Philips 65PUS6262/12 Graphic Problem Help
  • markolino
    • Mar 2020
    • 108
    • Slovenia
    Hi.
    I bought a Philips TV model: 65PUS6262/12 Used.
    The seller was selling it as not working well. It was almost free.
    I want to fix the TV in some way.
    Namely.. A very interesting error, but very rare.
    The TV turns on and works. I can go to the menu, open smart applications, etc.
    From the very beginning, the graphics were somewhat strange to me... I'm talking about the menu graphics, etc..
    When I want to start the Youtube application, there is a sound but the picture is green! no movement nothing can be seen!
    If I connect to any HDM input, external chromecast. Nothing works either, the picture comes up green or it doesn't detect it at all..
    If I cast from the phone to the TV, the green image appears again
    In short, I noticed that nothing works when it comes to watching videos. The graphics are bad, strange...
    I tried factory reset one 10x but it doesn't work.
    I tried to install the new software via a USB stick.. Again nothing..
    I can't find an older firmware on the internet.. But only the latest version. If you guys can help me in any way.. The TV screen looks nice and whole, nothing damaged, nothing.. It doesn't have any lines or anything, everything b.p. at a glance.
    The previous owner of the TV says that this happened to him once when he wanted to do a factory reset... But I don't believe him...
    Is the Main board broken or is the T-Con board broken ??
    Has anyone had such a problem?
    The video is coming
    Please any clarification regarding this problem..
    Here is video of my TV
    https://www.youtube.com/watch?v=lDWjOLsZl3I
    Thank you
    Marko.
  • William1967
    • Nov 2017
    • 212
    • Netherlands
    Re: Philips 65PUS6262/12 Graphic Problem Help
    Try the reset with the .pkg file that you can find here This upgrade loader resets the EMMC and installs it like new. After upgrading check if all options etc. are still good.
    • markolino
      • Mar 2020
      • 108
      • Slovenia
      if you can help me. how to insert this file ??
      steps? but I only put it on usb or how?
      • markolino
        • Mar 2020
        • 108
        • Slovenia
        A have the problem... How to forced tv upgrade
        Because file. upgrade_loader.pkg not possibile to update from menu of TV
        • markolino
          • Mar 2020
          • 108
          • Slovenia
          managed to do the software update that you told me. but to no avail... of course it's all the same
          • William1967
            • Nov 2017
            • 212
            • Netherlands
            My guess is a broken mainboard, a reset would be the cheapest solution. Little chance the t-con is the problem. Difficult to pinpoint , I have a tool for that but probably you don't.
            • markolino
              • Mar 2020
              • 108
              • Slovenia
              what tool do i need?? I have a multimeter and I also have an ESR meter
              can you give me some advice on how to check if the motherboard is broken?
              Look picture. .. it is possibile to buy mainboard for model 55PUS6262/12 ?? It is compatibile?
              Hire is link.
              https://www.ebay.com/itm/22537810460...mis&media=COPY
              • markolino
                • Mar 2020
                • 108
                • Slovenia
                has anyone ever repaired such a broken board ??????
                Does anyone know if the processor is bad or a capacitor or resistor?? etc..
                is there any thread on the same or similar case as mine??
                • alltvrepairs
                  • Jan 2014
                  • 225
                  • Malta
                  Try the following:
                  5.3 Set Option Code
                  Press the following key sequence on a standard RC transmitter: “062598” directly followed by MENU and “xxx”, where “xxx” is a 3 digit decimal value
                  of the panel type: see column “Set Option Code” in below tab. After resetting the Display Code, restart the set immediately.
                  The Option Code is a 3 digit found on the back plate STICKER of the TV
                  #Example : OPTION CODE 102
                  Good luck
                  • markolino
                    • Mar 2020
                    • 108
                    • Slovenia
                    Originally posted by alltvrepairs
                    Try the following:
                    5.3 Set Option Code
                    Good luck
                    in my case which is the code ??
                    here is a picture.
                      • 12206
                      • U.S.
                      Looks like 037.
                      • markolino
                        • Mar 2020
                        • 108
                        • Slovenia
                        this is this menu.. hmm, I'm looking for where it says xxx
                        • alltvrepairs
                          • Jan 2014
                          • 225
                          • Malta
                          I would exit SAM .
                          Press the following key sequence on a standard RC transmitter: “062598” directly followed by MENU and “037”
                          • markolino
                            • Mar 2020
                            • 108
                            • Slovenia
                            Wherr imput????
                            • markolino
                              • Mar 2020
                              • 108
                              • Slovenia
                              aaa, here, I figured out how. the tv turns off after your combination.
                              but without success. I turn it back on and nothing
                              of course it remains the same
                              • markolino
                                • Mar 2020
                                • 108
                                • Slovenia
                                this topic can be closed.
                                I bought another main board and solved the problem
                                thank you for your help
                                • jimbofz
                                  • Apr 2013
                                  • 539
                                  i would love to know if the board you bought for your 65 inch tv
                                  was replaced with board from 55inch model?
                                  ive been searching for 715G 8709 M0E B00 005N
                                  for my 65 inch :65pus6162/05
                                  i have seen same board number but from 55inch version for sale
                                  but thaught it was not compatible ,due to screen size
                                  im hoping perhaps it is
                                  • markolino
                                    • Mar 2020
                                    • 108
                                    • Slovenia
                                    no unfortunately for you I got the main board from the same TV model 65PUS6262/12
                                    but I think that it could also make plates from the 55 inch model as long as it has the same model code.
                                    what is wrong with your board?? did you open your thread?
                                    • markolino
                                      • Mar 2020
                                      • 108
                                      • Slovenia
                                      Hir you have board for you tv 65PUS6162/12
                                      Look the link
                                      https://www.lcd-onderdelen.nl/a-5403...0/#description
                                      • markolino
                                        • Mar 2020
                                        • 108
                                        • Slovenia
                                        • jimjoe123
                                          LCD TV Green/Pink screen problem
                                          by jimjoe123
                                          I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                                          Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                                          Then each time...
                                          02-23-2020, 01:29 AM
                                        • janos6662000
                                          Philips 47PFS7509/12 LCD TV problem
                                          by janos6662000
                                          Hi
                                          I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                                          When i applied cable signal to check image, i had normal picture, but TV was restarting.
                                          I downloaded original firmware and applied the update, but the problem remained.
                                          From a colleague i received a "factory package software" which is a lot bigger.
                                          I made another firmware update, but still did not solve the problem.
                                          Somewhere on the way the error got worse, because at the moment the...
                                          08-12-2025, 12:54 PM
                                        • courtcircuit
                                          Philips HTS8000 home cinema noise problem
                                          by courtcircuit
                                          Hello
                                          I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
                                          Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
                                          Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
                                          I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
                                          Removed each of tyhe boards
                                          02-08-2025, 08:22 AM
                                        • theone111
                                          by theone111
                                          3. Problem: TV shuts down
                                          07-22-2024, 10:36 AM
                                        • bohaboha
                                          PHILIPS 32pfl3403d Flat-panel TV Upgrade Assistant problem
                                          by bohaboha
                                          Hi trying to update my Philips cause in retail mode not possible to get out from it i get this message in update site : Error message: no data exception. Your reference: Request ID (server_1930105)
                                          how to fix it thanks
                                          02-05-2025, 09:23 PM
