Samsung 65" UE65TU7000KXXU VER:02/UTU7000 TV Blue screen
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4456
    • Italy - Milan
    #101
    Re: Samsung 65" UE65TU7000KXXU VER:02/UTU7000 TV Blue screen
    bad leds..
    • howardc64
      • Jun 2017
      • 636
      Originally posted by gbbradshaw
      Hi everyone.
      I had to reopen this thread as now I've encountered another problem with the tv.
      Basically the tv works but the brightness Is at its lowest possible and the screen flickers. I can see the image in the dark room but only then. I have tried to lower the brightness and also turned the automatic brightness off.
      The things I've tested are:
      -plugged of the pcb and start the tv, but still same issue
      -started the tv without the led connected plugged in, same
      -tested the power that comes out from the power board to the led connector. I am getting 286v on the first pin 1+ and just that, the rest shows 0 voltage. With or without the led connector in.
      Is this likely to be the power board needs replacing?
      Please see the image attached with the power board.
      Did you unplug the cable between main<->PSU and plug in AC cord? This will light up the backlights if its working (screen will be dark due to LCD off but will see backlight shining through the holes in the middle chassis.
      Is the flickering like a brightness strobing effect? I have this on a US version of 65TU7000 but not dimmed picture. My issue was a noisy VCST
      https://www.badcaps.net/forum/showpo...08&postcount=6
      • gbbradshaw
        • Feb 2023
        • 55
        #103
        hi,
        yes i did. nothing changed, and yes, like a brightness strobing effect. sometimes looks brighter . if you look down the holes in the chassis you can see the light "strobing"
        • Diah
          • Feb 2013
          • 6435
          masking Panel CKV never being solution.. the side effect range are huge.
          • gbbradshaw
            • Feb 2023
            • 55
            #105
            You might be right, but i don't really think this is what caused the problem. The problem was that the screen was set on full brightness all the time and this made the led fail (probably burnt led).haven't got the suction cups to remove the screen and check
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4456
              • Italy - Milan
              #106
              No... i think defenitely no.. this set has been hit by a overvoltage, those can destroy many parts of a tv at same time, already seen so many times.. plus some effects of o.v. damage can show with delay..
              • gbbradshaw
                • Feb 2023
                • 55
                #107
                There was an overvoltage in my area couple of weeks ago, but didn't notice anything damaged in thr house.
                OK, so what's to be done? First check for burnt led
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4456
                  • Italy - Milan
                  #108
                  build a simple tester, YouTube is full of projects, power resistor and a diode britdge, 2 components, if led are bad replace led bars
                  • Donny2derby
                    • Apr 2023
                    • 228
                    • Uk
                    #109
                    With this in mind Diah, what's the proper solution to blocking these lines so that other issues don't crop up.
                    • mar1in
                      Samsung TU8000, backlight and sound on, stuck in blue screen
                      by mar1in
                      I've got this Samsung here that would be stuck in a boot loop.
                      After opening up and doing the tape block method, I was able to get it to turn on and play sound from the HDMI input, but with a blue screen.
                      Does that mean there is another combination of pins that I need to block in order to get a picture, or is there something more serious, faulty mainboard or faulty panel?
                      Thanks in advance
                      11-08-2023, 05:43 PM
                    • Mgiffune
                      by Mgiffune
                      06-09-2024, 10:28 AM
                    • Chrissygizmo
                      by Chrissygizmo
                      02-10-2025, 12:33 AM
                    • Chrissygizmo
                      samsung galaxy ao2s very temperamental after screen replaced
                      by Chrissygizmo
                      Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                      Ive eventually managed to get it on and working but it's very temperamental...
                      The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                      05-26-2024, 12:05 AM
                    • bohaboha
                      Samsung UE70TU6905 BACKLIGHTS AND SOUND ON NO PICTURES BUT SCREEN NOT DARK
                      by bohaboha
                      Hi it looks like everything works don't know where to test except the 390v in the 2 capacitor in the hot side of the power supply and the weird 180v in the diodes in the cold side that should be discharged it is writin on the circuit no more you can read what is written on the circuit quite srrange color mixiing yellow and white
                      anyhow i couldn't t read anything else
                      the backlight is on strong and the screen does not get dark or very dark but no pictures
                      the mainborad feels a bit hott on the black part i test it to 52 degree's against 34 to 40 on the rest of it
                      01-02-2025, 08:04 PM
