Samsung "MU" series (UN, UA, UExxMUxxxx) fault dump IC1604 25Q40...
  • bohaboha
    • Nov 2012
    • 1015
    • sweden
    #221
    ​Hi I've read all the post in this thread trying to find something about UEXXTU but not a single one about it except EUXXMU basically my search lies in finding which IC chip corresponds to 25Q40 on my own board :BN94-16627N the patch and BN41-02751B-000 on PCB hopefully lotas can enlighten me
    • Lorenzo1967
      • Nov 2024
      • 6
      • ITALY
      #222
      Good afternoon, I have a Samsung MU series locked, it does not boot, the power supply is ok, most likely the IC1604 25Q40 file is corrupted.
      • lotas
        • Jan 2016
        • 4654
        • Russia
        #223
        Everything is OK with the firmware (dump), read the dump from the chip again and show what status register is set for the chip (it should be 0x88, 0x42), what is the problem with the TV, is the standby LED on, does the backlight light up if you disconnect the cable from the power supply to the motherboard?, have you disconnected the lvds cables from the panel?
        • Lorenzo1967
          • Nov 2024
          • 6
          • ITALY
          #224
          Thanks for your interest, I reprogrammed the same file on a new 25Q40, register at 0x88 0x42 and now the TV has started working again.
          I will keep it to test, I would not want there to be some problem on the main.
          Power, backlight and panel are ok.
          Can you tell me what data is corrupted, so that I can recognize if a file is corrupted or not. Thank you very much for your support.
          • lotas
            • Jan 2016
            • 4654
            • Russia
            #225
            Basically, the header in dump with a size of 4 kB (initial bytes) FF FF FF..... flies off, and the status register itself.
            • SDNarcia
              • Jul 2024
              • 5
              • México
              #226
              Hi, I have a Samsung TV that's having trouble booting. I checked the voltage and everything is correct. I don't have a standby light. Could you help me correct my file?
              Thank you very much!
              P.S.: Please excuse my poor English.
              • lotas
                • Jan 2016
                • 4654
                • Russia
                #227
                Try it, don’t forget about status register (0x88, 0x42).
                • Jeffaas
                  • Jan 2021
                  • 11
                  • Nederland
                  #228
                  Hi Lotas, could you check this one for me?
                  • lotas
                    • Jan 2016
                    • 4654
                    • Russia
                    #229
                    Try!
                    • Jeffaas
                      • Jan 2021
                      • 11
                      • Nederland
                      #230
                      Thank you very much! works perfectly!!!! Thank Thanks Thanks!
                      • lotas
                        • Jan 2016
                        • 4654
                        • Russia
                        #231
                        Ok!
                        • bohaboha
                          • Nov 2012
                          • 1015
                          • sweden
                          #232
                          Originally posted by lotas
                          Ok!
                          Hi I'm making another try but now I'm adding pictures please lotas help me
                          • lotas
                            • Jan 2016
                            • 4654
                            • Russia
                            #233
                            Well, is it possible to see anything in such quality photos? Something similar, or this one, or this one.
                            • SergioPF
                              • Aug 2025
                              • mexico
                              #234
                              Looking for eMMC dump for Samsung UN65AU7000F, mainboard BN94-00051C / BN41-02992A. TV is dead, no standby LED. Already confirmed PSU is working.
                              • bohaboha
                                • Nov 2012
                                • 1015
                                • sweden
                                #235
                                Are these better?
                                • SergioPF
                                  • Aug 2025
                                  • mexico
                                  #236
                                  This Is my mainboard
                                  • lotas
                                    • Jan 2016
                                    • 4654
                                    • Russia
                                    #237
                                    Are these better?
                                    What's better? Open your photos yourself and see how visible the markings are on the chips, replace the camera and take a photo with good focus!
                                    • bohaboha
                                      • Nov 2012
                                      • 1015
                                      • sweden
                                      #238
                                      hello again sorry i can't get better pictures with my bad equipment here you have the designation of the four ic
                                      1) 4801A SBL0316
                                      2)G4435SS 2049
                                      3)Q80C-104HIP X00R05 2036HIA
                                      4)Q40B-104HIP X901622 2028HLX
                                      • lotas
                                        • Jan 2016
                                        • 4654
                                        • Russia
                                        #239
                                        1) 4801A SBL0316
                                        2)G4435SS 2049
                                        What you are looking for (25Q40) from the list, then it corresponds to number 4 (Q40B-104HIP)
                                        • bohaboha
                                          • Nov 2012
                                          • 1015
                                          • sweden
                                          #240
                                          Thank you so much
                                          • totof
                                            Samsung UE55MU6102K IC1604 dump needed - TV don't start
                                            by totof
                                            Could you help me...
                                            I have a Samsung UE55MU6102K with the following problem : I disconnect the motherboard from main power supply from and the backlight leds light up.
                                            Then motherboard connected, standby led is on and current consuption is 18W.
                                            Then trying to start the TV, the standby led is blinking once but TV don't start and standby led stay red.
                                            Maybe the firmware in the IC SPI Flash W25Q40CL (IC1604) is corrupted.
                                            The model of my TV is :
                                            Power supply BN44-00807A
                                            Main Board BN41-02568B / BN94-12765W
                                            Panel CY-GM055HGLV3H...
                                            05-01-2023, 04:30 AM
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • jeangonbay
                                            Samsung UE43MU6105K IC1604 dump needed - TV don't start
                                            by jeangonbay
                                            Could you help me,I have a Samsung UE43MU6105K with the following problem, dead TV, when I disconnect the main power supply to logic board, the leds light up.
                                            The model of my TV is UE43MU6105K
                                            Main Board: BN41-02568B
                                            BN94-12007Y
                                            Could you help me to repair the dump please. Thank you.
                                            02-16-2024, 05:46 AM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • Mephysis
                                            DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                                            by Mephysis
                                            Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                                            I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                                            03-27-2025, 02:34 AM
