Samsung "MU" series (UN, UA, UExxMUxxxx) fault dump IC1604 25Q40...
  • Willail
    • Jan 2016
    • 29
    • France
    Re: Samsung UN55MU6103F IC1604 dump
    Hello Lolas
    Thanks a lot for the softwares. I will test them tomorow and will inform you if it is ok
    • Willail
      • Jan 2016
      • 29
      • France
      Originally posted by Willail
      Hello Lolas
      Hello Lotas,
      I used Asprogrammer and followed the instructions in this thread in post #4.
      It's impossible to put a check mark on QE (SREG Edit). Despite this issue, the tv work again. Thank a lot for your fix in my firmware, you are the best
      I have an another TV samsung UE55RU7025K, mainboard BN41-02703A, it don't turn on anymore but i have the standby light.
      The power board seems ok because if I disconnect the cable with the mainboard and then plug it into the socket, the backlight comes on.
      I copy the firmware of ic1604 (W25Q40CL) with a CH431A usb
      Dear Lotas, would you please take a look at this and fix it for me please?
      • Willail
        • Jan 2016
        • 29
        • France
        Originally posted by lotas
        Here are the programs, instructions in this thread in post #4.
        Hello Lotas,
        I have an another TV samsung UE55RU7025K, mainboard BN41-02703A, it don't turn on anymore.
        • lotas
          • Jan 2016
          • 4599
          • Russia
          Hello Lotas,
          Your dump seems to be ok. Try these two working dumps for your motherboard.
          • Willail
            • Jan 2016
            • 29
            • France
            Thank you Lotas for the dumps for my motherboard.
            I try them but the TV doesn't work. I have only the standby light like with the the original dump.
            I copy the firmwares of ics W25Q80DV and 24C512 with a CH341A usb
            Dear Lotas, would you please take a look at theses dumps and say me if it is OK?
            I read that the W25Q80DV is for TCON and Panel. But i don't know the use of 24C512? Do you have an idea?
            • lotas
              • Jan 2016
              • 4599
              • Russia
              #26
              It's more likely a problem in the eMMC firmware, or there is no voltage on the dc / dc converters or broken hdmi inputs ..., you tried to disconnect the LVDS cable and turn it on.
              • Willail
                • Jan 2016
                • 29
                • France
                #27
                Yes, i tried to disconnect the LVDS cable and turn it on. But, nothing happens only the red light of standby which stay lit. Do you know how to update the eMMC? Do you have read the dump of 24C512? it is amazing there is a lot of FFF and 00000 in the top of the lines. It is possible to find a schematics where i could check some voltages? Thanks à lot for your help
                • lotas
                  • Jan 2016
                  • 4599
                  • Russia
                  #28
                  Here is someone else's dump eeprom 24c512 from the same motherboard and in the same way fff, 000.
                  • Willail
                    • Jan 2016
                    • 29
                    • France
                    #29
                    Hello Lotas,
                    Thank you for the dump eeprom 24C512. So, the 24C512 is not the problem for my TV. Probably the 25Q80 or the eMMC is faulty. I want to put another dump in the 25Q80. Is the same way to write the dump for 25Q40? May i put the registers? Do you know if someone who has this dump?
                    Thanks a lot
                    • lalodbs
                      • Oct 2017
                      • 14
                      • mexico
                      #30
                      help samsung un43mu6103f does not turn on, nor the attached power led my dump
                      • lotas
                        • Jan 2016
                        • 4599
                        • Russia
                        #31
                        Try.
                        • lalodbs
                          • Oct 2017
                          • 14
                          • mexico
                          #32
                          Try.
                          thank you very much lotas 100% working
                          • _adi_
                            • May 2017
                            • 5
                            • romania
                            #33
                            Dears,
                            I have a Samsung 55MU6102 with no stand-by light. In order to not bother you with my problem, I downloaded many dumps of the IC1604, and I have written the memory with it.
                            So far I got only to have red light on the st-by led, but the TV don't want to start.
                            As long as I cannot figure how to fix the original dump of the IC1604, I would like to ask you if you can help me to fix it.
                            Please excuse me if my English is not so good.
                            • lotas
                              • Jan 2016
                              • 4599
                              • Russia
                              #34
                              Originally posted by _adi_
                              Dears,
                              It is necessary to lay out the original, native dump, if you have not saved it and have already written other dumps to it, then this will be a problem.
                              • _adi_
                                • May 2017
                                • 5
                                • romania
                                #35
                                Thank you for the response.
                                I have the original one already saved
                                • lotas
                                  • Jan 2016
                                  • 4599
                                  • Russia
                                  #36
                                  Try.
                                  • avalente123
                                    Avalente
                                    • Dec 2017
                                    • 9
                                    • Portugal
                                    #37
                                    Hello
                                    I have one UE49MU6405U with no boot problems. I have the Ic1603. It is possible to fix it?
                                    Thank you
                                    • lotas
                                      • Jan 2016
                                      • 4599
                                      • Russia
                                      #38
                                      Originally posted by avalente123
                                      Hello
                                      Thank you
                                      Try.
                                      • avalente123
                                        Avalente
                                        • Dec 2017
                                        • 9
                                        • Portugal
                                        #39
                                        I tested and it works. Thank you very much. The only thing that not correct was protect SREG1 need to be 88 and only 8A. So i tested and tv starts again can it be like SREG1 8A?
                                        • lotas
                                          • Jan 2016
                                          • 4599
                                          • Russia
                                          #40
                                          Yes, it should be 0x88, 0x42.
                                            09-07-2024, 05:50 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • totof
                                            Samsung UE55MU6102K IC1604 dump needed - TV don't start
                                            by totof
                                            Could you help me...
                                            I have a Samsung UE55MU6102K with the following problem : I disconnect the motherboard from main power supply from and the backlight leds light up.
                                            Then motherboard connected, standby led is on and current consuption is 18W.
                                            Then trying to start the TV, the standby led is blinking once but TV don't start and standby led stay red.
                                            Maybe the firmware in the IC SPI Flash W25Q40CL (IC1604) is corrupted.
                                            The model of my TV is :
                                            Power supply BN44-00807A
                                            Main Board BN41-02568B / BN94-12765W
                                            Panel CY-GM055HGLV3H...
                                            05-01-2023, 04:30 AM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • jeangonbay
                                            Samsung UE43MU6105K IC1604 dump needed - TV don't start
                                            by jeangonbay
                                            Could you help me,I have a Samsung UE43MU6105K with the following problem, dead TV, when I disconnect the main power supply to logic board, the leds light up.
                                            The model of my TV is UE43MU6105K
                                            Main Board: BN41-02568B
                                            BN94-12007Y
                                            Could you help me to repair the dump please. Thank you.
                                            02-16-2024, 05:46 AM
