LG55UH615T pulsating Redstanby LED
  • wushumike
    • Jun 2016
    • 41
    • singapore
    LG model 55UH615T when plug into AC, the Red standby light pulsating slowly. Not sure if it is logic board or power supply.
    Troubleshoot Power board as follows.
    1. Connect to AC source
    2. Measuring P201 connector, there are 7.8V from the 5 pins.... assuming this is the standby voltage.
    3. Connect the 7.8V via a 1K resistor to PWR_ON pin, the output change to 13.2V ....so I would assume the power is correct.
    4.There is no 186Vdc for the backlight.... Not sure if this should turn on with step 3.
    5. Voltage across the two caps is 284Vdc..
    6. Any expert in this power supply ?
    7 What would be the likely problem,... or could it be the logic board ?!
  • wushumike
    • Jun 2016
    • 41
    • singapore
    Re: LG55UH615T pulsating Redstanby LED
    Update on further testing.
    I have disconnect the backlight connection and try power on. Now the standby LED is normal..... it only blink when I connect back the backlight connector. I would assume that the motherboard is working because without the backlight connector, I can see faint image with torchlight shining on screen.... although no sound, but could be the tv setup... not sure because difficult to run setup without light....
    Any expert to comment ?
      • 12210
      • U.S.
      ok, same test, cable from powerboard to mainboard UNHOOKED, resistor from standby to power on and add 2 more resistors from standby to both pdim 1 and pdim2, retry see if that 186 voltage goes higher and if the backlights come on and stay on.
      • wushumike
        • Jun 2016
        • 41
        • singapore
        As per instruction, without connecting motherboard and pull up PWR_ON, PDIM1, PDIM2 and with backlight connected, NOT lighted up....
        I remove the backlight connector to measure voltage of LED+ with reference to chassis ground. Pin 7 (LED+) = 30VDC ; Pin 1 (LED+) = 300Vdc.
        There are two pairs wires both LED+/LED- ....... the copper trace LED+ is common, but the LED- is not.
        I do not have a LED backlight tested so no able to check the LED strips...
          • 12210
          • U.S.
          seems like a backlight issue, what was the voltage across those caps with those jumpers in place? careful HIGH voltage there.
          • Storyteller12
            • Jun 2020
            • 624
            These TVs have a lot of bad backlight issues. Sad part is only 1 led has to go bad for the whole tv to shut down.
            Replacing backlights and turning the backlight setting down usually solves the issue. You can also modify the board to lower the amps to the backlights.
            There is a thread that describes the process
            • wushumike
              • Jun 2016
              • 41
              • singapore
              As I have did a preliminary check on the power board backlight related component, all seems to be OK... and also when I remove the backlight connector, the stand-by light is back to normal.... it can turn on and also can see faint image with torchlight test.
              Anyway I have decided not to waste money and time on this TV, I have decided to go thru the tedious way and remove the panel to physically check the backlight led. ( Just to satisfy my curiosity and doubt)
              Voila.... the right side LED was burnt at the very end.... I will get a new pair of the LED strip and try installing back.... Hopefully I don't break the LCD panel along the way... Will update
              • wushumike
                • Jun 2016
                • 41
                • singapore
                Kudos.... You are absolutely right. As I do not wish to spend too much time and money on this TV, I remove the LCD panel to check if it is really the LED problem.
                Upon dismantling, the right side LED strip was burnt at the very end... I have remove and physically check both strip to see what is the extend of the damage. The left strip all LEDs are OK. For the right side, apart from the burnt end, in between there are a few shorted LEDs.
                I would assume the power board sense that the voltage or current drawn is not correct and trigger a fault signal.
                P.S. As there are two sets of LEDs, left and right. I did try powering individual strip by removing one set from the connector. It didnt work although I assume half of the screen would light up.
                • Diah
                  • Feb 2013
                  • 6376
                  yours Photo ... its look to me not LED defect... but connection defect to the next or to return line on same strip.. easy can be repaired .
                  • wushumike
                    • Jun 2016
                    • 41
                    • singapore
                    After replacing both LED backlight. The power board seems to be damage too because the backlight still not lighted up.
                    Searched and bought an old power board from China seller...fixed to the TV, one side light up normal but another side the LED is dim. Attached photo.
