LG55UH615T pulsating Redstanby LED
  • wushumike
    • Jun 2016
    • 41
    • singapore
    LG model 55UH615T when plug into AC, the Red standby light pulsating slowly. Not sure if it is logic board or power supply.
    Troubleshoot Power board as follows.
    1. Connect to AC source
    2. Measuring P201 connector, there are 7.8V from the 5 pins.... assuming this is the standby voltage.
    3. Connect the 7.8V via a 1K resistor to PWR_ON pin, the output change to 13.2V ....so I would assume the power is correct.
    4.There is no 186Vdc for the backlight.... Not sure if this should turn on with step 3.
    5. Voltage across the two caps is 284Vdc..
    6. Any expert in this power supply ?
    7 What would be the likely problem,... or could it be the logic board ?!
  • wushumike
    • Jun 2016
    • 41
    • singapore
    Re: LG55UH615T pulsating Redstanby LED
    Update on further testing.
    I have disconnect the backlight connection and try power on. Now the standby LED is normal..... it only blink when I connect back the backlight connector. I would assume that the motherboard is working because without the backlight connector, I can see faint image with torchlight shining on screen.... although no sound, but could be the tv setup... not sure because difficult to run setup without light....
    Any expert to comment ?
    • nomoresonys
      • 12328
      • U.S.
      ok, same test, cable from powerboard to mainboard UNHOOKED, resistor from standby to power on and add 2 more resistors from standby to both pdim 1 and pdim2, retry see if that 186 voltage goes higher and if the backlights come on and stay on.
      • wushumike
        • Jun 2016
        • 41
        • singapore
        As per instruction, without connecting motherboard and pull up PWR_ON, PDIM1, PDIM2 and with backlight connected, NOT lighted up....
        I remove the backlight connector to measure voltage of LED+ with reference to chassis ground. Pin 7 (LED+) = 30VDC ; Pin 1 (LED+) = 300Vdc.
        There are two pairs wires both LED+/LED- ....... the copper trace LED+ is common, but the LED- is not.
        I do not have a LED backlight tested so no able to check the LED strips...
        • nomoresonys
          • 12328
          • U.S.
          seems like a backlight issue, what was the voltage across those caps with those jumpers in place? careful HIGH voltage there.
          • Storyteller12
            • Jun 2020
            • 625
            These TVs have a lot of bad backlight issues. Sad part is only 1 led has to go bad for the whole tv to shut down.
            Replacing backlights and turning the backlight setting down usually solves the issue. You can also modify the board to lower the amps to the backlights.
            There is a thread that describes the process
            • wushumike
              • Jun 2016
              • 41
              • singapore
              As I have did a preliminary check on the power board backlight related component, all seems to be OK... and also when I remove the backlight connector, the stand-by light is back to normal.... it can turn on and also can see faint image with torchlight test.
              Anyway I have decided not to waste money and time on this TV, I have decided to go thru the tedious way and remove the panel to physically check the backlight led. ( Just to satisfy my curiosity and doubt)
              Voila.... the right side LED was burnt at the very end.... I will get a new pair of the LED strip and try installing back.... Hopefully I don't break the LCD panel along the way... Will update
              • wushumike
                • Jun 2016
                • 41
                • singapore
                Kudos.... You are absolutely right. As I do not wish to spend too much time and money on this TV, I remove the LCD panel to check if it is really the LED problem.
                Upon dismantling, the right side LED strip was burnt at the very end... I have remove and physically check both strip to see what is the extend of the damage. The left strip all LEDs are OK. For the right side, apart from the burnt end, in between there are a few shorted LEDs.
                I would assume the power board sense that the voltage or current drawn is not correct and trigger a fault signal.
                P.S. As there are two sets of LEDs, left and right. I did try powering individual strip by removing one set from the connector. It didnt work although I assume half of the screen would light up.
                • Diah
                  • Feb 2013
                  • 6552
                  yours Photo ... its look to me not LED defect... but connection defect to the next or to return line on same strip.. easy can be repaired .
                  • wushumike
                    • Jun 2016
                    • 41
                    • singapore
                    After replacing both LED backlight. The power board seems to be damage too because the backlight still not lighted up.
                    Searched and bought an old power board from China seller...fixed to the TV, one side light up normal but another side the LED is dim. Attached photo.
                    P.S. Initially I thought was the new backlight LED giving problem, I swap the pair of LED of left to right side and now the right side brighten up and normal.
