Samsung "MU" series (UN, UA, UExxMUxxxx) fault dump IC1604 25Q40...
  • patii
    • Aug 2025
    • Norwegia
    #241
    ue70ru6025k lcd cv-GN070HGJV1H BN41-2703A HELP
    • neighbor
      • Sep 2025
      • romania
      #242
      Hello, here is a UE50MU7000 with BN41-02568B (after an electricity jump):
      - no stand by led light
      - power supply has 9v outputs which go to mainboard
      - without mainboard connected backlight works fine
      - without backlight connected still no stand by led light
      - dumped 24C512, 25Q40, 25Q80 (through CH341A programmer before finding this site), and flashed backup data from a UE40MU6102KXXH (which has same main board), this did not fix anything
      After reading this thread, found out there is a specific way of flashing 25Q40, so I've placed all original backups back to their chips (also tried to restore header data in 25Q40, but it did not work)
      and while doing what is in guide in 4th post, found out that QE is impossible to check. (edit: in NeoProgrammer V2.2.0.10 it's possible)
      Is there also a special way of flashing 24C512 and 25Q80 like 25Q40 requires?
      Can you please take a look at these files and see if there is anything wrong?
      Can send a thanks thru PayPal if it will fix this issue.
      • lotas
        • Jan 2016
        • 4805
        • Russia
        #243
        Try it, don't forget about the register status (0x88, 0x42) after writing my dump.
        • ladharimohamed2
          • Jul 2021
          • 45
          • tunisia
          #244
          Hi , i have a samsung model ua32k5100 that has its memory image corrupted.
          IC 805 W25Q40CL.
          Board name BN94-10869Q.
          i have tried several images the best ones are when tv comes with samsung logo for 1 second and then reboot and stays black.
          original problem with my own image that tv wont turn on and all voltages are ok and the board is ok
          can someone pls try to fix my original dump or give me one.
          original dump attached .
          Thanks a lot.
          • lotas
            • Jan 2016
            • 4805
            • Russia
            #245
            IC 805 W25Q40CL.
            Thanks a lot.
            Try.
            • ladharimohamed2
              • Jul 2021
              • 45
              • tunisia
              #246
              Originally posted by lotas
              Try.
              it is doing the same with my image, red lignt flashing for several seconds then samsung logo appears then the TV powers off the led stays on then reboots and doing the same thing. maybe is something else ?
              thanks for your help
              • lotas
                • Jan 2016
                • 4805
                • Russia
                #247
                Anything could be wrong, for example, the firmware in the NAND or in the eeprom, is your backlight OK?
                • ladharimohamed2
                  • Jul 2021
                  • 45
                  • tunisia
                  #248
                  yes, the samsung logo shows off for several seconds with backlight on then the logo goes off and backlight stays on for some seconds then the tv reboots. i cant find the eeprom ic. photo of the board attached.
                  thanks for your help.
                  • lotas
                    • Jan 2016
                    • 4805
                    • Russia
                    #249
                    It's hard to tell from this photo, but the eeprom should be 24c256.
                    • ladharimohamed2
                      • Jul 2021
                      • 45
                      • tunisia
                      #250
                      Didn't find any other programmable IC, must be the nand W29N01HVSINF. thank you so much for your help
                      • lotas
                        • Jan 2016
                        • 4805
                        • Russia
                        #251
                        Well, I don’t know what kind of motherboard you have, but the NAND is F59L1G81MA-25TI.
                        • Carlo Verdone
                          • Aug 2020
                          • 10
                          • Italia
                          #252
                          Samsung UE49MU6450 No turn on no led st.by . Hi everyone i think it's the problem with IC1604 mainboard BN94-12399N - BN41-02568B . Attach the original dump . For TL866 II Plus program Xgpro software , maybe perhaps requires special procedures for to program ? Thanks in advance .
                          • lotas
                            • Jan 2016
                            • 4805
                            • Russia
                            #253
                            Try.
                            • Carlo Verdone
                              • Aug 2020
                              • 10
                              • Italia
                              #254
                              Thank you very much . Fantastic job , works very well , it's all ok .
