Sony KD-65x8500b - bad Tcon or panel?
  • rimwall
    • Oct 2023
    • 11
    Hi, hoping for some views on this one which I've not come across before. The TV generates an image that has 12 noticeable bands across it. The image is still there and accurate, but the colour (or perhaps the brightness) changes gradually across each band which creates a noticeable 'step change' at the edge of each band. Given it's a 4K TV with 2160 rows of pixels, I'm guessing the 12 bands correspond to 12 gate drivers of 180 rows each. If this guess is right, then perhaps:
    a) all the gate drivers are malfunctioning the same way (which seems unlikely), or
    b) the Tcon board is malfunctioning, or
    c) something else
    My guess is b), do folks agree? I'm not sure what Tcon malfunction would cause this effect. Maybe not enough power to the gate drivers so the image fades out as it works down the rows?? Which makes me wonder whether if the power board could be the culprit instead...?
    The other thing that might be relevant is that moving images suffer from some degree of retention. So that prior images seem to remain faintly in the background for a little while. Does this imply a problem with the clearing voltage from the Tcon? 15,000 hours on the panel (see service pic) seems a lot but what I read says it should last 40,000+ hours
    I've also attached the TV's Service page. It doesn't seem to suffer from the banding, which is curious. It shows some recent errors associated with the TV tuner, but I doubt if that is related to the image issue, which is the problem I want to fix. There are also some very old errors (2015, 2017, 2020) which can most likely be ignored.
  • EazyBone
    • Jun 2023
    • 1362
    • United states
    Re: Sony KD-65x8500b - bad Tcon or panel?
    Do you have it open? Try disconnecting one of the panel ribbon cables one at a time, plug in and see if the lines go away after doing each one. If you get 1/4 or 1/2 screen picture with out those lines then the panel could be suspect.
    I personally would not see this as a power board issue, but I'm a bit new to TV repair.
    • rimwall
      • Oct 2023
      • 11
      Here are the pics with each ribbon cable removed (only 1 disconnected at a time). Picture order is top right cable removed, top left removed, bottom left removed, bottom right removed. The banding is visible in pics 1,2; maybe not visible in pic3,4. The image retention is visible in pic3.
      Any help greatly appreciated!
        • 12330
        • U.S.
        Not sure but I would try a replacement tcon if it didn't cost too much, some good videos for tcon testing on youtube.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4539
          • Italy - Milan
          TOP and BOTTOM?? never seen a tcon with both sides connected... photograph the rear of tv..
            • 12330
            • U.S.
            Maybe inspect the cable pins and make sure they are clean and none are damaged.
            • lotas
              • Jan 2016
              • 4862
              • Russia
              Like this...
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4539
                • Italy - Milan
                Damn.. how odd!... Is there any testpoint to photograph on tcon? For me it's bad tcon.. but wait..
                • rimwall
                  • Oct 2023
                  • 11
                  Yep, those pics are identical to the TV and Tcon board.
                  It's an LCD.
                  A second hand tcon is about $50 including postage (a big factor in getting boards to Oz). I was just wondering if folks could say for sure that bands for each gate driver meant a bad tcon…
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4539
                    • Italy - Milan
                    I asked for a picture with testpoints.. i see nothing until now.. are you searching a wizard casually?
                    post also the marking of the 2 square chips to the left, the pmic..
                    • rimwall
                      • Oct 2023
                      • 11
                      Thanks for helping, Here's a pic of the Tcon, and what could be test points. What tests did you have in mind? I have an AC/DC digital multimeter.
                      Also a pic of one the two square ICs. Hard to read, but maybe it says ‘TPS, 65162, TI 43K, AXIE G4'.
                      • lotas
                        • Jan 2016
                        • 4862
                        • Russia
                        Wash the entire board with a soft brush in a soapy solution, dry it with a hairdryer, clean all contacts on all cables with isopropyl alcohol, then reassemble and check everything.
