Samsung "MU" series (UN, UA, UExxMUxxxx) fault dump IC1604 25Q40...
  • bohaboha
    • Nov 2012
    • 1032
    • sweden
    #221
    ​Hi I've read all the post in this thread trying to find something about UEXXTU but not a single one about it except EUXXMU basically my search lies in finding which IC chip corresponds to 25Q40 on my own board :BN94-16627N the patch and BN41-02751B-000 on PCB hopefully lotas can enlighten me
    • Lorenzo1967
      • Nov 2024
      • 6
      • ITALY
      #222
      Good afternoon, I have a Samsung MU series locked, it does not boot, the power supply is ok, most likely the IC1604 25Q40 file is corrupted.
      • lotas
        • Jan 2016
        • 4881
        • Russia
        #223
        Everything is OK with the firmware (dump), read the dump from the chip again and show what status register is set for the chip (it should be 0x88, 0x42), what is the problem with the TV, is the standby LED on, does the backlight light up if you disconnect the cable from the power supply to the motherboard?, have you disconnected the lvds cables from the panel?
        • Lorenzo1967
          • Nov 2024
          • 6
          • ITALY
          #224
          Thanks for your interest, I reprogrammed the same file on a new 25Q40, register at 0x88 0x42 and now the TV has started working again.
          I will keep it to test, I would not want there to be some problem on the main.
          Power, backlight and panel are ok.
          Can you tell me what data is corrupted, so that I can recognize if a file is corrupted or not. Thank you very much for your support.
          • lotas
            • Jan 2016
            • 4881
            • Russia
            #225
            Basically, the header in dump with a size of 4 kB (initial bytes) FF FF FF..... flies off, and the status register itself.
            • SDNarcia
              • Jul 2024
              • 6
              • México
              #226
              Hi, I have a Samsung TV that's having trouble booting. I checked the voltage and everything is correct. I don't have a standby light. Could you help me correct my file?
              Thank you very much!
              P.S.: Please excuse my poor English.
              • lotas
                • Jan 2016
                • 4881
                • Russia
                #227
                Try it, don’t forget about status register (0x88, 0x42).
                • Jeffaas
                  • Jan 2021
                  • 11
                  • Nederland
                  #228
                  Hi Lotas, could you check this one for me?
                  • lotas
                    • Jan 2016
                    • 4881
                    • Russia
                    #229
                    Try!
                    • Jeffaas
                      • Jan 2021
                      • 11
                      • Nederland
                      #230
                      Thank you very much! works perfectly!!!! Thank Thanks Thanks!
                      • lotas
                        • Jan 2016
                        • 4881
                        • Russia
                        #231
                        Ok!
                        • bohaboha
                          • Nov 2012
                          • 1032
                          • sweden
                          #232
                          Originally posted by lotas
                          Ok!
                          Hi I'm making another try but now I'm adding pictures please lotas help me
                          • lotas
                            • Jan 2016
                            • 4881
                            • Russia
                            #233
                            Well, is it possible to see anything in such quality photos? Something similar, or this one, or this one.
                            • SergioPF
                              • Aug 2025
                              • mexico
                              #234
                              Looking for eMMC dump for Samsung UN65AU7000F, mainboard BN94-00051C / BN41-02992A. TV is dead, no standby LED. Already confirmed PSU is working.
                              • bohaboha
                                • Nov 2012
                                • 1032
                                • sweden
                                #235
                                Are these better?
                                • SergioPF
                                  • Aug 2025
                                  • mexico
                                  #236
                                  This Is my mainboard
                                  • lotas
                                    • Jan 2016
                                    • 4881
                                    • Russia
                                    #237
                                    Are these better?
                                    What's better? Open your photos yourself and see how visible the markings are on the chips, replace the camera and take a photo with good focus!
                                    • bohaboha
                                      • Nov 2012
                                      • 1032
                                      • sweden
                                      #238
                                      hello again sorry i can't get better pictures with my bad equipment here you have the designation of the four ic
                                      1) 4801A SBL0316
                                      2)G4435SS 2049
                                      3)Q80C-104HIP X00R05 2036HIA
                                      4)Q40B-104HIP X901622 2028HLX
                                      • lotas
                                        • Jan 2016
                                        • 4881
                                        • Russia
                                        #239
                                        1) 4801A SBL0316
                                        2)G4435SS 2049
                                        What you are looking for (25Q40) from the list, then it corresponds to number 4 (Q40B-104HIP)
                                        • bohaboha
                                          • Nov 2012
                                          • 1032
                                          • sweden
                                          #240
                                          Thank you so much
                                          • Yanleb
                                            UN65MU6300FXZC, no standby LED but power supply good. Bad IC1604 25Q40?
                                            by Yanleb
                                            My UN65MU6300FXZC is dead and the standby LED stays off. The power supply is good. The main board is BN94-12434A.
                                            Disconnecting the main board from the power supply makes the backlight come ON.
                                            I did disconnect the panel cables and the WIFI modules, the board is still dead.
                                            I did read in many posts that IC1604 25Q40 becomes corrupted. It has proper 3.3 volt on VCC pin 8. I did read that if I post its dump here someone can fix it. Is that right?
                                            Thanks.
                                            11-18-2024, 12:34 AM
                                          • ogabuga
                                            Asrock B650E PG-ITX BIOS_WHP1 /25Q40/
                                            by ogabuga
                                            Hello, I need a dump of the BIOS_WHP1 /25Q40/, EC controller chip /NTC6686D/. The motherboard is coming for repair after a another service, what is in the dump that I downloaded is the beginning of the MAIN BIOS, according to the analysis that I did based on the documentation of the EC controller NTC6686D, the content should be different. BIOS_WHP1 /25Q40/ is connected directly to SCE1#, SO1, SI1, SCK1 pins 66, 68, 67, 69 of the NTC6686D​
                                            01-28-2025, 04:48 AM
                                          • daniel0799
                                            Full 25Q40 dump for TP-LINK TL-SG1016D V7 (RTL8382L + 2x RTL8218B, PCB KB616010558)
                                            by daniel0799
                                            I’m looking for the **full 512KB (25Q40) SPI dump** for **TP-LINK TL-SG1016D V7 (unmanaged)**, PCB code **KB616010558**, with SoC **RTL8382L + 2×RTL8218B**.
                                            My current dump only initializes 8 ports and the LEDs are misaligned, so I believe I have a firmware from an 8-port model.
                                            I need a complete dump (bootloader + firmware) from a working switch to restore full 16-port operation.
                                            If anyone has this model or a similar V7 revision, please share the BIN file or point me to a resource.
                                            I can provide photos of my board and the flash...
                                            10-22-2025, 11:12 AM
                                          • alro7779
                                            Samsung UN55MU6103F video problem; has colored stripes on the display
                                            by alro7779
                                            Hello, everyone!
                                            A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                                            09-27-2025, 11:29 PM
                                          • totof
                                            Samsung UE55MU6102K IC1604 dump needed - TV don't start
                                            by totof
                                            Could you help me...
                                            I have a Samsung UE55MU6102K with the following problem : I disconnect the motherboard from main power supply from and the backlight leds light up.
                                            Then motherboard connected, standby led is on and current consuption is 18W.
                                            Then trying to start the TV, the standby led is blinking once but TV don't start and standby led stay red.
                                            Maybe the firmware in the IC SPI Flash W25Q40CL (IC1604) is corrupted.
                                            The model of my TV is :
                                            Power supply BN44-00807A
                                            Main Board BN41-02568B / BN94-12765W
                                            Panel CY-GM055HGLV3H...
                                            05-01-2023, 04:30 AM
