Swan SP0110N electric tin opener, not turning can.
  • fuzzy4
    • Jul 2024
    • 18
    I have this electric tin opener and the part that moves the can round (1st picture), doesn't move, I can hear the motor turning, but no movement, there's something rattling inside, so presume a piece of plastic has broken, or come loose.
    Took the bottom plate off, but left with this (3rd picture), any ideas how to get inside?
    Thanks.
  • CapLeaker
    Leaking Member
    • 8339
    Maybe pry those metal tabs up and take these covers off. Could be that more screws are hidden there.
    • fuzzy4
      • Jul 2024
      • 18
      Thanks.
      I worked it out, the front and back plastic parts side off and are really tight (need a flat head screwdriver), then you can get the metal cover off (undo screws).
      Easy fix in the end.
      • Flaku_34
        Acer Nitro XV273 and Predator XB273, look inside and disassembly guide.
        by Flaku_34
        Introduction:
        Hello everyone, this topic is more of a knowledge sharing and look inside type of post, but for someone working on this model of display it might be useful. Recently I bought Acer Nitro XV273 XB MIIPRZX with busted electronic, but screen was intact, price was incredibly low, so I took a gamble and bought the unit and try to fix it. As I dug inside, I found out that my motherboard was not responding, although all voltages seemed fine. I wasn't able to find any reliable information about this monitor on the web (only some pictures of motherboards from Ebay). By some research...
        04-18-2024, 12:47 PM
      • BOSCHNJAK
        by BOSCHNJAK
        ABOUT ME INTRODUCTION FILE
        2
        024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
        2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
        2022 BEV, PROJECT ?
        2021 BEV, PROJECT ?
        2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
        2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
        12-28-2023, 02:09 PM
      • tibimakai
        Lincoln Electric LE31MP welder not turning on
        by tibimakai
        This is my own welder, that blew up while welding. There is no warranty on it. Purchased it a year ago, sealed box from Craigslist.
        It worked great until now, about a year.
        What I have found is a blown trace next to the main capacitors, it seems like also got damaged the SMPS IC, output MOSFET and a 1 Ohm resistor to the ground from the MOSFET.
        After replacing these components, the relay, fans turn on and it sounds like it's working, but there is no output voltage for the welder, LEDs do not turn on.
        So there are more components that are damaged.
        I'm having a hard...
        10-14-2023, 07:40 PM
      • NicRac
        monowheel repair,Is the diode the problem?
        by NicRac
        Hello everybody☺️ I am glad to be here and looking forward to a good discussion.
        First of all, I am new here. Therefore I will shortly introduce myself.
        I am Nico and currently I study Physics.
        In my freetime I like to build and repair stuff. Especially big battery's.
        A few years ago I got myself an electric unicycle, monowheel or however you call that.
        The battery bms was broken so I replaced and resolder that. Nothing big.
        I used this thing for some years and had a lot of fun. Unfortunately I used it last time in heavy rain. Usually everything...
        07-26-2024, 06:13 AM
      • e-repair
        Broken connector on an electric boat power steering
        by e-repair
        Hey, i have to repair an electronic board on an electric power stearing. the package was damaged during delivery and the connector was broken. but i can't find a part. the connector is the same BUT reversed as fiat power steering. I searched on digikey, mouser and aliexpress and i can't find any part similar. it's an uflex electric power steering, but i don't have more reference on the power steering block. if needed, i can buy any complete part just to recover the conector on the board and put it on this board...
        09-24-2025, 07:30 AM
