Samsung "MU" series (UN, UA, UExxMUxxxx) fault dump IC1604 25Q40...
  • lotas
    • Jan 2016
    • 4562
    • Russia
    #181
    Originally posted by yureyko
    Interesting...
    All voltages are present, but the indicator does not light up.
    However, when I try to flash the SPI with a working firmware from a similar model, the indicator lights up, but there is no startup...​
    Then check what status register is set, maybe it has crashed (it should be 0x88, 0x42).
    • yureyko
      • Oct 2024
      • 12
      • Ukraine
      #182
      • yureyko
        • Oct 2024
        • 12
        • Ukraine
        #183
        Dear lotas ,
        After installation in the TV, the status changed to 0x46.
        • lotas
          • Jan 2016
          • 4562
          • Russia
          #184
          There should be only (S3, S7, S9, S14).
          Try to record your native dump again via NeoProgrammer_2.2.0.10.
          In the program:
          1. Click "Detect Chip" and select W25Q40CL and "Select IC".
          2. Click "Unprotect".
          3. Click "Clear IC" and "Yes".
          4. Click "Open File" and select your corrected dump.
          5. Press "Program IC" and "Yes".
          6. Click "Verify IC".
          7. Press the down arrow to the right of "Unprotect" and select "SREG Edit", put a check mark on SRP0, BP1, CMP, QE (S3, S7, S9, S14) and press "Write" and "Yes"
          7. Close the program. Ready.​
          • yureyko
            • Oct 2024
            • 12
            • Ukraine
            #185
            In the program:
            Dear lotas ,​
            I already have some default parameter set. That's why I can't set the register code 0x42.
            • yureyko
              • Oct 2024
              • 12
              • Ukraine
              #186
              Maybe I have a problem with the SPI chip or the CH314A programmer. Mine is not modified. Do I necessarily need to modify it?
              • lotas
                • Jan 2016
                • 4562
                • Russia
                #187
                Try to remove protection first, i.e. remove all checkboxes and press "Write", then erase and write dump again, then set the status register again...
                • yureyko
                  • Oct 2024
                  • 12
                  • Ukraine
                  #188
                  The same result, it immediately enables that parameter.
                  • lotas
                    • Jan 2016
                    • 4562
                    • Russia
                    #189
                    Try this dump.
                    And is your CH341A black or green?
                    • yureyko
                      • Oct 2024
                      • 12
                      • Ukraine
                      #190
                      The same behavior in three programs (SiberiaProg, Colibri, NeoProgrammer).
                      • yureyko
                        • Oct 2024
                        • 12
                        • Ukraine
                        #191
                        Try this dump.
                        I tried your firmware, but I have the same problem. I have a black CH341A.
                        When I try your other firmware for different TV models, I still have the same problem. It's probably an issue with the programmer or the SPI chip.
                        • lotas
                          • Jan 2016
                          • 4562
                          • Russia
                          #192
                          And in the settings it is set as green.
                          • yureyko
                            • Oct 2024
                            • 12
                            • Ukraine
                            #193
                            I was experimenting with everything back then... Now all the settings are correct.
                            • lotas
                              • Jan 2016
                              • 4562
                              • Russia
                              #194
                              Do you use it through a clamp or do you unsolder the flash and use an adapter on the programmer?
                              Try another flash...
                              • yureyko
                                • Oct 2024
                                • 12
                                • Ukraine
                                #195
                                I desolder the SPI chip and clamp it with a clip. I haven't had issues with this before.
                                Will the Winbond W25Q40BVSNIG chip work?
                                • lotas
                                  • Jan 2016
                                  • 4562
                                  • Russia
                                  #196
                                  I haven't tried it, try replacing it with this one.
                                  • Diah
                                    • Feb 2013
                                    • 6357
                                    W25Q40BVSNIG have difrent clock signal at I2C will not take effect as the CL
                                    • lotas
                                      • Jan 2016
                                      • 4562
                                      • Russia
                                      #198
                                      Don't make me laugh, where did spi flash get the I²C Protocol from, it's not eeprom.
                                      https://www.fs-pcba.com/ru/spi-vs-i2c/
                                      • Diah
                                        • Feb 2013
                                        • 6357
                                        [QUOTE=lotas;n3596169]
                                        https://www.fs-pcba.com/ru/spi-vs-i2c/[/QUOTE
                                        then start to laugh lotas, script written as befehl which SoC do it as I2C act via eMMC / NAND firmware , when position of script address at SPI or eEPROM different the SoC will take order but it cant deliver it to Main Firmware.. this called Step BY Step start..
                                        • yureyko
                                          • Oct 2024
                                          • 12
                                          • Ukraine
                                          #200
                                          My dear lotas,
                                          I ordered the Winbond W25Q40BVSNIG and W25Q40CLNIG chips to check if there will be any difference.
                                            09-07-2024, 05:50 AM
                                          • totof
                                            Samsung UE55MU6102K IC1604 dump needed - TV don't start
                                            by totof
                                            Could you help me...
                                            I have a Samsung UE55MU6102K with the following problem : I disconnect the motherboard from main power supply from and the backlight leds light up.
                                            Then motherboard connected, standby led is on and current consuption is 18W.
                                            Then trying to start the TV, the standby led is blinking once but TV don't start and standby led stay red.
                                            Maybe the firmware in the IC SPI Flash W25Q40CL (IC1604) is corrupted.
                                            The model of my TV is :
                                            Power supply BN44-00807A
                                            Main Board BN41-02568B / BN94-12765W
                                            Panel CY-GM055HGLV3H...
                                            05-01-2023, 04:30 AM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • jeangonbay
                                            Samsung UE43MU6105K IC1604 dump needed - TV don't start
                                            by jeangonbay
                                            Could you help me,I have a Samsung UE43MU6105K with the following problem, dead TV, when I disconnect the main power supply to logic board, the leds light up.
                                            The model of my TV is UE43MU6105K
                                            Main Board: BN41-02568B
                                            BN94-12007Y
                                            Could you help me to repair the dump please. Thank you.
                                            02-16-2024, 05:46 AM
                                            09-06-2024, 11:40 PM
