TCL 55S451 Blank screen
  • EazyBone
    • Jun 2023
    • 1306
    • United states
    Re: TCL 55S451 Blank screen
    I don't see why not. Could short both sides. You really want this TV to work lol. But yes, good multi meter helps, I figured that out early
    • x_orange90_x
      • May 2015
      • 702
      I have been thinking about this stupid tv again and really wanting to get it figured out. Everyone I see with similar models either have a bad TCON or a bad main board causing the blank screen. In my case I don't have a TCON to replace, though I've replaced the main twice.
      What is the likelihood of THREE main boards being bad and all exhibiting the exact same symptoms?
      I really do want to test the scaler boards but I have no idea where to probe. I've watched several videos of it being done but they're mostly in Hindi language and they never show HOW to IDENTIFY your 12v, 3.3v, etc test points on YOUR OWN tv. Obviously mine will be different from theirs. If I were to post full pictures of the scalers would someone be able to help me identify the test points?
      Edit:
      There is a sticker on one of the scalers with the number PT550GT05-3 on it. Googling that number brings up TCON boards with the same exact number. Maybe that's helpful, maybe it isn't.
      • EazyBone
        • Jun 2023
        • 1306
        • United states
        Just test if any of the capacitors are shorted. Turn multimeter to beep beep and test both sides of each cap on there.
        • x_orange90_x
          • May 2015
          • 702
          I just checked every capacitor on the right side and they all tested good. Beep on one side and not on the other. Didn't check the left side yet but something tells me they'll be good too.
          • x_orange90_x
            • May 2015
            • 702
            Update! I disconnected the right side ribbon and got an image on the left side! I did this probably a dozen times before and didn't get an image but now I do. I checked all of the resistors on that sides scaler and they all tested good, and so did the caps. I pinned out the CKV lines and blocked them off but I just get a gray image on that side and the left side is fine. Is there something else that needs to be taped off along with the clock lines?
            • lotas
              • Jan 2016
              • 4527
              • Russia
              #26
              Post a photo in full, in good quality, of the faulty buffer strip and your photo, which contacts you masked.
              • x_orange90_x
                • May 2015
                • 702
                Here's some photos of that side. I need to get another of the outside edge but this is a start. Also, I used my multimeter on continuity and touched one probe to CKV test point and the other to the pins on the ribbon. I determined it's lines 4-12 and blocked those off, that's how I got the grey screen on that side.
                I also attached a screenshot of the pinout for that chip.
                • lotas
                  • Jan 2016
                  • 4527
                  • Russia
                  #28
                  And you can see this entire bar; this chip is a spi flash.
                  • x_orange90_x
                    • May 2015
                    • 702
                    I will get a photo of the whole bar later when I get home. Is there something specific you're looking for? I can try to get a close up of it if so.
                    • lotas
                      • Jan 2016
                      • 4527
                      • Russia
                      #30
                      Yes, I’m interested in the very edge of this bar, what components are located on it.
                      • x_orange90_x
                        • May 2015
                        • 702
                        Here are the pictures. The one with the black tape is the end you asked about.
                        • lotas
                          • Jan 2016
                          • 4527
                          • Russia
                          #32
                          Yes, now you can see that there are no protective diode assemblies here; you checked the ceramic capacitors for low resistance with the cable disconnected.
                          • x_orange90_x
                            • May 2015
                            • 702
                            I don't think it was unplugged. I can recheck them.
                            • x_orange90_x
                              • May 2015
                              • 702
                              Attached is a picture of the readings I got, going from the left side of the strip to the right. The caps not listed read OL. I'm guessing probably only one cap is bad but pulling down the others? I notice that all that read low are positioned in the middle of the strip instead of near the top where most of the others are.
                              • lotas
                                • Jan 2016
                                • 4527
                                • Russia
                                #35
                                If none of the capacitors have low resistance (in Om), then they are fine, show where you masked the contacts.
                                • x_orange90_x
                                  • May 2015
                                  • 702
                                  Are those readings normal then despite the others reading OL?
                                  I will try to get you a picture of what I masked off. It was on the main board side of the ribbon but that should't matter since I pinned the traces for continuity.
                                  • lotas
                                    • Jan 2016
                                    • 4527
                                    • Russia
                                    #37
                                    Well then, compare with the working strip what resistance they have on the capacitors, you just need to disconnect the cables going to the t-con. You may have masked more contacts than required, and now power is not supplied to the non-working strip, but I don’t see what you masked there, maybe half of the cable is masked there.
                                    • x_orange90_x
                                      • May 2015
                                      • 702
                                      You reminded me just now, I did check them on the working side and they all read OL.
                                      • lotas
                                        • Jan 2016
                                        • 4527
                                        • Russia
                                        #39
                                        I can’t understand what resistance is, what is it in megaohms, milliohms...?
                                        • x_orange90_x
                                          • May 2015
                                          • 702
                                          I can't understand what resistance is, what is it in megaohms, milliohms...?
                                          Here is my meter:
                                          https://www.innova.com/products/hand...10-megohm-3306
                                          It's an auto ranging 10 MegOhm meter. It's "M" not "m" on my display, don't know if that helps.
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • jb_Bak
                                            by jb_Bak
                                            CN6401
                                            Pin 01 NC
                                            Pin 02 NC
                                            Pin 03 "BL_ON": 0V
                                            Pin 04 "N/C"
                                            Pin 05 "STBY 3.3V": 3.5V
                                            Pin 06 "GND": N/C
                                            Pin 07 "AC_OFF"...
                                            09-27-2021, 04:52 PM
                                          • JDC
                                            by JDC
                                            ONN 100012588
                                            Long answer:
                                            07-15-2022, 07:39 AM
                                          • advant
                                            by advant
                                            02-03-2020, 12:25 AM
                                          • Asraf Atb
                                            Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                                            by Asraf Atb
                                            Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                                            Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                                            I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                                            01-27-2025, 05:02 PM