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4539
                          • Italy - Milan
                          Check in ohm or replace every condenser on the Sup & Avin pins of TPS ic
                          this tcon design appears almost rubbish, few powerful for a very big tv..
                          • rimwall
                            • Oct 2023
                            • 11
                            Hi, thanks for the suggestions. I cleaned the whole board, connectors and ribbon cable ends with isopropyl alcohol, but the image is the same. I don’t have the equipment to solder these tiny components, so I think I will roll the dice and try another Tcon board. Fingers crossed…!
                            • rimwall
                              • Oct 2023
                              • 11
                              Whoa! Did a bit more fiddling today. Turned it on, same problem with the bands. But service screen didn’t have bands. Figured it *must* be the Tcon. Turned it off. Reconnected all 4 ribbon cables just in case. Turned it on. Seemed a bit darker. Odd. Turned it off. Redid all 4 cables. Turned it on. Tcon board now emitting a faint buzz, and the picture is fine! Buzz is coming from the end of the board near the TPS ICs.
                              So, definitely not the panel, yay! Now I’m wondering… is it the Tcon or the ribbon connection? Is a faint buzz from a Tcon normal? It’s loud enough to hear 1m away from the *front* of the TV (zero TV volume in a totally quiet room).
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4539
                                • Italy - Milan
                                try ohm meter test on each pin of ribbons..
                                • rimwall
                                  • Oct 2023
                                  • 11
                                  Ok, would that test be:
                                  - disconnect ribbon from tcon
                                  - touch ohmmeter leads to adjacent pins on end of ribbon cable
                                  - adjacent pins should not be electrically connected
                                  Or some other test?
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4539
                                    • Italy - Milan
                                    My first thought was that there was not enough current to feed entirely all the gate drivers but the supply faded along the path, this can happen also if there are poor connections, gate drivers does not draw so much current, then if the ribbons are completely detachable you test each trace from input to output pins, not for short circuits, you have to test also each pin of the connectors with ribbons in place, and compare ohm results to find higher ohms, maybe more than less of 1 ohm (before it measure the tester probes short circuit value)
                                    • rimwall
                                      • Oct 2023
                                      • 11
                                      An update in case it’s helpful: TV was good for a couple of years, one day it was left on for 24hours - after that no image and Tcon buzzing became louder. I figured the Tcon overheated and finally died. Replaced Tcon board and everything works. So, it was definitely the Tcon.
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4539
                                        • Italy - Milan
                                        OK, but if you will have problems, remeber to carry the board to service shop and do the cap replaement i said.. also a resolder of TPS ICs, bye..
                                        • rimwall
                                          Sony KD-65x7500D - double image - Tcon or Panel?
                                          by rimwall
                                          This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                                          I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                                          11-18-2025, 02:09 AM
                                        • iglitare
                                          by iglitare
                                          09-04-2025, 07:13 AM
                                        • AK_777
                                          Sony KD-65A1 Repair – 4 Red Blinks Error
                                          by AK_777
                                          Hi everyone!
                                          I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                                          Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                                          02-20-2025, 04:15 PM
                                        • netgearnetgear
                                          TCL 43S423 TCON OR PANEL FAULTY???
                                          by netgearnetgear
                                          Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                                          08-20-2025, 06:04 PM
                                        • swrb898
                                          Sony KD-70X690E Bravia; Bad TCON? Bad panel?
                                          by swrb898
                                          What's wrong with my TV: the TCON, the panel, or something else? I'm stuck.
                                          Problem:
                                          Last week, my Sony KD-70X690E 70" stopped displaying a picture. The TV powers on, and the back lights power on. However, the TV doesn't seem to boot up. I say this because the SONY splash-screen logo does not display, nor does any picture display, nor can I invoke a menu by pressing "Menu" on the remote. Other than back-light bleed, the screen is black.
                                          My troubleshooting got me this far:
                                          With the left-hand TCON to bottom-board ribbon cable...
                                          12-28-2021, 08:12 PM
