Samsung 65" UE65TU7000KXXU VER:02/UTU7000 TV Blue screen
  • lotas
    • Jan 2016
    • 4656
    • Russia
    #61
    Re: Samsung 65" UE65TU7000KXXU VER:02/UTU7000 TV Blue screen
    Originally posted by Davi.p
    but which code, BN41- or BN94- ?
    Post 28 has it all.
    • gbbradshaw
      • Feb 2023
      • 55
      • United Kingdom
      #62
      Iotas is right. Bn94-15304y
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4366
        • Italy - Milan
        #63
        no, i asked which code he has searched, if the good one or not.. BN94 is the good one..
        my curiosity, has someone done house works , using heavy tools, drills , demolitions and so on the days the defect happened?
        • gbbradshaw
          • Feb 2023
          • 55
          • United Kingdom
          #64
          Not that I know off. After getting so much information from here, my good guess is that he ( the local tech )has probably tried to fix it by working with the u ribbon cable and eventually totally damaged the main board. That's why my tv went from normal image but with horizontal stall lines to full blue.
          • gbbradshaw
            • Feb 2023
            • 55
            • United Kingdom
            #65
            I forgot I had a picture of it before.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4366
              • Italy - Milan
              #66
              yes, clearly a panel defect, the same and today old gate driver defect.. only masking tape can work
              you must mask a series of 8 subsequent pins on one of the two flat cables starting from the outer side, at random
              • gbbradshaw
                • Feb 2023
                • 55
                • United Kingdom
                #67
                I understand. Going from left or right to the middle of each cable. 8 at once. Should I try that before swapping the main board ?
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4366
                  • Italy - Milan
                  #68
                  the main board is good
                  • gbbradshaw
                    • Feb 2023
                    • 55
                    • United Kingdom
                    #69
                    Update: before leaving home, I have managed to swap the main board and now I have the image back! Yeey ! So the main board was damaged. But I still get the lines. If I remove one of the u ribbon I get the following image.
                    I will have to try your method of masking the 8 subsequent pins tomorrow.
                    Picture 1 - without removing the flex ribbon
                    Picture 2 - with the flex ribbon removed
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4366
                      • Italy - Milan
                      #70
                      the bad side is the right side
                      • gbbradshaw
                        • Feb 2023
                        • 55
                        • United Kingdom
                        #71
                        I am afraid I have only removed the u ribbon from right side as I ran out of time to do so for the left side aswell
                        I will try this tomorrow. So patch 8, then another 8, only from on side of the u ribbon, until it gets fixed? Please look at picture.
                          • 12206
                          • U.S.
                          #72
                          Despite what one member says, lines on the screen even lots close together doesn't instantly mean a bad panel, it could be as simple as a bad cap on panel driver boards which technically is a bad panel, or cap on mainboard or cap on powerboard or something else on one of the boards, those who jump to conclusions quickly, NEVER make good troubleshooters AND they are sooo f@#king irritating.
                          • gbbradshaw
                            • Feb 2023
                            • 55
                            • United Kingdom
                            #73
                            Despite what one member says, lines on the screen even lots close together doesn't instantly mean a bad panel, it could be as simple as a bad cap on panel driver boards which technically is a bad panel, or cap on mainboard or cap on powerboard or something else on one of the boards, those who jump to conclusions quickly, NEVER make good troubleshooters.
                            I completely agree with you, but there's nothing else I can do but try things. So far, the only thing that worked was changing the MB, now I got back to having an image. I would also change the caps on the lower boards where the the flex ribbon connects, but honestly I don't see which caps are they or the name, so I can order some.
                            • gbbradshaw
                              • Feb 2023
                              • 55
                              • United Kingdom
                              #74
                              Like the one in the pic
                              • Diah
                                • Feb 2013
                                • 6397
                                show us clear photo of the left side panel puffer boards when u look on it from back side
                                  • 12206
                                  • U.S.
                                  #76
                                  No it's not you Gbb, it's that goofy guy that keeps crying panels shorted every time he sees a line or two, which it could be a bad panel but could also be a LOT of other things as well, we all know his name.
                                  • gbbradshaw
                                    • Feb 2023
                                    • 55
                                    • United Kingdom
                                    #77
                                    First two pics are from the left side of the tv as you look from the back ( right side front)
                                    Last two are from the right side of the back( left side front)
                                    I hope when you said puffer boards, you meant this.
                                    • Diah
                                      • Feb 2013
                                      • 6397
                                      thx for photos
                                      sorry to say.. your hand very heavy at work.... u keep it so no fix.. or u try while it on. smoothly make pressure on the u ribbon or in the cofs ribbon which goes to lcd from both side.. if u find any better change.. try to fix it by load.
                                      • gbbradshaw
                                        • Feb 2023
                                        • 55
                                        • United Kingdom
                                        #79
                                        thx for photos
                                        Sorry but I don't really get what you say in the first two lines. I must be tired
                                        • Diah
                                          • Feb 2013
                                          • 6397
                                          are you heavy weight person lol..... the place were u worked before on u ribbon... i can see there are signs
                                          if you were slim which i don't think so... then sorry ignore what i wrote. lol
                                          • mar1in
                                            Samsung TU8000, backlight and sound on, stuck in blue screen
                                            by mar1in
                                            I've got this Samsung here that would be stuck in a boot loop.
                                            After opening up and doing the tape block method, I was able to get it to turn on and play sound from the HDMI input, but with a blue screen.
                                            Does that mean there is another combination of pins that I need to block in order to get a picture, or is there something more serious, faulty mainboard or faulty panel?
                                            Thanks in advance
                                            11-08-2023, 05:43 PM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • Chrissygizmo
                                            by Chrissygizmo
                                            02-10-2025, 12:33 AM
                                          • Chrissygizmo
                                            samsung galaxy ao2s very temperamental after screen replaced
                                            by Chrissygizmo
                                            Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                            Ive eventually managed to get it on and working but it's very temperamental...
                                            The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                            05-26-2024, 12:05 AM
                                          • bohaboha
                                            Samsung UE70TU6905 BACKLIGHTS AND SOUND ON NO PICTURES BUT SCREEN NOT DARK
                                            by bohaboha
                                            Hi it looks like everything works don't know where to test except the 390v in the 2 capacitor in the hot side of the power supply and the weird 180v in the diodes in the cold side that should be discharged it is writin on the circuit no more you can read what is written on the circuit quite srrange color mixiing yellow and white
                                            anyhow i couldn't t read anything else
                                            the backlight is on strong and the screen does not get dark or very dark but no pictures
                                            the mainborad feels a bit hott on the black part i test it to 52 degree's against 34 to 40 on the rest of it
                                            01-02-2025, 08:04 PM
