Samsung "MU" series (UN, UA, UExxMUxxxx) fault dump IC1604 25Q40...
  • lotas
    • Jan 2016
    • 4859
    • Russia
    #181
    Originally posted by yureyko
    Interesting...
    All voltages are present, but the indicator does not light up.
    However, when I try to flash the SPI with a working firmware from a similar model, the indicator lights up, but there is no startup...​
    Then check what status register is set, maybe it has crashed (it should be 0x88, 0x42).
    • yureyko
      • Oct 2024
      • 12
      • Ukraine
      #182
      • yureyko
        • Oct 2024
        • 12
        • Ukraine
        #183
        Dear lotas ,
        After installation in the TV, the status changed to 0x46.
        • lotas
          • Jan 2016
          • 4859
          • Russia
          #184
          There should be only (S3, S7, S9, S14).
          Try to record your native dump again via NeoProgrammer_2.2.0.10.
          In the program:
          1. Click "Detect Chip" and select W25Q40CL and "Select IC".
          2. Click "Unprotect".
          3. Click "Clear IC" and "Yes".
          4. Click "Open File" and select your corrected dump.
          5. Press "Program IC" and "Yes".
          6. Click "Verify IC".
          7. Press the down arrow to the right of "Unprotect" and select "SREG Edit", put a check mark on SRP0, BP1, CMP, QE (S3, S7, S9, S14) and press "Write" and "Yes"
          7. Close the program. Ready.​
          • yureyko
            • Oct 2024
            • 12
            • Ukraine
            #185
            In the program:
            Dear lotas ,​
            I already have some default parameter set. That's why I can't set the register code 0x42.
            • yureyko
              • Oct 2024
              • 12
              • Ukraine
              #186
              Maybe I have a problem with the SPI chip or the CH314A programmer. Mine is not modified. Do I necessarily need to modify it?
              • lotas
                • Jan 2016
                • 4859
                • Russia
                #187
                Try to remove protection first, i.e. remove all checkboxes and press "Write", then erase and write dump again, then set the status register again...
                • yureyko
                  • Oct 2024
                  • 12
                  • Ukraine
                  #188
                  The same result, it immediately enables that parameter.
                  • lotas
                    • Jan 2016
                    • 4859
                    • Russia
                    #189
                    Try this dump.
                    And is your CH341A black or green?
                    • yureyko
                      • Oct 2024
                      • 12
                      • Ukraine
                      #190
                      The same behavior in three programs (SiberiaProg, Colibri, NeoProgrammer).
                      • yureyko
                        • Oct 2024
                        • 12
                        • Ukraine
                        #191
                        Try this dump.
                        I tried your firmware, but I have the same problem. I have a black CH341A.
                        When I try your other firmware for different TV models, I still have the same problem. It's probably an issue with the programmer or the SPI chip.
                        • lotas
                          • Jan 2016
                          • 4859
                          • Russia
                          #192
                          And in the settings it is set as green.
                          • yureyko
                            • Oct 2024
                            • 12
                            • Ukraine
                            #193
                            I was experimenting with everything back then... Now all the settings are correct.
                            • lotas
                              • Jan 2016
                              • 4859
                              • Russia
                              #194
                              Do you use it through a clamp or do you unsolder the flash and use an adapter on the programmer?
                              Try another flash...
                              • yureyko
                                • Oct 2024
                                • 12
                                • Ukraine
                                #195
                                I desolder the SPI chip and clamp it with a clip. I haven't had issues with this before.
                                Will the Winbond W25Q40BVSNIG chip work?
                                • lotas
                                  • Jan 2016
                                  • 4859
                                  • Russia
                                  #196
                                  I haven't tried it, try replacing it with this one.
                                  • Diah
                                    • Feb 2013
                                    • 6564
                                    W25Q40BVSNIG have difrent clock signal at I2C will not take effect as the CL
                                    • lotas
                                      • Jan 2016
                                      • 4859
                                      • Russia
                                      #198
                                      Don't make me laugh, where did spi flash get the I²C Protocol from, it's not eeprom.
