EU55JS9000T black screen and sound good
    • 12331
    • U.S.
    #41
    Re: EU55JS9000T black screen and sound good
    It really sucks the way samsung did this model, they made that shitty hot ocb and put absolutely no other connection ports on the tv itself, so they gave the consumer no choice but to use it.
    • totof
      • Feb 2017
      • 186
      • france
      #42
      My work colleague, who owns the TV, told me that one of the seller's selling points was that it would be easy to upgrade the TV and repair it with this external box.
      Except that 8 years later the box no longer exists, it cannot be found even in the Samsung approved repair center.
        • 12331
        • U.S.
        #43
        Just more of samsungs planned obsolescence but many seen this one coming.
          • 12331
          • U.S.
          #44
          I steer clear of any proprietary bs like that ocb cable nonsense, just give me hdmi, rca, component, toslink, usb etc. And put them right on the tv so I don't lose them.
          • lotas
            • Jan 2016
            • 4899
            • Russia
            #45
            https://aliexpress.com/item/1005001530200726.html
            • totof
              • Feb 2017
              • 186
              • france
              #46
              415 euros.
              Much too expensive for my colleague especially for a used card.
              I checked the capacitors for short circuits and found several with low resistance:
              - C373, C377, C381, C382, C383: 36.6 ohm
              - C3318: 0 ohm
              - C1014: 36 ohm
              I'm tracking the shorted C3318 capacitor because it's located just below the OCB connector. I removed it but it's not the one that's shorted.
              • totof
                • Feb 2017
                • 186
                • france
                #47
                I did not understand what C3318 is for in any case there is 12.3V at its terminals and it is connected to the VIN pins of several ICs: Z3013PI, TPS54427 (x2) and TPS106041 (x2)
                This is not the right way.
                Complicated, very complicated (for me)
                  • 12331
                  • U.S.
                  #48
                  415 euros.
                  Check that diode right beside it, go ahead and check it in circuit, see what it reads.
                  • totof
                    • Feb 2017
                    • 186
                    • france
                    #49
                    The diode D3301 is one side connected to GND and other side to B13V from OCB connector.
                    Marking code on the diode is D2 W5n. It is a zener diode but I don't know if it is the good voltage.
                    It seems D2 code is for 3,6V zener diode. I don't know what is W5n.
                    I desoldered the diode and it is identified as a diode with my tester.
                      • 12331
                      • U.S.
                      #50
                      So what did it read?
                      • totof
                        • Feb 2017
                        • 186
                        • france
                        #51
                        Sorry I don't understand your question
                          • 12331
                          • U.S.
                          #52
                          Use a multimeter. Diode mode meter connected in one direction get a voltage drop zeners are usually about .6 volts, meter leads switched and you get OL, 1.
                          • totof
                            • Feb 2017
                            • 186
                            • france
                            #53
                            Yes, I had done this test. 0.74V in one direction and OL in the other direction
                              • 12331
                              • U.S.
                              #54
                              Ok, now hopefully the capacitor is still off the board, check the pads it came off of, does it read short? maybe also check it in ohm mode.
                              • totof
                                • Feb 2017
                                • 186
                                • france
                                #55
                                The pads of the capacitor is still shorted.
                                With the multimeter I read OL for this capacitor, she is not dead.
                                Alas, I would have loved it if she was the one to be hs
                                  • 12331
                                  • U.S.
                                  #56
                                  Read the cap in ohm mode, make sure you have good connection with the probes.
                                    • 12331
                                    • U.S.
                                    #57
                                    If your meter is not auto-ranging you will probably need to adjust the ohm mode to the different settings and see if you get a reading, OL can just mean that your meter isn't set right.
                                      • 12331
                                      • U.S.
                                      #58
                                      I would take the board out of the box and look it over closely from all sides, check for bad solder joints etc.
                                      • totof
                                        • Feb 2017
                                        • 186
                                        • france
                                        #59
                                        I've done this before but didn't see anything unusual.
                                        Without a diagram it's shit
                                          • 12331
                                          • U.S.
                                          #60
                                          Sometimes it can be the components in a circuit that can make things seem shorted, like if there's a resistor in circuit across it, it may read short and be ok, that's why you get the best results off the board.
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • totof
                                            LG 43UF640V backlight good but black screen and no sound
                                            by totof
                                            Good morning.
                                            I have a problem with my LG Smart 43UF640V TV. It starts, the backlight comes on but nothing is displayed on the screen and there is no sound.
                                            I thought it was a TCon problem and ran various tests. If I disconnect one or the other of the cables from the tcon to the panel then the screen is white on the side where the cable is disconnected and black on the other side. If the two cables are disconnected the screen is completely black.
                                            In the 4 configurations I measure exactly the same voltages on the tcon card (model V15 43UHD TM120 Ver0.4) :
                                            HVDD : 7,28...
                                            04-13-2024, 11:37 PM
                                          • Audeze
                                            Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
                                            by Audeze
                                            I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
                                            Does...
                                            10-06-2024, 08:54 PM
                                          • HTR-Informatique
                                            by HTR-Informatique
                                            02-09-2025, 06:51 AM
                                          • VcemPzd
                                            Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                                            by VcemPzd
                                            Hello everyone !
                                            My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                                            04-28-2025, 10:14 AM
