                    #38
                                    Is it a smart TV? I guess not..
                                    • karthur
                                      • Nov 2015
                                      • 150
                                      Correct. It is not a Smart TV.
                                      • Davi.p
                                        Davi.p commented
                                        Editing a comment
                                        So the software is all within that Small spi flash
                                      • karthur
                                        karthur commented
                                        Editing a comment
                                        That would be my guess, but I am not 100% sure about that.
                                    • karthur
                                      • Nov 2015
                                      • 150
                                      I have not given up on this just yet. I finally got around to replacing the main board and I still have the same issue. I have replaced both the main and T-con board. The only one left is the Power board. Before I spend another $55 on this thing, can someone tell me what to check so I can have a clue if the problem is the power board or not?
                                      There is a picture of the power board on post #9.
                                      Much appreciated.
                                      • Bardou Kari
                                        HP EliteBook 840 G6 – no power after lightning strike
                                        by Bardou Kari
                                        I’m trying to fix an HP EliteBook 840 G6 that stopped working after a lightning storm.
                                        – Charger is OK and 19V is present at the motherboard.
                                        – No charging LED, no fan, no reaction.
                                        – I don’t see any 3.3V or 5V near the coils.
                                        – Battery is unplugged.
                                        – I’m new to board repair but can use a multimeter.
                                        I added a clear photo of the board.
                                        Any idea where to start or what to check next?
                                        Thanks a lot for your help!...
                                        07-01-2025, 10:45 AM
                                      • SluggerB
                                        Panasonic TH-50PX80 killed by lightning strike, help me save her!
                                        by SluggerB
                                        Yes it's a 17 year old Panasonic plasma!
                                        I was watching TV when there was a huge lighting strike nearby my house that shook the house. When that happened, the picture on the TV froze and the TV wouldn't turn off except by pulling the power cable. Now if you plug in the TV, it seems to turn on (it makes the turn on "clikcs" it always does, the red power light comes on but there is no picture, although I can see the back light around the edges. And the TV doesn't respond to the power button on the remote to turn off, and doesn't respond to the manual power button on the front...
                                        06-04-2025, 07:02 PM
                                      • MrCreosote
                                        Lightning Strike: 55" TV dead: is display panel OK?
                                        by MrCreosote
                                        THE LIGHTNING:
                                        This was a very close strike, blew a 15 amp breaker for all ceiling lights in home AND could smell ozone for a few minutes after strike.
                                        Very close and probably a very strong EMP.
                                        THE TV:
                                        No standby LED. Some voltage from PSB (not totally dead).
                                        But found a kit of ALL 4 circuit boards for $55.
                                        At first thought, this will fix my TV.
                                        But then lightning has the ability to totally fry semiconductors. Which would include any or all of the PCBs. However, the display is one big semiconductor and given...
                                        08-16-2021, 10:27 PM
                                      • pbig
                                        advices for repairing Sony Bravia 32EX600 after lightning strike
                                        by pbig
                                        hi everyone,
                                        my parents in law have seen their Bravia Sony LED 32EX600 TV set stop after a lightning strike. After being plugged to mains, it shows nothing no power LED on bottom left shines.
                                        On the power PCB (GE3b, attached pic), I chacked the fuses and the only roasted one is R6536 : 0.47 ohms, 1/2W. After replacing it, I made some voltage measurement with ref to the chassis :
                                        - the 450V/150uF capacitor voltage when plugged is normal at 394V
                                        - from connector CN6150 (15 poles)
                                        STBY normal 3.3V -> I shunted it to 3 (POWER ON) and 11 (BL ON) and unplugged...
                                        06-28-2023, 02:43 AM
                                      • pfl
                                        ElectroVoice ETX-18SP (powered Subwoofer) damaged after lightning strike
                                        by pfl
                                        Hello Everyone.
                                        This powerful amplified subwoofer doesn't make any sound after lightning striked near the house were it was plugged in.
                                        It consists in :
                                        • a power board were the full H bridge class D amplifier and main power rails are located
                                        • a preamp board (ref. F.01U.299.771) receiving 2 symetrical inputs(IN1, IN2), a digital chain (A-D converter -> Digital Signal Processor -> D-A converter) and a micro controler in charge (at least) of the human interface (lcd display and 1 rotating button)
                                        Power rails are ok.
                                        human interface is working fine
                                        Input levels are...
                                        01-23-2024, 10:21 AM
