Vizio E55-DO firmware corrupted?
  • Lee M.
    • Nov 2021
    • 35
    I was given this set and do not have the original remote. It will turn on with the power button and display "oobe V1.1.12 firmware V0" but that's all it will do. It does not respond to the input select button or volume button. I have a remote from the cable company and programmed it for Vizio and it will turn the set on and off but that's it, no response from any other buttons. The white standby led comes on bright at first and then dims but stays on while the set is on. I pulled the back off and looked for anything obvious like loose connectors, bad solder, bad caps and didn't find anything. Also checked voltages on PS board and they all looked normal. Since the BL's are on and it's displaying a pic and responding to the remote for on and off functions, I'm thinking maybe this is a firmware problem. What do u guys think? thanks, Lee
  • R_J
    • 9588
    Re: Vizio E55-DO firmware corrupted?
    Try updating the firmware using the usb method, current version is 2.0.17
    • Lee M.
      • Nov 2021
      • 35
      I downloaded the firmware, extracted and copied it onto a blank thumb drive. With the set on I plugged the drive into the usb port and nothing happened. I connected an ethernet cable to the set just to see what would happen and now I've got Google pics changing every few min and the correct time displayed. The firmware instructions say to put the set on an input with no signal and I think that may be why it's not updating. When I press the input button on the rear panel nothing happens and I don't have a remote. I also downloaded the smartcast app onto my phone thinking I might be able to control the set with the phone. When I try to pair the phone with the set the phone searches and does not see the set.
      • R_J
        • 9588
        You may need the proper remote control, but I would think the input button on the tv should work, try disconnecting the network cable and see if the input will change, I am not that familiar with this problem but it seems like the tv hardware is working but the firmware has an issue
        • Lee M.
          • Nov 2021
          • 35
          Tried disconnecting the network cable and pressing the input button but it does nothing. When I disconnected the cable the screen went blank and when I reconnected it the google pics came back on. It seems it's stuck in whatever mode displays the google pics. lol I'll order the oem remote tomorrow.
            • 12269
            • U.S.
            Try a simple reset, unplug tv, hold power button on tv for 30 seconds, plug tv in and try it, if you didn't already.
            • Lee M.
              • Nov 2021
              • 35
              Tried it and also tried the other reset where u hold the volume and input buttons down. I think it did reset to the original firmware. I tried to update the firmware with a thumb drive but it not starting the process, it just sits there. I ordered the remote and it should be here by Fri.
              • Lee M.
                • Nov 2021
                • 35
                Got the remote in and it will turn the set on and off but that is it. It looks as if it is not booting up because sometimes when u turn it on it will only show the software version on a black screen. Other times it will show google pics and the correct time. It will change from pic to pic and the whole screen looks great. But that is all it will do. It won't let u select an input. When u hit other buttons like volume up down, channel up down etc. nothing appears on the screen and the set doesn't respond.
                • Lee M.
                  • Nov 2021
                  • 35
                  Here's a couple of screen pics. If the firmware is corrupted like i think it is then why am I able to see google pics?
                  • Lee M.
                    • Nov 2021
                    • 35
                    new main board fixed it.
                    • SluggerB
                      Help with trying to fix phone that is not charging (Pics inside)
                      by SluggerB
                      I have two TCL A30 phones.
                      Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
                      New Phone: Works fine, bought as a donor board to try and repair Old Phone
                      My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
                      08-12-2024, 08:11 AM
                    • keeney123
                      new OS on a Sonim XP5s phone
                      by keeney123
                      To you programmers out there I want to know if it is possible to put a new OS on the Sonim XP5s phone? I only need this phone to make calls, receive calls, have a list of contacts and be able to call voice mail.
                      I bought this phone new Sep.2021 as an unlock phone from a third-party seller. The phone worked fine until Jan 2022. I then had intermittent problems with the sound setting resetting itself. One of the settings, outdoor, would go to silent all by itself. When in silent mode it does not indicate a call has come in. I missed very important phone calls. All the other setting in sound...
                      05-13-2022, 07:19 PM
                    • jason123
                      Vizio D50-F1 - Can't update Software / Firmware
                      by jason123
                      Wondering if any of you have seen this before. I got this TV with lower half of the screen dim. Fixed the LED backlight issue - smooth
                      I noticed that the System update lists current firmware is V1.0.6 and is able to find on the Vizio server 2.60.23-1... it downloads fully.. but instead of restarting, it just goes back to the previous screen "NO SIGNAL - HDMI1"
                      I got the code and followed the update via flash drive - and it does exactly the same thing. Firmware is copied by the TV 100%, and then nothing - instead of restarting, it just goes back to the previous...
                      08-15-2021, 06:48 AM
                    • jesterace
                      Samsung B2030HD IR Remote Receiver Dead, shorted micom?
                      by jesterace
                      I have this TV a small 20 inch that works perfectly except for the IR has stopped. I have confirmed that the remote control is fine and tried an alternative and even tried with IR blaster from phone. Remote 100% ok.
                      Tried installing latest firmware but no change.
                      TV won't respond to remote at all, not even to bring it out of standby. I have to use the touch sensitive front panel to operate, at which point TV is usable albeit with no remote.
                      Tried replacing the IR receiver diode/bulb on front panel and no change so put the old one back. After tracing...
                      10-26-2022, 02:20 AM
