TCL 55S451 Blank screen
  • lotas
    • Jan 2016
    • 4531
    • Russia
    #41
    And how do you determine that it shows Om, kOm, MOm?
    • x_orange90_x
      • May 2015
      • 702
      I looked at the owners manual online and it doesn't help. That's all I know is it says ex. 5.00 M ohm
      I thought that if they read anything other than OL they would be suspect and one bad can make others read bad when they're not. I have another older meter I try and see if it's different.
        • 12094
        • U.S.
        #43
        Capital M for megaohms, small m for milliohms.
        • x_orange90_x
          • May 2015
          • 702
          Thanks for the clarification. I used my other meter and it displayed the capital M as well, but I did notice the readings started out in K ohm and climbed up into the M range. Is it okay then that they are reading that way or should I suspect an issue with one or more?
          I still need to get a picture of the lines I blocked off on the ribbon. I didn't get a chance to do it last night.
          • x_orange90_x
            • May 2015
            • 702
            lotas
            I'm going to reattempt the tape trick tonight and I'll take a photo of it for you. I'm hoping I can find a bad component on the scaler to fix the issue rather than the tape. If I can FIX it the image will be perfect, but the tape trick will likely cause some lines or something.
            • x_orange90_x
              • May 2015
              • 702
              If none of the capacitors have low resistance (in Om), then they are fine, show where you masked the contacts.
              Attached is a photo of the lines I blocked off. The 4th line is STV, then CKV 8, 7, 6, 5, 4, 3, 2, 1 in that order from left to right. I checked continuity on them to find that's what they are via the test points over each of their resistors. With the tape in place I rechecked and the first untaped one (STV) still has continuity, so I know I blocked off ONLY the clock lines.
              I also checked all of the caps for short to ground and all are ok.
              • lotas
                • Jan 2016
                • 4531
                • Russia
                #47
                Check also VGH, VGL, 3.3v..., there are many more control points there
                • x_orange90_x
                  • May 2015
                  • 702
                  Ok. Do I just check voltage between the test point and ground with it plugged in and turned on?
                  • lotas
                    • Jan 2016
                    • 4531
                    • Russia
                    #49
                    Yes, check it out.
                    • x_orange90_x
                      • May 2015
                      • 702
                      Yes, check it out.
                      All ribbons attached, no tape, and power on:
                      DVDDI = 1.83V
                      HVAA = -3.8mV
                      VAA = -0.376V
                      VCM1 = -0.363V
                      SPI_DI = 120.6mV
                      SCK = 120.3mV
                      SPI_CS = 3.25V
                      SPI_DO = 3.27V
                      VGL1 = -3.0V and increases toward 0
                      VGL2 = -8.93V
                      AVCM = -.362V
                      • x_orange90_x
                        • May 2015
                        • 702
                        Yes, check it out.
                        I noticed my labels are quite different from what would be expected. The only one that sticks out to me is DVDDI. Should be 3.5V and I'm under 2V. What do you think?
                        • x_orange90_x
                          • May 2015
                          • 702
                          I checked the left side voltages with the right side ribbon disconnected and get the following:
                          DVDD1 = 1.83V HVAA= 6.73V
                          VAA= 15.32V
                          VCM1= 4.19V
                          VSS1= -5.03V
                          VSS2= -8.91V
                          AVCM= 4.19V
                          Notice the left has VSS instead of VGL. So clearly I'm missing voltages on the right. If I check the left side with the right ribbon connected I get almost the exact same readings as the right side, so the right side brings down the left when it's connected.
                            • 12094
                            • U.S.
                            #53
                            maybe check all the resistors on the right side.
                            • x_orange90_x
                              • May 2015
                              • 702
                              I previously did a resistance check on all of them and they read correctly. Should I check them another way? I don't understand how blocking the clock signals gives me grey on the right and image on the left, but uncovering just one makes the whole screen black again.
                              • x_orange90_x
                                • May 2015
                                • 702
                                Did I lose you guys?
                                • EazyBone
                                  • Jun 2023
                                  • 1306
                                  • United states
                                  #56
                                  Throw it in the trash
                                  • x_orange90_x
                                    • May 2015
                                    • 702
                                    After watching the following video I think I might dust this TCL off and give this a try!
                                    https://youtu.be/bdw8Mub9ReU?si=a2J11CRKriWQSTZP
                                    If I do this, would I apply 12v to the VCC leg of that IC in order to get a "smoking gun"? About how many amps would be appropriate?
                                    Lastly, do you think this may work on my case? 😁
                                    • x_orange90_x
                                      • May 2015
                                      • 702
                                      Update:
                                      I revisited the tape method and successfully found the clock signals, blocked them, and the end result looks great! I can't see any anything wrong with the picture!
                                      • EazyBone
                                        • Jun 2023
                                        • 1306
                                        • United states
                                        #59
                                        Well at least you got a 4th garage TV 😂 😂
                                        • x_orange90_x
                                          • May 2015
                                          • 702
                                          😆 I have way more than 4 in there! I fix and resell most of them. Just picked up another 55" Samsung 4k last night.. Added to the "needs backlights" pile along with a 55" Element, 50" Toshiba, and 75" Vizio. Funny thing is, I don't even USE a 4k in the house, only 1080p lol can't really tell the difference
                                          It was just nice to save this one finally because I was probably one more garbage day away from evicting it.
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • jb_Bak
                                            by jb_Bak
                                            CN6401
                                            Pin 01 NC
                                            Pin 02 NC
                                            Pin 03 "BL_ON": 0V
                                            Pin 04 "N/C"
                                            Pin 05 "STBY 3.3V": 3.5V
                                            Pin 06 "GND": N/C
                                            Pin 07 "AC_OFF"...
                                            09-27-2021, 04:52 PM
                                          • JDC
                                            (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                                            by JDC
                                            ONN 100012588
                                            Issue: No Power, Then Rebooting After Main Board Change
                                            Short answer: replace main board and power board
                                            Technical answer: replace main board and Q306 & Q307 on power board.
                                            Long answer:
                                            TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                                            07-15-2022, 07:39 AM
                                          • advant
                                            by advant
                                            02-03-2020, 12:25 AM
                                          • Asraf Atb
                                            by Asraf Atb
                                            01-27-2025, 05:02 PM
