Samsung "MU" series (UN, UA, UExxMUxxxx) fault dump IC1604 25Q40...
  • lotas
    • Jan 2016
    • 4645
    • Russia
    #161
    Originally posted by Beard dwarf
    SAMSUNG UE40MU6402
    There is no standby mode. I tried to fix the firmware myself, the standby mode appeared, but when I turn on the image there is no. Maybe I did it wrong.
    Can anyone help?
    Try.
    • Beard dwarf
      • Dec 2024
      • 5
      • Украина
      #162
      Originally posted by lotas
      Try.
      Thank you, lotas, but it didn't help.
      This is my home TV. When it broke, I took it to a service center. They diagnosed it as a broken processor.
      I repair other electronics and am not an expert in TVs, but this seemed strange to me. So I decided to try it myself.
      In 25q40, I found that the firmware start was missing and searching the forums suggested that this was a common problem. But fixing this problem resulted in the standby voltage appearing, the TV started to turn on, but there was no image.
      Scratches on 25Q80 indicate that they tried to flash it without unsoldering it. This makes me think that I will have to further improve my skills in TV repair.​
      • lotas
        • Jan 2016
        • 4645
        • Russia
        #163
        What is the motherboard number BN94-xxxxx, and what is the panel number CYxxxxxx?
        If the TV was already at the service center, then it is possible that the 25Q40 already had a non-original dump, maybe they tried to program it without saving the original one..
        • Beard dwarf
          • Dec 2024
          • 5
          • Украина
          #164
          BN94-12398F
          CY-KK040HGNV2H
          If this is not the original dump, then why is it also corrupted? I hope this is the original. Maybe you're right.
          • lotas
            • Jan 2016
            • 4645
            • Russia
            #165
            A working Dump is damaged immediately after power is applied, if the status register (0x88, 0x42) is not set after writing; if the service center did not do this, then it is damaged again.
            • lotas
              • Jan 2016
              • 4645
              • Russia
              #166
              Try these dumps for t-con (25q80).
              • Beard dwarf
                • Dec 2024
                • 5
                • Украина
                #167
                Big thanks for help, everything works. Happy New Year!
                • lotas
                  • Jan 2016
                  • 4645
                  • Russia
                  #168
                  Ok! Happy New Year!
                  • srdi
                    • Jan 2024
                    • 5
                    • Ukraine
                    #169
                    Телевізор не включається, немає режиму очікування! SAMSUNG UE55MU6172
                    The TV does not turn on, there is no standby mode!​ SAMSUNG UE55MU6172
                    • DJJaro
                      • Feb 2025
                      • Slovakia
                      #170
                      Hello. I have broken IC1604 from board BN94-12432B.Dump from this threed not working. Is possible fix? Thank you.
                      Edit: solved, must be changed status register. Board working OK, thank you.
                      • David Rocha
                        • Feb 2025
                        • Ceara
                        #171
                        Hello! My TV is a Samsung UN43MU6100G from board BN94-12431J, CODE: BN41-02568B.Dump from this! Could you help me a fix this problem? This TV in standby stay blinking and not turn on!
                        • lotas
                          • Jan 2016
                          • 4645
                          • Russia
                          #172
                          Your dump is fine, it works, the problem is different.
                          • ducky29
                            • Dec 2015
                            • 370
                            • Europe
                            #173
                            Hello Iotas. Can you please check this dump? UE43NU7022K. Thank you!
                            • lotas
                              • Jan 2016
                              • 4645
                              • Russia
                              #174
                              Hi, try the working dump.
                              • ducky29
                                • Dec 2015
                                • 370
                                • Europe
                                #175
                                Thanks Iotas. It works fine!
                                • lotas
                                  • Jan 2016
                                  • 4645
                                  • Russia
                                  #176
                                  Ok!
                                  • yureyko
                                    • Oct 2024
                                    • 12
                                    • Ukraine
                                    #177
                                    Greetings friends,
                                    i have a Samsung TV UE40MU6402U with board BN41-02568b
                                    The problem is that i have no standby
                                    I thint that maybe the problem is software related since i have voltages in board.
                                    I read the IC1604 (W25Q40CL)
                                    Propably problem is the IC1604 but i read all of them.
                                    If someone knows or have software to help please you are welcome.
                                    Thanks in advance for your time and your help.​
                                    • lotas
                                      • Jan 2016
                                      • 4645
                                      • Russia
                                      #178
                                      Originally posted by yureyko
                                      Greetings friends,
                                      Your dump is working, the problem is different...
                                        • 21133
                                        The thread title has been renamed to Samsung "MU" series (UN, UA, UExxMUxxxx) fault dump IC1604 25Q40...
                                        • yureyko
                                          • Oct 2024
                                          • 12
                                          • Ukraine
                                          #180
                                          Interesting...
                                          All voltages are present, but the indicator does not light up.
                                          However, when I try to flash the SPI with a working firmware from a similar model, the indicator lights up, but there is no startup...​
                                          • totof
                                            Samsung UE55MU6102K IC1604 dump needed - TV don't start
                                            by totof
                                            Could you help me...
                                            I have a Samsung UE55MU6102K with the following problem : I disconnect the motherboard from main power supply from and the backlight leds light up.
                                            Then motherboard connected, standby led is on and current consuption is 18W.
                                            Then trying to start the TV, the standby led is blinking once but TV don't start and standby led stay red.
                                            Maybe the firmware in the IC SPI Flash W25Q40CL (IC1604) is corrupted.
                                            The model of my TV is :
                                            Power supply BN44-00807A
                                            Main Board BN41-02568B / BN94-12765W
                                            Panel CY-GM055HGLV3H...
                                            05-01-2023, 04:30 AM
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • jeangonbay
                                            Samsung UE43MU6105K IC1604 dump needed - TV don't start
                                            by jeangonbay
                                            Could you help me,I have a Samsung UE43MU6105K with the following problem, dead TV, when I disconnect the main power supply to logic board, the leds light up.
                                            The model of my TV is UE43MU6105K
                                            Main Board: BN41-02568B
                                            BN94-12007Y
                                            Could you help me to repair the dump please. Thank you.
                                            02-16-2024, 05:46 AM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • Mephysis
                                            DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                                            by Mephysis
                                            Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                                            I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                                            03-27-2025, 02:34 AM
