Sony kdl 40ex720 firmware update
As you can read above I made the update a chinese 4GB MBR FAT32 stick. Copied the above folder into its root, and attached it to the TV in power off. Pushed the connector to the mains, the TV was in out of order state. Then I pushed power+source together on TV tast, and then started to blinking Y-G led and the stick too, it started update immediately. If stick blinking continously Wait for long time. I think it restarted 2 times and finally started with baclight and normal working.
(I think the most important that the TV let in Y-G blinking state, the update will start if usb attached before or later.)Comment
So i have to put the folder with the file inside on the root of the usb stick or just the bin file?Comment
but this is for 32ex420
my tv is 40ex720
is same?Comment
by dkneyleDiagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about... -
by madyoyoHello everyone.
I replaced the mainboard on a KDL60w685a, and now it blinks green and yellow. I think i need to update the firmware. But it's not available from Sony website.
Does anyone have the firmware for this TV? -
by thesteveSo I bought another main board from eBay and the same thing happened.
I got the firmware file from the Sony website. My model was listed and everything matched.
sony_tvupdate_2011_4027_aaa_auth.zip was the file.
Extracted to a folder: "sony_dtv0FA10A01A0A1_00000301"
with file: 00000301_07e8046a.bin inside.
Loaded it into the root of an otherwise empty USB thumbnail bought from around the same time as the TV. Not too old, not too new.. under 2Gig.
The file reads perfectly. Lots of "disk activity"... -
by ahmedtouHi everyone,
help me please
I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
I will share all the details with you, including the disc information.
...Code:HL-DT-ST BD-RE GGW-H20N XA02 (ATA) Current Profile: BD-R Disc Information: Status: Empty State of Last Session: Empty Erasable: No Free Sectors: 12,219,392 Free Space: 25,025,314,816 bytes Free Time: 2715:27:17 (MM:SS:FF) Next
by TheUserHello to everyone ,
This is my first post here, and i would like to share with you a small story in case you can help me.
Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help... - Loading...
