Sony kdl 40ex720 firmware update
(I think the most important that the TV let in Y-G blinking state, the update will start if usb attached before or later.)Comment
So i have to put the folder with the file inside on the root of the usb stick or just the bin file?Comment
by dkneyleDiagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about... -
by madyoyoHello everyone.
I replaced the mainboard on a KDL60w685a, and now it blinks green and yellow. I think i need to update the firmware. But it's not available from Sony website.
Does anyone have the firmware for this TV? -
by thesteveSo I bought another main board from eBay and the same thing happened.
I got the firmware file from the Sony website. My model was listed and everything matched.
sony_tvupdate_2011_4027_aaa_auth.zip was the file.
Extracted to a folder: "sony_dtv0FA10A01A0A1_00000301"
with file: 00000301_07e8046a.bin inside.
Loaded it into the root of an otherwise empty USB thumbnail bought from around the same time as the TV. Not too old, not too new.. under 2Gig.
The file reads perfectly. Lots of "disk activity"... -
by TheUserHello to everyone ,
This is my first post here, and i would like to share with you a small story in case you can help me.
Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help... -
by rumpumpel1Lenovo System Update offered me an update for the firmware of the Folio keyboard for my X12 Detachable Gen 1. The update got stuck and after 20 minutes I switched off the laptop. Since then, the keyboard and touchpad have been without function. Does anyone know how I can revive it?10-24-2024, 08:59 AM
- Loading...