                    P.S. Initially I thought was the new backlight LED giving problem, I swap the pair of LED of left to right side and now the right side brighten up and normal.
                    Anyone can advice if it is this replacement board is also faulty?... The measured voltage again chassis ground is Pin 7= 269V ; Pin5= 117V ; Pin 3=269V ; Pin1=106V
                    Is there any repair recommendation rather then getting another unknown condition board from CN.
                    Power Board: EAX66944001(1.4)
                    LG P/N EAY64388821
                    TV Model : 55UH615T-TB
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4333
                      • Italy - Milan
                      Power on pin must not exceed 5v, with one resistor you can't decrease voltage, two resistors needed..voltage divider, 13v> 3v, 13v--W---3v---W---0v, 13v -- 3,3kohm -- 3v -- 1kohm -- 0v
                      ..and also.. never connect a 7v/13v to any other pins, like pdim! Must decrease voltage before..
                      who has suggested you has probably broke your precious board!
                      • wushumike
                        • Jun 2016
                        • 41
                        • singapore
                        I bought a second hand power board from CN.... all working except the right backlight LED is very dimly lited
                        When replace, the right side backlight LED is dimmer....and the Left side is OK...
                        Initially I thought the new LED strips are giving problem... so I swap the pair of LED ie left connection to right connection.... Now the one that was dim lights up without problem..... So to say the backlight LED is not the problem
                        I'm not sure if this second hand power board is faulty or not.... but then again, the backlight LED strips both are tested OK
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4333
                          • Italy - Milan
                          ah ok now is clear , yes it seems no good power board..
                          • wushumike
                            • Jun 2016
                            • 41
                            • singapore
                            Many time getting old boards from CN reseller is a gamble because they dont usually test the boards if is OK .....This is the second time I encountering.....Previous repair I bought a samsung ps....so badly repaired and not working and they refuse to refund...bought again from another supplier and it works.
                            • wushumike
                              • Jun 2016
                              • 41
                              • singapore
                              Any sugguestion for repair? ... The right and left sets of LED are common LED+ but the return path goes separate ways for this power board.
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4333
                                • Italy - Milan
                                probably the backlight manager ic is no good , post a clear picture of the back of board, if the return wire goes directly to ic then ic is bad, instead if it goes to a separate mosfet it can be bad too
                                • wushumike
                                  • Jun 2016
                                  • 41
                                  • singapore
                                  Picture showing the backlight section...is the set LED +/- on the right side that is problematic
                                    • 12210
                                    • U.S.
                                    try something simple, like cleaning and reseating the ribbon cables.
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4333
                                      • Italy - Milan
                                      in your last photo, check those 2 to252 mosfets, if them are ok repkace ic801
                                      • lotas
                                        • Jan 2016
                                        • 4613
                                        • Russia
                                        Throw the wires on the cable, and you will find out where the problem is in the power supply or in the LED bar.
                                        • ohren
                                          by ohren
                                          09-08-2023, 05:24 PM
                                        • Crystaleyes
                                          Samsung BN44-00259A standby question
                                          by Crystaleyes
                                          Hi all.
                                          I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                                          SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                                          Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                                          The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                                          08-11-2023, 05:15 AM
                                        • Yanleb
                                          LG 60PK550 Logic Control Board EBR63450301
                                          by Yanleb
                                          Hi all, I just want to share the repair of my 60PK550-UA TV set.
                                          The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                                          But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                                          All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                                          C57: 3.30V
                                          C61:...
                                          07-20-2023, 12:38 AM
                                        • Scoff
                                          LG55UB850V no picture or audio - flashing LED's help please?
                                          by Scoff
                                          Hi, I'm looking for some help with attempting to troubleshoot and hopefully repair my trusty LG55" TV.
                                          I'm reasonably comfortable working with electronics, but far from expert level! I have more experience with auto-electrics than anything.
                                          We recently had a power cut while the TV was on, and since then, when the TV is switched on at the wall, the red standby light comes on like normal. Then. when you press the power button on the remote or the TV to switch it on from standby, the standby light flashes 3 times and then goes out. There is no audio or video at...
                                          01-26-2022, 06:13 AM
                                        • ipatch
                                          troubleshooting microsoft surface pro 4 no power no led charge light
                                          by ipatch
                                          hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                                          10-05-2023, 11:59 AM