                                      https://www.fs-pcba.com/ru/spi-vs-i2c/
                                      • Diah
                                        • Feb 2013
                                        • 6564
                                        [QUOTE=lotas;n3596169]
                                        https://www.fs-pcba.com/ru/spi-vs-i2c/[/QUOTE
                                        then start to laugh lotas, script written as befehl which SoC do it as I2C act via eMMC / NAND firmware , when position of script address at SPI or eEPROM different the SoC will take order but it cant deliver it to Main Firmware.. this called Step BY Step start..
                                        • yureyko
                                          • Oct 2024
                                          • 12
                                          • Ukraine
                                          #200
                                          My dear lotas,
                                          I ordered the Winbond W25Q40BVSNIG and W25Q40CLNIG chips to check if there will be any difference.
                                          • Yanleb
                                            UN65MU6300FXZC, no standby LED but power supply good. Bad IC1604 25Q40?
                                            by Yanleb
                                            My UN65MU6300FXZC is dead and the standby LED stays off. The power supply is good. The main board is BN94-12434A.
                                            Disconnecting the main board from the power supply makes the backlight come ON.
                                            I did disconnect the panel cables and the WIFI modules, the board is still dead.
                                            I did read in many posts that IC1604 25Q40 becomes corrupted. It has proper 3.3 volt on VCC pin 8. I did read that if I post its dump here someone can fix it. Is that right?
                                            Thanks.
                                            11-18-2024, 12:34 AM
                                          • ogabuga
                                            Asrock B650E PG-ITX BIOS_WHP1 /25Q40/
                                            by ogabuga
                                            Hello, I need a dump of the BIOS_WHP1 /25Q40/, EC controller chip /NTC6686D/. The motherboard is coming for repair after a another service, what is in the dump that I downloaded is the beginning of the MAIN BIOS, according to the analysis that I did based on the documentation of the EC controller NTC6686D, the content should be different. BIOS_WHP1 /25Q40/ is connected directly to SCE1#, SO1, SI1, SCK1 pins 66, 68, 67, 69 of the NTC6686D​
                                            01-28-2025, 04:48 AM
                                          • daniel0799
                                            Full 25Q40 dump for TP-LINK TL-SG1016D V7 (RTL8382L + 2x RTL8218B, PCB KB616010558)
                                            by daniel0799
                                            I’m looking for the **full 512KB (25Q40) SPI dump** for **TP-LINK TL-SG1016D V7 (unmanaged)**, PCB code **KB616010558**, with SoC **RTL8382L + 2×RTL8218B**.
                                            My current dump only initializes 8 ports and the LEDs are misaligned, so I believe I have a firmware from an 8-port model.
                                            I need a complete dump (bootloader + firmware) from a working switch to restore full 16-port operation.
                                            If anyone has this model or a similar V7 revision, please share the BIN file or point me to a resource.
                                            I can provide photos of my board and the flash...
                                            10-22-2025, 11:12 AM
                                          • alro7779
                                            Samsung UN55MU6103F video problem; has colored stripes on the display
                                            by alro7779
                                            Hello, everyone!
                                            A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                                            09-27-2025, 11:29 PM
                                          • totof
                                            Samsung UE55MU6102K IC1604 dump needed - TV don't start
                                            by totof
                                            Could you help me...
                                            I have a Samsung UE55MU6102K with the following problem : I disconnect the motherboard from main power supply from and the backlight leds light up.
                                            Then motherboard connected, standby led is on and current consuption is 18W.
                                            Then trying to start the TV, the standby led is blinking once but TV don't start and standby led stay red.
                                            Maybe the firmware in the IC SPI Flash W25Q40CL (IC1604) is corrupted.
                                            The model of my TV is :
                                            Power supply BN44-00807A
                                            Main Board BN41-02568B / BN94-12765W
                                            Panel CY-GM055HGLV3H...
                                            05-01-2023, 04:30 AM