                              • lotas
                                • Jan 2016
                                • 4805
                                • Russia
                                #255
                                Ok!
                                • lividas
                                  • Jun 2014
                                  • 4
                                  • Lithuania
                                  #256
                                  Samsung UE49MU6272uxxh No turn on no led st.by . Hi everyone i think it's the problem with IC1604 mainboard BN94-12486H - BN41-02568B . Attach the original dump . Thanks in advance .
                                  • lotas
                                    • Jan 2016
                                    • 4805
                                    • Russia
                                    #257
                                    Where is DUMP itself?
                                    • lividas
                                      • Jun 2014
                                      • 4
                                      • Lithuania
                                      #258
                                      "Where is DUMP itself?"
                                      • lotas
                                        • Jan 2016
                                        • 4805
                                        • Russia
                                        #259
                                        Try.
                                        • lividas
                                          • Jun 2014
                                          • 4
                                          • Lithuania
                                          #260
                                          Thank you Lotas .
                                          There is a problem with the motherboard — the IC400 won’t boot.
                                          • Yanleb
                                            UN65MU6300FXZC, no standby LED but power supply good. Bad IC1604 25Q40?
                                            by Yanleb
                                            My UN65MU6300FXZC is dead and the standby LED stays off. The power supply is good. The main board is BN94-12434A.
                                            Disconnecting the main board from the power supply makes the backlight come ON.
                                            I did disconnect the panel cables and the WIFI modules, the board is still dead.
                                            I did read in many posts that IC1604 25Q40 becomes corrupted. It has proper 3.3 volt on VCC pin 8. I did read that if I post its dump here someone can fix it. Is that right?
                                            Thanks.
                                            11-18-2024, 12:34 AM
                                          • ogabuga
                                            Asrock B650E PG-ITX BIOS_WHP1 /25Q40/
                                            by ogabuga
                                            Hello, I need a dump of the BIOS_WHP1 /25Q40/, EC controller chip /NTC6686D/. The motherboard is coming for repair after a another service, what is in the dump that I downloaded is the beginning of the MAIN BIOS, according to the analysis that I did based on the documentation of the EC controller NTC6686D, the content should be different. BIOS_WHP1 /25Q40/ is connected directly to SCE1#, SO1, SI1, SCK1 pins 66, 68, 67, 69 of the NTC6686D​
                                            01-28-2025, 04:48 AM
                                          • daniel0799
                                            Full 25Q40 dump for TP-LINK TL-SG1016D V7 (RTL8382L + 2x RTL8218B, PCB KB616010558)
                                            by daniel0799
                                            I’m looking for the **full 512KB (25Q40) SPI dump** for **TP-LINK TL-SG1016D V7 (unmanaged)**, PCB code **KB616010558**, with SoC **RTL8382L + 2×RTL8218B**.
                                            My current dump only initializes 8 ports and the LEDs are misaligned, so I believe I have a firmware from an 8-port model.
                                            I need a complete dump (bootloader + firmware) from a working switch to restore full 16-port operation.
                                            If anyone has this model or a similar V7 revision, please share the BIN file or point me to a resource.
                                            I can provide photos of my board and the flash...
                                            10-22-2025, 11:12 AM
                                          • alro7779
                                            Samsung UN55MU6103F video problem; has colored stripes on the display
                                            by alro7779
                                            Hello, everyone!
                                            A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                                            09-27-2025, 11:29 PM
                                          • totof
                                            Samsung UE55MU6102K IC1604 dump needed - TV don't start
                                            by totof
                                            Could you help me...
                                            I have a Samsung UE55MU6102K with the following problem : I disconnect the motherboard from main power supply from and the backlight leds light up.
                                            Then motherboard connected, standby led is on and current consuption is 18W.
                                            Then trying to start the TV, the standby led is blinking once but TV don't start and standby led stay red.
                                            Maybe the firmware in the IC SPI Flash W25Q40CL (IC1604) is corrupted.
                                            The model of my TV is :
                                            Power supply BN44-00807A
                                            Main Board BN41-02568B / BN94-12765W
                                            Panel CY-GM055HGLV3H...
                                            05-01-2023, 04:30 AM