                    Anyone can advice if it is this replacement board is also faulty?... The measured voltage again chassis ground is Pin 7= 269V ; Pin5= 117V ; Pin 3=269V ; Pin1=106V
                    Is there any repair recommendation rather then getting another unknown condition board from CN.
                    Power Board: EAX66944001(1.4)
                    LG P/N EAY64388821
                    TV Model : 55UH615T-TB
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4535
                      • Italy - Milan
                      Power on pin must not exceed 5v, with one resistor you can't decrease voltage, two resistors needed..voltage divider, 13v> 3v, 13v--W---3v---W---0v, 13v -- 3,3kohm -- 3v -- 1kohm -- 0v
                      ..and also.. never connect a 7v/13v to any other pins, like pdim! Must decrease voltage before..
                      who has suggested you has probably broke your precious board!
                      • wushumike
                        • Jun 2016
                        • 41
                        • singapore
                        I bought a second hand power board from CN.... all working except the right backlight LED is very dimly lited
                        When replace, the right side backlight LED is dimmer....and the Left side is OK...
                        Initially I thought the new LED strips are giving problem... so I swap the pair of LED ie left connection to right connection.... Now the one that was dim lights up without problem..... So to say the backlight LED is not the problem
                        I'm not sure if this second hand power board is faulty or not.... but then again, the backlight LED strips both are tested OK
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4535
                          • Italy - Milan
                          ah ok now is clear , yes it seems no good power board..
                          • wushumike
                            • Jun 2016
                            • 41
                            • singapore
                            Many time getting old boards from CN reseller is a gamble because they dont usually test the boards if is OK .....This is the second time I encountering.....Previous repair I bought a samsung ps....so badly repaired and not working and they refuse to refund...bought again from another supplier and it works.
                            • wushumike
                              • Jun 2016
                              • 41
                              • singapore
                              Any sugguestion for repair? ... The right and left sets of LED are common LED+ but the return path goes separate ways for this power board.
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4535
                                • Italy - Milan
                                probably the backlight manager ic is no good , post a clear picture of the back of board, if the return wire goes directly to ic then ic is bad, instead if it goes to a separate mosfet it can be bad too
                                • wushumike
                                  • Jun 2016
                                  • 41
                                  • singapore
                                  Picture showing the backlight section...is the set LED +/- on the right side that is problematic
                                  • nomoresonys
                                    • 12328
                                    • U.S.
                                    try something simple, like cleaning and reseating the ribbon cables.
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4535
                                      • Italy - Milan
                                      in your last photo, check those 2 to252 mosfets, if them are ok repkace ic801
                                      • lotas
                                        • Jan 2016
                                        • 4842
                                        • Russia
                                        Throw the wires on the cable, and you will find out where the problem is in the power supply or in the LED bar.
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • KYBOSH
                                          Trying to Save - Samsung 65" The Frame (QN65LS03B) with no signs of life (One Connect Box)
                                          by KYBOSH
                                          I picked this one up today.
                                          Previous owner says no signs of life.
                                          TV looks immaculate and its a 2022 model year so I thought maybe the one connect cable was damaged.
                                          Got it home and put it on the Kill-A-Watt power meter and it was completely dead.
                                          The TV model is QN65LS03BAFXZA - version: CB06
                                          The One Connect Box BN44-01066D / BN96-54788Q / BN39-02470A.
                                          I immediately remembered EazyBone's Samsung The Frame TV no power....One Connect thread and am preparing myself to tear the One Connect open and hunt for dead parts.
                                          Will keep you all...
                                          04-05-2025, 08:32 PM
                                        • fharris1977
                                          Vizio D50u-D1 Dead Set No Standby
                                          by fharris1977
                                          Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                          12-28-2023, 10:25 AM
                                        • An-klamm
                                          Samsung 55HU8590 UE55HU8590 maybe one connect box ocb
                                          by An-klamm
                                          Hello!
                                          I have a TV that I can't get any further with.
                                          It is a Samsung UE 55HU8590 with one connect box.
                                          When I turn on the TV without the one connect box, the animation on the TV tells me to connect the ocb.
                                          As soon as I connect it, the TV restarts (panel goes dark) and the TV tries to start continuously (relay on the SMPS clicks about every 3 seconds).
                                          Since the TV works without ocb, I assume that it can't be the PSU?!
                                          I have measured all contacts of the one connect cable against GND on the ocb board and there is no short circuit anywhere.
                                          Is there...
                                          12-04-2023, 01:35 AM
                                        • ChristianBr01
                                          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                          by ChristianBr01
                                          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                          04-23-2025, 01:48 AM
